Question about Kenwood 1080VR Receiver
I have a Kenwood 1080V-R and have had it since new. While operating, just stops, unit is on, no sound. Then I have to unplug and plug back in to get back on. This happens irregularly throughout the day, some days a lot, some days not so many, appears to be getting worse. Only setting for speakers I can get is Jazz Club, etc. Thanks Jay Sheehan
  • 2,098 Answers
Hi Jay,
This kind of trouble was caused by leaky/dried electrolytic filter capacitor in the power supply section and or bad solder joints. You must have a capacitor checker to determine the condition of capacitor to isolate the faulty one. Also check for bad solder joints around the power supply section. This is hard to spot, I would advice you to work in the brightest area or used portable/table lamp. If you don't have necessary tools and test instrument, I would advice you to look for a qualified technician to troubleshoot the symptom.
Hope I helped you. Have a nice day! Thanks for using Fixya.
Posted on Mar 22, 2011
The back and top of the unit is getting very hot fast...like hot to the touch. I had a kenwood in there before so I just unplugged it from back and plugged into new unit. its in a jeep not boat
Hi, your issue can be caused by many thing. My first question is why did you change the first radio. Just because its the same brand, doesnt mean the plug or wiring is the same as the new unit.(unless its an exact replacement.) My first thing i would chk is the wires on your speakers. Most jJapanese eequipment for cars and such is 4ohm. If you wired two 4ohm spkrs in pparallel your load drops to 2ohms, which will make the system work harder and get very hot. I would try unhooking them and rreconnecting them one by oon. Hope that helps.
Feb 21, 2016 | Kenwood KMR-D562BT Marine CD/MP3 Player -...
I can't operate my kenwood KR-A4070 receiver manually anymore, it only operates with factory remote. When it was new, I could manually press the various function button's..such as power-tuner-etc., an
Only a service person can help now. Likely you have a connection loose, a buldged cap or maybe just a transistor with a cold solder joint. Not being able to see it makes it hard to tell.
Jan 21, 2015 | Kenwood Audio Players & Recorders
Kenwood no sound
Just had the same thing happen to my new pioneer system. My truck battery died because I was jamming to the new installation, and the system just suddenly turned off. I charged the battery and the unit came on all the lights menus and displays worked like normal but there was no sound coming from the speakers. I checked all the fuses in the truck but none were burnt out. So I remembered there was a fuse on the back if the unit so I had to pull the unit back out. I checked the fuse and it was fine. I unplugged the wiring harness from the unit, plugged it back in and IT WORKED so I'm not sure exactly what was wrong with it, but I suspect when I unplugged the harness it reset the unit. So maybe this will work for your installation as well. Not exactly a high tech answer but maybe it will help ya! Good luck
Jul 23, 2014 | Kenwood KDC-S2009
Does the Kenwood KDC MP5032 have an aux input? If so, where is it?
Kenwood utilize the CD Changer plug in the back (which acts as a secondary Aux input), to operate external iPod devices.
This is done with the aid of an Adapter Lead - it has the 13-pin DIN plug on one end (plugs into the rear of your unit), and an iPod plug on the other end (plugs into your iPod).
Depending on the "Generation" of your external iPod device, you will need to buy the appropriate Kenwood adapter cable. These are: KCA-IP102, KCA-IP202 or KCA-IP302.
There may be some aftermarket (3rd party) cables that may do the same job.
Just ensure you read your Kenwood manual, as the Kenwood unit may be limited to the types of files (i.e. formats) it can read & play.
Hope this explains....
Cheers,
Dec 31, 2012 | Kenwood KDC-MP5032 CD Player
I hooked up my kenwood kdc-x692 and i plugged it in the first time and it started playing right and then i unplugged it from the dock in the back to finish the wiring then i plugged it back in and it read...
Double check your wiring. If there's a problem with a wire or wiring, when you disconnect the bad cable the protect warning should clear. Disconnect them one by one, until you clear the fault. If it doesn't clear,and the unit is still in warranty or new, get it exchanged. If the unit isn't in warranty, it will have to be serviced. You can take it to a local TV Repair shop, or contact Kenwood for the closest repair facility:
http://www.kenwoodusa.com/Support/
Good luck and hope this helps.
Mar 28, 2011 | GPS
The standby indicator blinks and the unit will not come on
Contact Kenwood website - usually a malfunction in the unit requiring service, and you cannot reset it. HOWEVER, try the usual unplug, wait and plug-in again. Make sure that there's not a shorted speaker - so unplug all speakers and try using just headphones. Also, make sure you have air ventilation around the unit - nothing on top of it, as that will cause it to overhead and shutdown. Try these items and report back. Good Luck!
Dec 29, 2009 | Kenwood KRF-V5060D Receiver
Reciever won't power up
HI, this amp may need to be reset. also, i would check the voltage selector on the back side to make sure the switch is set to 110-120v. once this is done, you will need to reset the microcomputer. here is the procedure.
The microcomputer may malfunction (unit cannot be operated,
or shows an erroneous display) if the power cord is unplugged
while the power is ON, or due to some other external factor. If
this happens, execute the following procedure to reset the
microcomputer and return the unit to its normal operating
condition.
Procedure- Unplug the power cord from the wall outlet, then
plug it back in while holding down the POWER key.
ok, after this reset, if your receiver isn't operational, it may have serious damage to its power board.
Mar 07, 2009 | Kenwood VR-605 Receiver
No front speaker sound
Microprocessor reset.
For US and Canada:
  1. Unplug the power cord from the wall outlet, then plug it back in while holding down the POWER key.
For other countries:
  1. With the power cord plugged in, turn the POWER key OFF. Then, while holding down th ON/STANBY key press POWER.
Jan 12, 2008 | Kenwood VR-209 Receiver
Kenwood 1080VR Receiver Logo
126 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
