Question about ASUS P8P67 PRO - ATX - INTEL P67 - SOCKET 1155 - DDR3 SDRAM Motherboard
ASUS P8P67 PRO Intel I7-2600K PSU: Enermax Modu 87+EMG700AWT Memory: G.Skill RipJaws X Series 8 Go (kit 2x 4 Go) DDR3-SDRAM PC3-12800 - F3-12800CL7D-8GBXH Can not switch on the comp: When I press the start botton: nothing happens: no PSU and CPU wentillator spinning, no LED flashing on mobo,only light green Led in the SATA corner is lighting.
5 Suggested Answers
nai6378
  • 58 Answers
SOURCE: AUS A7N8X -X Mother board AMDAthlon 27648 CPU No picture
if this is a built sustem out of the box with old monitor try another monitor oddly enough some arent compatible, you can check by looking at the prong patern.
Posted on May 10, 2008
gtjr
  • 31 Answers
SOURCE: ASUS P5P800-VM motherboard - LED on; fan on; no monitor output
if it has an external video card reseat it or clean the gold contacts
Posted on Nov 06, 2008
support793
  • 81 Answers
SOURCE: Connecting my PSU to my Motherboard
The bare essentials to start a computer are PSU, Motherboard, CPU, RAM and Video.
Its possible the PSU arrived DOA. Though I've only had 2 DOA PSU's in the 15 years I've been building custom computers.
Hope this helps.
Mary
Posted on May 21, 2009
  • 4102 Answers
SOURCE: please could you tell me
HI, their is a good site that i use that will tell you exactly what you can and cant put in your motherboard if you go to this site and enter the mother board details it will tell you the maximum you can have is and also what ram will fit into it.
goto
www.crucial.com
then fill in the details and it will tell you everything ok
i build pc's and use this site to max out pc's and have always found it covers all makes and models.
let me know if you have any problems with the site ok
plz rate this solution as i have a whole page of unrated posts, thanks
Posted on Sep 21, 2010
1. How to indent a motherboard?
All mother boards have its number printed on it. With that number, you can Google to know its details, and specifications.
Gopakumar Gopalan Google
Jul 04, 2014 | ASUS P8P67 PRO - ATX - INTEL P67 - SOCKET...
2 beeps, no post on my Asrock Extreme3 970
two things:
your RAM's its not fitted right or in right spot.
too small power supply, its to narrow in watts, should have 750 Watts at least.
Mar 22, 2012 | Computers & Internet
Does the Intel MB DG41TX work with the Intel 7300 processor and a single 4GB memory module (Kingston KVR1333D3N9/4G)?
maximum memory for this motherboard 4 GB not sure about a single 4GB module
Max Supported Memory 4 GB
  • Supported RAM Technology DDR3 SDRAM
  • Supported RAM Integrity Check Non-ECC
  • Two 240-pin DDR3 SDRAM Dual Inline Memory Module (DIMM) sockets
  • Support for DDR3 1333(OC)/1066/800 MHz DIMMs
  • Support for up to 4 GB? of system memory
  • hope this helps
  • Sep 03, 2011 | Intel DG41TX Motherboard
    I want to get a usb 3.0 hub and plug it to the asus p8p67 pro on the middle of the mother board. What kind of connection is it?
    The header bus above is for the USB Front Panel interface:
    This is included in many of the various flavors of the MoBo. If you're looking to use the MoBo connector to supply something other than this Front Panel interface, you're going to need to obtain the pinout of the jack on the motherboard and compare it to the signals required by your USB 3.0 device. The one from Asus is simply gathers the wires and forms them in a single shell - then keys the shell to prevent reverse insertion.
    Think of what you have to do as the way USB 2.0 headers are provided on MoBo and the way PC cases have USB jacks built in. The USB header isn't standard; some have 9 pins - some even have 10! They can't seem to get on the same page as to how many pins are needed. The location of the signals on the header are probably different from brand to brand, too. So, the case manufacturers break up all the individual wires and label the signal so that YOU can check the MoBo manual and plug each one in to the correct pin.
    May 06, 2011 | ASUS P8P67 PRO - ATX - INTEL P67 - SOCKET...
    Zipcode to malta?
    This link here is the best I could find for postal codes for Malta. Just click on the jurisdiction, or as it is listed Local Council and it will give you the info you need. I cannot guarantee the accuracy of this information as postal codes can change, but I feel it is fairly current.
    Glad to help.
    Thank you for using FixYa.com
    Apr 22, 2011 | ASUS P8P67 PRO - ATX - INTEL P67 - SOCKET...
    My computer was working fine and i went down stairs to put dishes in the dish washer and went back to my computer and it was off, i tried to start it and nothing, the power light is on that is on the...
    This might work.
    Power off your computer.
    Remove your "ram" memory stick(s).
    With a pencil eraser, very gently rub the gold metal contacts on the sticks. (all you're doing is cleaning them).
    Reinsert the ram and try rebooting.
    Let me know how it works out.
    Feb 21, 2011 | ASUS P8P67 PRO - ATX - INTEL P67 - SOCKET...
    I have a m4a78lt-m motherboard will kingston ddr3 1600 4gb khx1600c9d3b1k2/4gx memory work with 32bit os I am putting a system togather have purchased the mother board and memory now i am questing if it...
    This motherboard uses DDR3-SDRAM, ECC and non-ECC, unbuffered, PC3-10600(1333mhz) or PC3-8500(1066mhz), dual channel architecture (two sticks at a time), and a max memory of 8Gs.
    This are the specs for your ram: 4GB 1600MHz DDR3 Non-ECC
    (Kit of 2) Intel XMP HyperX = DDR3-1600
    Default = DDR3-1333 CL9-9-9-27
    CL9-9-9 1.65V
    1.5V
    In other words, Yes! This should work just fine. The ram will just run at its default speed of 1333mhz.
    Jan 28, 2011 | ASUS M4A78LTM LE Motherboard
    THE PC BOOTS TO 1 LONG BEEP, 3 SHORT BEEPS. THE BOOK SAYS DID NOT DETECT VIDEO. TRIED BOTH PCIEX SLOTS AND 2 DIFFERENT VIDEO CARDS. CAN'T GET OT TO GO ANY FURTHER!!?? WHATS THE LIKELY PROBLEM?
    the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
    make sure that your RAM is securely seated
    test or replace all the leads that attach to your hard drive make sure the connections are secure including electrical extensions + IDE,SATA the ones that attach from your
    ((motherboard to hard drive))
    make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
    hope this helps
    Jan 27, 2011 | ASUS P8P67 PRO - ATX - INTEL P67 - SOCKET...
    I dont know wat sort of ram to choose for this board because i am wanting to put in x6 4 gig ram ddr3 memory modules
    running triple channel memory with more than 3 DDR3 1600 sticks installed (4-6) cuts the memory speed in half. you have to run with 3 sticks at a time in triple channel mode or you will see a reduction in ram speeds.
    OCZ is making some good 4 gig ram sticks. they have a 12 gig triple channel memory kit with 3x4gig sticks. you could get 2 of these kits and have your 6 sticks- 24 gigs total, but your memory frequencies will be lower- your ram access will be slower.
    Oct 28, 2010 | ASUS P6X58DE Desktop Board Intel Chipset...
    ASUS P8P67 PRO - ATX - INTEL P67 - SOCKET 1155 - DDR3 SDRAM Motherboard Logo
    50 people viewed this question
    Top ASUS Computers & Internet Experts
    Alun Cox
    Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
