I have a bonair evap aircon model VSL72 and have just replaced the water pump to suit .when wiring the unit up I connected it as showen on the wiring diagram but nothing workes.please could you tell me which wires go where as i may have gotten them mixed up.
5 Suggested Answers
SOURCE: Need a wiring diagram for mastercool evap 2 stage unit
I have the wiring diagram in the cooler. I can photograph and send it to you. Do you still need it?
Posted on Jun 06, 2009
  • 5 Answers
SOURCE: vulcan bonair evaperative cooling unit will not
If shut down at end of season by air con person may be switched off in roof unit. just remove one side and should have switch in unit usually near pump
Posted on Nov 01, 2009
SOURCE: Our Bonaire Evap Cooler stopped after power failure
Turn the power of to both the heater and the cooler. Turn the power back on to the heater and the cooler at the same time then reset codes on controller.
Posted on Feb 09, 2010
  • 123 Answers
SOURCE: bonair evap. when the wind comes up, the unit
You can't get a person to balance the blades, they just replace them. As for it coming on off on off... That sounds like a Tstat problem. Perhaps you should change the Tstat. You might even have a short in the tstat wire.
Posted on Jan 28, 2011
Water won't stop flowing on Bonaire Evap system, even after turning system off , any ideas?
repair the water control valve
the rubber stopper is failed and needs replacing
Nov 17, 2015 | Cars & Trucks
Bonaire vulcan comfort control
No it cant really be fitted as the evap system uses much larger duct and also in some cases people use a different type of duct that when running a gas heater threw it it tends to melt with the heat. Your best option would be to get new ducting that way you can size it correctly so you dont have air alance issues down the track.
May 10, 2014 | Heating & Cooling
I have a bonaire evap system cant get it to come on have changed batteries and reset it still nothing happens the remote is called bonaire comfort control have recently brought the house and cant find an...
Remotes are a pain. Can you get into the unit to see the control box? You need to see if the unit has power. If its new enough it will have some diognostic lights so you can see if it has power. Without that its hard to diognose. Unit Model number is also helpfull. if it looks like the one on this picture it will be etched into a badge on one of the corner pillars. if its a plastic unit it will be on a sticker inside the unit
Feb 24, 2011 | Mastercool 67471 Evaporative Cooler Air...
Bonair evap. when the wind comes up, the unit roar`s on off, on off it`s very annoying, also who can balance the fan?
Jan 28, 2011 | Heating & Cooling
Feb 07, 2010 | Mastercool 67471 Evaporative Cooler Air...
Vulcan bonair evaperative cooling unit will not operaate when switched on
Nov 01, 2009 | Mastercool 67471 Evaporative Cooler Air...
Vulcan-Bonaire : summer breeze
This unit is a cooling unit only. I don't know what switch you are looking at but I don't think it's for the evap. cooler(swamp cooler). I am in the Phoenix, Arizona area and it's very common to have a evap. cooler and a seperate heat/cool system as on the hottest days the evap. cooler doesn't cool enough. I hope this helps. Please give me a positive rating. Thank you.
Jan 27, 2009 | Mastercool 67471 Evaporative Cooler Air...
Heating & Cooling Logo
57 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
