Question about Ryobi Garden
I HAVE BURST THE HI PRESSURE HOSE ON MY RYOBI CLEANER.WHERE IS YOUR CLOSEST AGENT IN PIETERMARITZBURG? tHANKS BOB HATTING. 0826776011
    Sergeant:
  • 259 Answers
Some parts stores can make the hose up. Show them the old fitting that connect to the pressure washer.
Posted on Mar 22, 2011
Why does my pressure hose burst when I use a turbo nozzle
Turbo heads are pressure rated for different pressure washers, your turbo head is most likely rated bellow the maximum pressure of your washer which in turn causes a pressure build up in the hose and it's eventual failure.
Sep 24, 2014 | Honda Pressure Washer PSI 3000
Install replacement high pressure hose
If you are replacing the hose because it burst you might contact the manufacturer. Mine, of a different brand, burst and they sent me a new pressure washer saying that it was very difficult to install a new hose. They had a lot of problems with hoses from China.
Apr 09, 2014 | Greenworks 1700 PSI 1.4 GPM Electric...
Power steering hose burst
There is little pressure on the return hose
Are you using power steering hose or vacuum
tubing or regular gas hose?
Take the pump off & apart or look for blockage
going into it
Mar 02, 2013 | 2006 Dodge Grand Caravan
What are the components in the handle of a Ryobi RHP 410 pressure washer?
Hello sir, that is a on going problem with power washers the pump not working, than works sporadically. the main cause is leaving the pressure hose hooked up to the machine over a long period of ,not draining hose & machine, in the winter time the hose & pump willfreeze causing hose & pump to expand and burst. build up of calcium deposits from hard water clogging up pump nozzle,valves in the gun handle,clogging hose fittings and screens.one of these has to be your problem.you can find a parts brake down at KARCHER.COM.orRJ BOWERS.COM . and manuals,these are good info,sites,hope this helps, MrFixIt,oh could you please rate this solutions.thankyou. ``
Jan 28, 2012 | Ryobi Garden
I was told that my upper radiator hose is soft. Do I need to replace it and what is the cost?
YEP HOSE TOO SOFT CAN BURST AT ANY MOMENT.MOST OF THE TIME SOFT HOSE BURST IN VERY HOT WEATHER QUICKER DUE TO MORE HEAT AND PRESSURE ON HOSE.HOSE PRICE RANGE $20.00 OR UNDER DEPENDS ON WHERE YOU BUY HOSE.
Jul 05, 2011 | 2006 Scion xA
Model rlt30ces serial no 0811007404
Thanks found a distributor in Townsville
Nov 30, 2009 | Ryobi Garden
Ryobi Cultivator 410r
The linefrom the tank with the filter goes to the mixture inlet on carb. The fuel return goes to the suction side of bulb. The bulb outlet line goes to the tank. Hopes this helps
Mar 19, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Karcher/Winner 11 - motor pulses when hose is not operating
Hi, I had the same problem, Replaced the O rings and the rubber seals and cups inside the pressure washer and eventually the hose itself burst. Turns out the hose was leaking, internally between the inner sheath and the outside plastic cover, for quite some time and this caused the pulse. New hose and pressure cleaner is as good as new.
Mar 15, 2009 | Karcher K2.26 Electric Power Washer
Air conditioning
The system refrigerant charge was most likely low but not empty, so you would get a burst of pressure and oil, the oil that lubricates the AC compressor circulates with the refrigerant. Does this make sense?
Jul 30, 2008 | 2001 Honda Accord
Garden Logo
100 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
