Question about GE Microwave Ovens
The oven doesn't work. Indicator stays on temperature 100
  • 2 more comments
  • lidiyac Mar 22, 2011
    Sorry, my question is about gas slide-in range oven model JGSP33. The oven doesn't work. Indicator stays on temperature 100
    my question is about gas slide-in range oven model GE JGSP33. The oven doesn't work. Indicator stays on temperature 100. The cooktop is working properly
  • lidiyac Mar 23, 2011
    I checke one more time the oven. The grill is working but the baking is not. Can you tell me what part it could be?
    I checked the oven and the broiler is working and the gas bake is not. Could you tell how can I order the technitian to solve the problem. I live in Brroklyn, 11235
  • GE Master
  • 1,902 Answers
Hello & Welcome to FixYa
This indicates an open/shorted oven temperature sensor and to solve this problem the temp.sensor needs replacement. If you want to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Posted on Mar 22, 2011
  • Kevin White
    Kevin White Mar 23, 2011
    It is the oven temp sensor and you can check here to call a tech
  • 2,069 Answers
That it is mostly fault of magnetron tube inside Microwave. This is the component that produces the microwaves that heats the food. The cost of the magnatron is about 90% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven. however, there is also a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process requiring some bit of a skill though.
Regards
Circulator fan is not working
call a service technician to fix
Dec 12, 2015 | Microwave Ovens
AEG micro-combi oven has big condensation problems. The glass on the oven door clouds over and drips of water can be seen on the glass. Water also drips out on both sides of the oven at times formin
Condensation inside the oven comes mainly when the temperature is below 100 Celsius, and this phenomenon is evident in almost all manufacturers. That means, the condensation starts at the beginning and at end of baking. My advice is the same as many manufacturers recommend: Before baking, preheat the oven to min. 100 Celsius and after that place the food in the oven. Reverse the procedure in the "cool down" phase before the temperature drops below 100 ° C and remove the food from the oven.
After that condensation should be drastically reduced.
Condensation could be technically solved but it would be too expensive for manufacturers (more parts inside oven) as well as for customers also (too expensive appliance and lost energy).
Dado
PS. This applies to the traditional way of baking
Feb 14, 2015 | AEG Microwave Ovens
Replaced 20amp fuse that was blown. new fuse did not blow, but oven is still dead.
see this causes and fix it. God bless you
If your microwave oven doesn't seem to work at all, check these: Fuses Door switch Fuses Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it. Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work
Sep 22, 2012 | Cuisinart CMW-100 Microwave Oven
The oven doesn't work, the timer works and the light comes on
This is a strong indicator the magnetron has failed "heats food" and is the heart of the system. If microwave oven is a few years old better to invest in new.
Mar 06, 2012 | Cuisinart Microwave Ovens
What is the temperature attained inside the microwave oven in a time span of 100seconds if the rating of the oven is 1200watt ?
The mass of the material you are heating affects the temperature achieved. ie. 2pints of liquid will reach a lower temperature than 1pint in 100 seconds.
Sep 06, 2011 | LG LMV1630 Convection/Microwave Oven
The burners light indicator stays on even when the burners are turned off
Here is a tip that I wrote about the problem of the cooktop light staying on.
Oven Hot Surface Indicator Light stays on heatman101
Apr 23, 2011 | Microwave Ovens
The bake function on the oven is not functioning the rotary dial adjusts the temp setting after the bake function is selected 350 temperature is selected and the temp flashes and stays at 100 without...
You probably have a bad bake element or control.
Please note that FixYa is not currently notifying us Experts when Clarification Requests are answered.
To allow us to help you effectively (at no charge), please post a
NEW problem to FixYa (but in the oven section, not in the microwave section), and please include your brand name and the full model number from the tag in or on the unit, and your symptoms.
You can find links to helpful exploded view diagrams and part ordering help here.
I'd recommend that your bookmark this link to your favorites.
Dec 11, 2009 | Roper Microwave Ovens
How to set temperature
hi friend,
The microwave oven per se, does not have a temperature. The microwaves that are generated simply heat up the water molecules in the item that they hit. So, the maximum temperature, I guess, would be 100 degrees C or 212 degrees F, the boiling point of water.
thank u for using fixya
regards,
sivaranjini
Aug 05, 2009 | Samsung MW4699S Microwave Oven
Microwave Ovens Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
