Question about Logitech Harmony 550 Remote Control
I replaced the batteries and now the activities button is lit up but nothing else.
  • 23 Answers
HI cHECK IF THE REMOTE IS SOILED OF ANYKIND OF LIQUID IS PRESENT INSIDE THE REMOTE
cLEAN THE WATER OR ANY OTHER THING AND REPLACE THE BATTERIES
THANK YOU
Posted on Mar 22, 2011
My daughter has a 2008 Sentra; tire inflation light was lit despite tires all properly inflated. She tried to reset computer by disconnecting battery cables.Now car won't start; nothing happens when s
Now you learned about removing battery cables,
for no reason
Look in your owners manual for the next step you take
After that --you will need to call a dealer or repair shop
& have them look up what --you needed to know
before you ever remove a battery cable
Aug 27, 2014 | 2008 Nissan Sentra
The digitech vocalist live 2 ,the left side button(reverb,enhancer) , activates the right side (harmony) LED's on the circuit board itself are lit up and nothing happens. t
The buttons are probably scanned as a matrix and possibly a circuit board has been cracked causing wrong data to go to the microprocessor in it. It is unlikely this will be a DIY fix so you should contact Digitech for a repair facility.
Jun 21, 2012 | DIGITECH VOCALIST LIVE 2
Samsung CXM1374 TV/VCR COMBO. The original rmote no longer functions. Changed batteries but still no functions work. Does remote or TV buttons have to be activated to reprogram?
you need to open the cover of your remote control..visually inspect the PCB for any loose connections/cracked board specially the battery terminals...solder any loose connections and if nothing happens replace the crystal oscillator from the remote control it is a square,color orange sometimes blue with a label on it its clock speed in MHZ. it is available at electronics supply store..you can use the camera of your cellphone to test whether the remote is working by just pointing the camera to the LED at the top of your remote once you press a button from the remote the LED should lit...means your emote is working...3rd test the LED/infra red if it is not busted..remove the LED INFRA RED from the pcb and using a multitester analog supply.set the tester to X1 range then supply the terminals positive negative with the test probe there should be a continuity connection and the LED should be lit.
May 20, 2010 | Televison & Video
It has locked up and will not do anything
Hi. I would try reapplying the firmware onto the remote in safe mode. That is the equivilent of resetting the remote. Here's how to do it:
1. Remove the battery, press and hold the 'OFF' button, and re-insert the battery. The screen will display 'Safe Mode!', or the 'Activities' button will be lit.
2. Launch the Harmony Remote Software, and log in.
3. Click "Downloads" at the top and click "Firmware".
4. Select "Yes", and click NEXT to update the remote.
May 09, 2010 | Logitech Harmony One Advanced Universal...
I CANT'T SEE THA ACTIVITIES ON THE SCREEN
Hi. Try doing the following
2. Connect your remote to the computer.
3. Launch the Harmony Remote Software, and log in.
4. Click "Downloads" at the top and click "Firmware".
5. The remote will go through the firmware update.
6. Select "Yes", and click NEXT to update the remote.
Nov 26, 2009 | Logitech Harmony 890 LCD Remote Control
Advent 7094swf turned off and never turn on again
i would say the hard drive needs replacing
Oct 15, 2009 | Advent Netbook
My laptop (Compaq Presario v2000) won't seem to boot up
Remove the battery. Plug power cord in. Turn on machine. Does it boot? Replace battery.
gurutim
Mar 17, 2009 | HP Compaq Presario V2000 Notebook
INDESIT DW S 60
check and make sure the door switch is activating
Jan 03, 2008 | Indesit 23 in. DV62 IX Built-in Dishwasher
Logitech Harmony 550 Remote Control Logo
47 people viewed this question
Top Logitech Televison & Video Experts
Greg Ulan
syspro
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
