Question about GE 24 in. Profile PDW9880JSS Built-in Dishwasher
GE PDW 9980 water will not pump out. Hose and disposal are not obstructed. Directions for replacing water pump.
  • 55 Answers
Check the piston and nut in the rear of the was tub, this will cause this issue.
Appliance & Refrigerator Repair
Posted on Mar 23, 2011
Whirpool built-in puddle of water in bottom, food on drain
see this causes and proceed according. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Oct 16, 2012 | Whirlpool Dishwashers
Dishwasher doesn't drain properly
Following a cycle, a small pool of clean water inside the tub is normal. An excessive amount of water means the pump isn't pumping water out properly, the drain hose isn't carrying it to the drain pipe, or the house's drain lines are backed up.
GA_googleFillSlot("HT_Appliances_Dishwashers_Articles_Box_Top_Left_ATF_300x250");
GA_googleCreateDomIframe('google_ads_div_HT_Appliances_Dishwashers_Articles_Box_Top_Left_ATF_300x250' ,'HT_Appliances_Dishwashers_Articles_Box_Top_Left_ATF_300x250');
If dirty water spews from the air gap, the drain line is kinked or clogged. (If you've recently installed a garbage disposer, be sure the knockout plug for the dishwasher was removed when the connection was made; see your disposer instructions.)
1) Remove the cover from the air gap at the top of the sink (usually a short chrome domed cylinder that sits at the back of the sink), and, using a stiff wire, clean it out. Also check the entire length of the drain hose for kinks or blockages, especially at the drain connection to the disposer or drain line.2) Once the dishwasher is cool, shut off the power to it, and-if your dishwasher is made to allow this-remove the strainer, located under the bottom spray arm at the base of the cabinet (see illustration). dishwasher_er1.gifUnscrew the hubcap, lift the spray arm off, and remove any clips that hold the strainer to get it out. Scrub it clean with a brush, then replace it.
3) Determine whether the sink trap or house drain line is clogged.
4) If the dishwasher still doesn't drain properly, the drain hose may be clogged or the drain valve may need replacement. You can check the drain hose for obstructions, but this sometimes involves pulling the dishwasher out from under your counter to access the hose, disconnecting the hose at both ends, and flushing it out with a faucet or garden hose or replacing it with a new hose.
Thanks for using fixya.
Nov 02, 2010 | GE 24 in. GSD4320Z Built-in Dishwasher
Water in the bottom and not working
Check for a clogged drain (e.g.: via drain hose), or a water pump malfunction due to foreign obstruction (e.g.: glass, etc).
Note: If you changed a food waste disposer (kitchen sink area) and did not remove "plug" from disposer for dishwasher drain hose (assuming dishwasher drain hose connected to food waste disposer), then water cannot drain from dishwasher.
Apr 14, 2010 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
I have standing water, what do I do?
you can use a wet dry shop vac and attach it to the end of the drian hose to remove the water.
Disconnect the hose from the garbage disposal and attach the shop vac to it this will remove all the water.
once the water is removed check the drain pump for any obstructions
Mar 09, 2010 | GE 24 in. Profile PDW7800 Built-in...
I have a GE mokel PDW 7300 dishwasher. I recently
Hello. Disconnect the dishwasher drain hose from the disposal and look into the disposal tube where you will see a plastic plug that you will need to knock out with a screwdriver and a hammer. Regards, J.
PS kindly rate my answer. Thank you. Joe
Feb 07, 2010 | Dishwashers
Water left in bottom of ge evolution dishwasher.
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 08, 2009 | GE Dishwashers
It is not draining, but the drain hose apprears unobstructed.
If your are attached to a disposal under your sink verify that the port is clear. Also the air vent above the sink may be clogged. If this is not the issue the pump may be obstructed with debris. If this is not the case the pump may be bad. If the water is in the bottom of the dishwasher press the cancel button for the cycle and see if the pump activates and drains.
Aug 05, 2009 | GE Nautilus 24" Built-in Dishwasher
GE Model gsd5330d00ww will not drain. There are no drain obstructions and I have replaced the piston gasket in the rear of the tub. What is my next step in figuring out the problem?
HI. check the following areas for fualts.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer/control
Replace if defective (note: uncommon problem).
Jul 30, 2009 | Dishwashers
GE DISWASHER - PDW7300J00WW- WATER STANDING IN BASE OF UNIT - WATER DOESN'T DRAIN. CHECKED HOSE TO DISPOSAL AND TO UNIT IT IS FREE OF OBSTRUCTIONS? wHAT NEXT?
Check the following to address this issue--
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Jun 03, 2009 | GE 24 in. Profile PDW7800 Built-in...
Dishwasher
Check the drain hose and sink drains for obstructions. Check your disposal make sure it is clear if you have one. If drain lines are clear, then you may have an obstructioin in your pump. clear obstruction and it should work properly. If no obstructions are found check voltage going to pump during pump out. If you have voltage to the pump and the water is not pumping out, you will need a new pump. Good luck and I hope this helps you.
Mike Anderson
May 08, 2008 | GE 24 in. GSD5110 Built-in Dishwasher
GE 24 in. Profile PDW9880JSS Built-in Dishwasher Logo
179 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
