If you have a wireless router with a wireless network then -
Configure the IP address your wireless
printer, (this is done through the printer's menu settings) make sure it
matches the IP address range on your wireless network, it maybe 192.168.1.***
then configure the wireless printer with a fixed IP address with the same IP
address range but at a higher address eg. 192.168.1.10 so it does not clash
with any other IP addresses.
Next install the printer driver normally.
Then configure the printer Properties.
Click Start - Printers and faxes - right click on the your printer - click
Properties - Port tab - click Add Port - Standard TCP/IP port -
Port Name eg. 192.168.1.10
Printer name eg Network printer
Click OK
Then do a TEST print if it does not work then the IP address is probably
incorrect.
