Question about Microsoft Windows XP Professional
Regarding Excel formulas
Can I enter a particular text in cell linked through a number? i.e. my cell B1 should contain "lemon" if I enter 1 in cell A1, "mango" if enter 2 in cell A1 and other such texts linked with particular numbers.
    Problem Solver:
  • 5 Answers
You can give the formula by the lookup function
at first make the lists in an another sheet e.g. in sheet2 write the following entries for reference :
a1 b1
1 lemon
2 mango
3 papaya
4 pear
5 orange
6 apple
7 banana
then in sheet1 write the following formula in cell b1
=LOOKUP(A1,Sheet2!A1:B7)
then enter the num upto the limit of lists.
the cell b1 will take values from the reference cell of sheet2
your problem must will be solve.
Posted on Aug 08, 2008
  • 10,594 Answers
Yes, its possible by designing a formula in excel.
Posted on Aug 03, 2008
How to do excel defined name formulas in microsoft excel 2007
Excel formulas really haven't changed at all, so any information you find on newer version of Excel will most likely apply to 2007.
However, to answer your question, let's look at the following scenario:
If A1 and B1 both have numbers and you want the cell C1 to be the result of adding A1 and B1, select the cell C1 and type "=SUM(A1:B1)" (without the quotation marks)
You can also do this by just typing "=SUM(" in C1 and then click and hold your mouse button on A1 and select B1 as well. Then close the parenthesis and press Enter. Done!
Hope this helps.
May 17, 2014 | Computers & Internet
Need to take create a formula that takes a cell
Hi sug04
These are couple of solutions
First. Solution
  • Take away 20% means the answer is 80%
  • 20% means 0.2 of a number, 80% means 0.8 of a number
  • So If you have 200 in Cell B1
  • And you want 20% less in B2
  • Goto B1 type 200
  • Goto B2 type like this =B1*.8 and press ENTER
  • Now Cell B2 displays 160 which is the correct answer
Second Solution
  • Goto B1 type 200
  • Goto B2 type like this =B1-(B1*.2) and press ENTER
Good luck, have a nice day
Please give a Rating to this solution
luciana44
Sep 17, 2009 | Microsoft Excel for PC
Text within an IF formula
Use this formula in B1: =CHOOSE(A1,"GOOD","FAIR","BAD")
With this you must have 1, 2, or 3 in A1 or you will get a #VALUE error in B1.
May 20, 2009 | Microsoft EXCEL 2004 for Mac
Finding the right formula
Assumption:
  1. we work on sheet1, cell b1 as description of material and cell e1 as quantity figure.
  2. we will put the transfer the text in cell b1 to sheet2 cell a1 if you have entered some value in sheet1 cell e1. Otherwise sheet2 cell a1 will left empty or display some text as "NONE" or as you wish.
what you should do is make a formula in sheet2 cell a1 like this:
=IF(Sheet1!e1<>"",Sheet1!b1,"")
The formula will check sheet1 cell e1, if there is any number or text put in there, the value of Sheet1 cell b1 will be copied to sheet2 cell a1. If you don't supply any number or text in sheet1 cell e1, there's nothing will appeared in sheet2 cell a1.
If you want some text will display when there's no value in sheet1 cell e1 just change the formula like this:
=IF(Sheet1!e1<>"",Sheet1!b1,"NONE")
You can modify it as your like. Just copy the formula to another row in sheet2 column a.
P.S.: If this information was helpful, please rate this solution.
1ak+f4pj7cbm32cuniyi2gaaaaaelftksuqmcc
Mar 12, 2009 | Microsoft Windows Vista Home Basic for PC
EXCEL FORMULA NOT WORKING
No tmaking promises but try pushing F9 and for future make sure the Automatic caluculation is turned on.
Nov 26, 2008 | Microsoft Excel for PC
BASIC EXCEL FORMULA
Are you looking to solve any particular problem?--- because there are a huge number of possible formulas in Excel.
However, in my opinion, the most commonly needed ones are addition, subtraction, division, multiplication, and summing.
Suppose you have the following numbers typed into your Excel spreadsheet:
columns: A B C D
rows
1 20 3
2 10 4
3 15 2
4 1 2 3
Then suppose you type in the following formulas (in the D column):
columns: A B C D
rows
1 20 3 =A1+B1
2 10 4 =A2-B2
3 15 2 =A3*B2
4 1 2 3 =sum(A4:C4)
Then the following answers will appear in the D column:
columns: A B C D
rows
1 20 3 23
2 10 4 6
3 15 2 30
4 1 2 3 6
Sep 29, 2008 | Microsoft Computers & Internet
Computer
Any formula in Excel starts with the equals sign ("="). This is how Excel distinguishes between formulas and literal values. Knowing this, you can create lots of formulas using the usual operators of +, -, * and / for addition, subtraction, multiplication and division, respectively. Please see the examples below.
Add 1 + 1: =1+1
Add the contents of cell A1 to the contents of cell B1: =A1+B1
Subtract 2 - 1: =2-1
Add the contents of cell A1 from the contents of cell B1: =B1-A1
Multiply 1 times 2: =1*2
Multiply the contents of cell A1 times the contents of cell B1: =A1*B1
I hope this resolves the question. If not, please let me know.
Aug 08, 2008 | Microsoft Computers & Internet
EXCEL FORMULA SOLUTATION FOR
hm I dont think that is possible with a formula. I think you need to use Macro.
Jul 18, 2008 | Microsoft Computers & Internet
Data validation in excel
instead of validation use conditional formating (under format menu). If c1<1 format cell as red. It does not have the attention getter that validation does not require the active cell event. Every other option requires the cell become active for a test.
Apr 13, 2008 | Computers & Internet
Land measuring
Just follow the steps....
  1. Type "Enter Land in Gundas" in A1
  2. Type "Equivalent Land in Acres" A2
  3. Type "=B1/40"
  4. Now type the number of gundas in B1 example 100
  5. you will automatically get 2.5 in B2
Now you need only two decimals tighy?
  1. Select B2 Cell
  2. Right Click and goto Format Cell
  3. Goto Number
  4. Under Number select Number Catogory
  5. and then select 2 decimals
Thats all
Jan 31, 2008 | Computers & Internet
Microsoft Windows XP Professional Logo
132 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
