Question about Intel D845GVSR Motherboard
I need a graphics Card for Intel 845GVSR motherboard PC!!! I couldn't find any!!! plz help!!! it supports AGP Card and DDR 1
  • 961 Answers
Http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007709%20600007850&IsNodeId=1&name=AGP%204X%2f8X
This is a link for Newegg. AGP cards are the older style of card. The newer style is PCIe express x16. The AGP cards are available.
Posted on Mar 22, 2011
What would be the best compatible 512 MB GPU(with shader 3 or 4) working with P4I45GV 3.00 /P4 2.4 GHZ/1 Gb ram ?
http://www.asrock.com/MB/overview.asp?Model=P4i45GV%20R5.0
Any of them Shubham.
If we are to discern by a few known statements;
1) It is believed in some 'geek communities', that using the same manufacturer of motherboard chipset, and graphics chipset; to be a good thing.
For example an AMD motherboard chipset 'plays well' with an AMD ATI graphics chipset;
Nvidia motherboard chipset 'plays well' with Nvidia graphics chipset.
Intel motherboard chipset with Intel graphics..............no wait,....... there is no Intel graphics chipset, unless it is -> Integrated Graphics.
[ Intel GMA ]
(Integrated Graphics is also said as OnBoard graphics. ON the motherBOARD)
2) DOES NOT MATTER what graphics memory type is used.
Motherboard can use DDR Sdram ram memory, and graphics card can use GDDR5.
Why?
Because the graphics card has it's own Processor, and Ram Memory.
Graphics Processing Unit, or GPU; is the Processor,
http://en.wikipedia.org/wiki/GPU
Graphics memory is the ram memory.
Operates independent of the system resources.
The graphics expansion slot on the P4I45GV (P4 i 45GV), is an AGP slot.
Accelerated Graphics Port,
http://en.wikipedia.org/wiki/AGP
It will use an AGP 4X, or AGP 8X graphics card.
Use an AGP 8X.
http://www.tigerdirect.com/applications/SearchTools/search.asp?keywords=agp+graphics+card+512mb
REMEMBER;
1) ALWAYS follow Anti-Static Precautions.
2) INSTALL the software for the graphics card F-I-R-S-T,
(Drivers and 'control panel')
THEN unplug the computer from power, follow Anti-Static Precautions, and Physically plug the graphics card into the motherboard, and install.
3) L@@k at the system requirements (Minimum) for the graphics card.
Specifically the Power Supply requirements. You need a Power Supply with enough Wattage, to handle the graphics card.
[ Handles the graphics card, and -> Motherboard, Processor, Ram Memory, and peripherals; Internal and External.
{Harddrive/s, optical drive/s; Internal
Mouse, Keyboard, external harddrive, etc; External ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 17, 2012 | Computers & Internet
Is my mobo compatible with a 256 mb 128 bit fx5500 agp video card?
youre motherboad support intel pentium d 800mhz fsb processor and ddr 400, it has built in graphics, yes it will support a 256 128 bit fx5500 agp card, the agp 8x/agp 3.0 enhance graphics performance it support a high bandwidth speeds up to 2.12gb/s its twice faster than agp 4x,
Nov 22, 2009 | EliteGroup 865G-M8 (V1.0) (MB865GM8)...
Finding Intel 845GVSR & 915GLVG Compatible Motherboard & Proc
you can use intel dg41 mbd , dualcore processor,1 gb ram,160 gb hdd or use intel atom for support contact 91-9645071021
Aug 11, 2009 | Intel D845GVSR Motherboard
I need help choosing a video card.
Hi there.
Any PCI Express card will do as long as its DDR2, DDR3 is not supported by your motherboard.
You have a choice between ATI or Nvidia graphics cards and your system should support up to 1GB of graphics memory.
Good luck and thanks for using FixYa!!
May 13, 2009 | Intel D101GGC Motherboard
Intel 845 GVSR drivers for windows vista
change to Windows XP,
windows vista will not support with *********** board
it will support more then 865 chipset
May 17, 2008 | Intel 845GE Motherboard
Not getting ATI Radeon 512MB graphics card
Go for :
ATI Radeon X1650 Pro 512MB AGP
ATI Radeon X1600 Pro 512MB AGP
plz rate me if this info is helfull to you... Thanks
May 14, 2008 | Intel D845GBV (BOXD845GBVL) Motherboard
Fix for older motherboards like Intel 845GVSR etc.,
HERE IS THE SOLUTION FOR FIXING DISPLAY PROBLEMS....
(This solution works for any Intel Motherboard)
No need to donwload or install any drivers.
Vista has everything built in.
Only thing is it needs atleast 128 Mb of Video Memory, but for older motherboards like Inter 845 by default the Video Memory is configured to 64 Mb which is resulting in your problem.
So what you have to do is...
SOLUTION:
Restart your computer > Press DEL Key
and
Go to BIOS Settings > Advanced > Video Configuration
1. Change "AGP Aperture Size" from 64 Mb to "128 Mb or Higher"
2. Leave "Primary Video Adapter" as "Integrated"
3. Change "Frame Buffer Size" from 1 Mb to "8 Mb"
and then press F10(i.e., Save changes and continue).
Sometimes, for the first time you may see screen not aligned properly, in that case just restart once more and Vista will automatically adjust the alignment for you.
Also, you can change the resolution to your desired one manually as follows...
1. Click "Start Button"
2. Right click on "Computer"
3. Select "Properties" option from the context menu.
4. Scroll down and find "Disply Settings" option and click it.
5. Adjust Resolution Size and Mode.
NOW, ENJOY USING VISTA.....
Apr 09, 2008 | Intel D845GVSR Motherboard
i don't know weathere you are awared of this or not...
to get the 32 bit graphic on 82845gv motherboard go to BIOS setting and change your video frame buffer size to 8 mb and agp aeperture to 256 mb and let the system boot... you will get 32 bit graphic with 1024 x 748 screen resolution... i have changed and believe me it is working
but only problem is that you will hardly play any game or use bubble screen saver..
Feb 24, 2008 | Intel D845GVSR Motherboard
Intel P$ 1.8 mhz on a D845HV/D845WN board
Before removing your current card swap video outputs on the PC. If currently connected to the VGA output switch to the HDMI connector AT the video card. Use the HDMI to VGA adapter that came with the video card. Check & see if the display loads Pc starts. Taking the information directly from your motherboard manual pg. 25, your AGP video can only run at, AGP supporting 1.5 V 4X AGP cards. The 9600pro runs at 8x & it is not backwards compatible. (able to run at either 8x or 4x). You could run the Sappire ATI Radeon 256MB 9550 DDR AGP 4x/8x 1.5volt card.
Here is one site: http://www.colordrives.com/sapphire-ati-radeon-9550-256mb-ddr-agp-4x-8x-video-card---retail-box.html
When you do get the video card be sure to set your bios AGP to the correct size as listed in your manual pg. 109 subsection 4.4.7
I hope this helped.
Feb 20, 2008 | Intel Motherboard
Intel D845GVSR Motherboard Logo
67 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
