Question about Kodak EasyShare C180 Digital Camera
Kodak C180 won't turn on. Multiple new batteries have been tried.
Solved! Works with NiMh 1.25 volt batteries! I pulled out my multi-meter and measured the voltage of two AA alkalines which were both around 1.47 volts. With these in the camera (Kodak C180) it wouldn't turn on. I tried charged NiMh batteries which measured 1.25 to 1.3 volts and it turns on as expected.
Posted on Sep 27, 2012
    Problem Solver:
  • 53 Answers
Remove battery 2 day's. Try again
Posted on Mar 22, 2011
3 Suggested Answers
leepania
  • 1099 Answers
SOURCE: My Kodak EasyShare C180 Digital camera, came with
We recommend you to use Rechageble batteries with 2000 mAmp or higher alternatively AA non-rechargeable lithium batteries (Ni-Mh)
Kodak Digital Imaging Support Centre can be contacted on any of the numbers below:
UK 0870 243 0270
International Toll line +44 (0) 131 458 6714
Posted on Oct 12, 2009
BillB-SA
  • 2761 Answers
SOURCE: I put new batteries in my Kodak easyshare c180 and
First make sure that you have the correct batteries for the camera and that they are installed properly. That taken care of, your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Posted on Oct 25, 2009
My Kodak EasyShare C180 10.2MP Digital Camera is less than a year old and suddenly won't turn on. I thought the batteries were dead so I replaced them...twice...and tried changing the direction around...
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Jul 06, 2011 | Kodak EasyShare C180 Digital Camera
Not downloading to computer Kodak easy share C180
Did you install the software and/or drivers before connecting it to your computer? if not, the computer won't recognize the camera. If you don't have the disk that came with the camera, you can get the software for free from Kodak's website. Download the software and drivers, then reconnect the camera to the pc with it turned on. That should solve your problem.
Mar 24, 2011 | Kodak EasyShare C180 Digital Camera
My kodac easy share c180 wont turn on
This kind of issue might happen. Remove the battery from the came and then press&hold the power button of the camera for 30 seconds.... Put the battery back and then try to turn it back on.......Hope u are sure that the battery has enough charge. If the step does not work try some other alkaline or lithium batteries if possible.
Feb 17, 2011 | Kodak EasyShare C180 Digital Camera
Brand new camera will not turn on
Be sure the batteries are inserted with the + and - facing the correct way.
May 25, 2010 | Kodak EasyShare C180 Digital Camera
Camera Kodak C180 On receiving the camer it
This is a "budget" camera on the low end of the quality scale. Quality control isn't very good and if you just bought it, return it...it's obviously defective.
Feb 19, 2010 | Kodak EasyShare C180 Digital Camera
My C180 easy share won't turn on.
Kodak's advice is disinformation & damage control: this is actually a product defect--it's a firmware bug that affects most Kodak Easyshare cameras, but Kodak will probably never admit it. The problem usually starts after you change the batteries or connect the camera to the computer. Google for "Kodak easyshare wont turn on" - there are more than 8,000,000 results. Just returned my new camera to the store because it locks up every time I change the card or transfer pictures via the USB port. Thought I was getting a good deal, but now I know why this was the cheapest camera they sold. What a waste of my time & money. So it's usually NOT the batteries fault--the real problem here is Kodak's low quality engineering.
Jan 12, 2010 | Kodak EasyShare C180 Digital Camera
Kodak C180 for Xmas - The pic of the battery shows
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). The batteries that was in your pack when bought are only test batteries and not rechargeble.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Turn on your camera without the memory card.
In order to organise your repair or Trade up please Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jan 04, 2010 | Kodak EasyShare C180 Digital Camera
I have a Kodak Easyshare C180 digital camera. I open ity, take a picture and then it closes. I then cannot get it open again. I see the on/off button but nothing happens
Is the camera LENs won't retract? Try to use a brand new different recomended batteries like alkaline batteries or lithium batteries. If your using a rechargable batteries make sure that they are fully charge. You can also try to turn the camera ON without using memory card. Remove the memory card on the camera. Then put a new recomended battery, try to turn it ON if the camera will not turn ON or stay ON call kodak support line. Support in English and Spanish is available at 1-800-235-6325 (23KODAK)
Nov 15, 2009 | Kodak EasyShare C180 Digital Camera
My Kodak EasyShare C180 Digital camera, came with "Kodak" batteries after those died, I inserted new batteries, and now everytime I try to turn the camera on, it doesn't respond. I have tried Lithium...
hi i just to have silimar problem with old panasonic, kodak and polaroid cameras.
try to use Duracel alkalines, not the cheap ones with out alkaline those are for remotes and clocks. flashlights.
if you are using rechargables make sure they are 2700mha AA NiMH or higher. lower won't work(there is another kind of rechargeables batteries those don't work on it).
for the lithium i never used them. they were kind of expensive compare to alkalines.
If i help. please rate me :)
Oct 08, 2009 | Kodak EasyShare C180 Digital Camera
Kodak EasyShare C180 Digital Camera Logo
184 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
