Question about Garden
Unable to raise pressure on Europ Super SIP Water Pressure Washer. Checked electrical connection and that is OK.
  • 313 Answers
SOURCE: I have a Karcher electric
see www.pressureparts.com for karcher
Posted on Jul 08, 2008
stug_57u
  • 99 Answers
SOURCE: No pressure in the pressure washer
Leaving the hose on shouldn't cause a problem so don't panic. It sounds like you could just have a dirty nozzle. Try sticking a pin or something in the end of the nozzle (machine not running) and giving it a clear out. also if it is a two peice gun, split it and tap the squirting part on something clean like a workbench to clear any debris that might have got in there.
Posted on Nov 01, 2008
  • 92 Answers
SOURCE: Karcher electric pressure washer
Dear mike husband,
One reasin for this fault could be a damaged lance or turbo lance. Try by replacing with new ones. If the problem is not solved, then the fault is due to a damaged spill valve. The spill valve could easily be damaged by using not suitable chemical or detergents. After using chemical detergents, one must always rinse the machine by passing pure water. The spill valve could also be damaged by leaving the machine for a long time with pressure in the system. One must never store such machines with pressure still inside. Always press the gun before storing.
Well the solution is to change the spill valve with a new one. In some cases even faulty suction valves can give this problem. But in the majority of cases it is the spill valve.
If you do not know how to fix this problem, it is better to be done by an expirienced technician.
Regards,
MG.
Posted on Nov 05, 2008
CRTN
  • 716 Answers
SOURCE: High pressure hose connection blew up. Fix? or buy new?
Yes take it to napa auto parts and they can cut and attach a new end which are for hydraulics. They are crimped on and meant to hold very very high pressure. I used to use a pressure washer everyday for a living and it was a tractor rental/repair shop and we used the hydraulic fitting machine on the power washer hose all the time so rest assured.
Posted on Mar 11, 2009
SOURCE: my karcher pressure washer has lost its water power
I have the same problem. With mine I have to remove the tip that I am using then pull the trigger and then replace the tip and pull and pressure should return. I believe that one of my valves is sticking causing me to reprime the pump frequently. I am trying to clean or replace my valves to fix the problem.
I hope this helps.
Posted on Apr 25, 2009
Where would I go to get our pressure washer serviced? I live in the Saskatoon, Sask. surrounding area.
Does the electric motor keep running? If it does continue to run with the trigger in the spraying position, then your pressure switch and motor are OK. If the motor is running and the water is not coming out with pressure, then either your check valves are not closing properly or the pumping mechanism is in need of repair. I think those little electrics have a simple wobble plate design. Basically not worth the effort to fix them
Oct 09, 2014 | Karcher 16017720 K3.690 X Series 1800 PSI...
Getting f20 error code, how to check flow meter operation
Check for stuck socks or something just under the door seal at the bottom of the drum. Check filter for blockage and all outlet pipes. Check the pressure switch hose for any holes as it may have rubbed on the drum and created a small hole in it. Make sure flow meter is level and not at any angle.
Dec 22, 2012 | Whirlpool duet Washing Machines
I can't get the pressure washer to start up. The water is coming out of the hose, but there is no water pressure
If the washer is the kind that shuts off completely when the pistol grip is released, the problem is likely the little pressure sensor located near the output fitting (the threaded part to which the hose connects). The sensor is a little plunger held down against an opening in the side of the pipe by a spring when there is low or no pressure in the output pipe, as when the trigger is pulled and the pressurized water in the hose is released by pulling the trigger. That completes the electrical circuit and the washer is on and continues pumping water. When the trigger is released, water in the hose and output pipe jams up super high pressure, forcing tjhe little plunger out against the spring, and the electrical circuit is broken. If you take the case apart, you will see wires coming from that area. The fix (if this is the problem) is to free up the little plunger.
Dec 05, 2012 | Coleman Powermate DuraBuilt 1400 PSI...
The machine leak water from inside, and it does not have pressure.
hi,
make sure everything is clean;the inlet screen etc. Take a flashlight and look inside were the hose connects and make sure nothing is inside.To do a simple test;connect the hose,turn on the water,and WITHOUT starting the pressure washer,squeeze the trigger on the gun;you should have a steady stream of water coming out,about the same as a kids water gun;like a super soaker;If not,then your problem is something is restricting the water inlet,or if the washer is old,mineral deposits inside a passage.If it does squirt out pretty good,then your washer is tired,or you used a cleaner that's NOT compatible with pressure washer seals,or maybe the unloader is stuck,and won't allow the washer to build pressure...........If it's getting a good supply of water,the only thing that builds pressure is the seals,and the unloader.Other than that,there is a small passage were the outlet is,and that could be restricted with mineral deposits,but I would take apart the hose and check for debris in the line,to be sure Hope this helps!!
http://www.pressureparts.com/OwnersManualsK1.aspx
Jan 31, 2011 | Karcher PSI Electric Pressure Washer
Does not give a continous high pressure flow cuts in and out
that is sure signal of insufficient water supply!
try easy solution first:
make sure that your mains is fully open, that tap on whihc hose is hook up is fully open and hose is of "decent" diameter to allow sufficient flow.
if above solution do not work then you need to make another, more difficult arrangement:
prepare 20litres pressure tank with inlet connected to mains and outlet by short hose to power washer, fill it with water from mains, keep it under mains pressure and use karcher power washer normaly. this will solve water supply problem. twenty litres will last about 2min, because it is re-filled, under standard pressure therefore it will last about 3min...
third possibility is to stop washing...
if you find my advice helpfull, please do not hesitate to left the comment and vote for me, thanx!
Jul 31, 2010 | Karcher K2.26 Electric Power Washer
How to connect the cold water supply to K 3.65 Jubilee? In the instruction leaflet, figure J, number 1, 2, and 3 I seem unable to connect it. The above is a pressure washer.
Hi all you need is a 3/4 tap fitting from a diy store.
Maybe a hoselock 3/4 male and female fitting that will fit a standard 1/2" hosepipe. If struggling I can send you a link to the fitting on ebay but if you type in karcher tap connector you will see it by the seller vavcandwash.
Feb 14, 2010 | Karcher 1750 psi Electric Pressure Washer
The water in the waser drum will not shut off at super set
It sounds like your pressure switch needs replaced or there is a hole in the hose connecting it to the wash tub. The pressure switch is generally located inside the control portion on top of your washer to the far left of the timer. This pressure switch is what tells the washer where the water level is. If it is not working it may never shut the water fill valve off and start the agitate cycle.
The switch looks like the attached picture
Oct 27, 2009 | Washing Machines
Pressure washer hesitates, does not start. Unable
get someone to keep the trigger pulled while you try to start it , its probably got presure trapped between the trigger and the pump.
alternatively turn off the water to the pump, pull the trigger to release any pressure trapped.
start the engine , allow engine to warm up, increase revs on engine then turn on water, should be ok then. Unless you have a problem with the engine that is!
Jul 21, 2009 | Briggs & Stratton Garden
Washer overflows
Hello docjhon174
Welcome to fizya,
You said, you washer over flows. water valve is ok also checked pressure switch. its ok
Can you send your brand ,model number and the year or age of your washer?
Waiting for this important info!
Huuum
Oct 08, 2008 | Dryers
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
