Question about Samsung HLP6163W 61" Rear Projection HDTV-Ready Television
I use attached the pc on tv but i didi not here any sound please tell me sound pin cable attached the tv?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • Samsung Expert
  • 177 Answers
Hi sahazada pak,
As i know, TV set not support sound from PC input.
If you want here sound and still working with PC, you should use HDMI or DVI input from your PC out. HDMI has support image and sound in one cable. DVI only image without sound. if you use DVI , sound pc should connected to audio in.
Good luck.
Posted on Mar 22, 2011
Can I attach a HDMI cable to an Old Samsung TV Model # HLN5065W1X/XAA
Gina, these are all the inputs on your TV
S-Video 4-pin DIN (2 sets) Back Composite RCA (2 sets) Back Component 3 RCAs Back Component (HDTV) 3 RCAs (2 sets) Back RGB 15-Pin Dsub Back Tuner Co-ax (2 sets) Back DVI Digital Input 24 pin DVI Back S-Video 4-pin DIN Front Composite RCA Front
You can not use HDMI cable with this set up.
Feb 22, 2016 | Samsung Televison & Video
No Sound from Fisher Box TV
I think your problem is with the scart socket . It most likely to be a dry joint on the pin where the sound goes in to the tv. you have to take back cover off the tv and turn the chassis over to do the dry joints if you can do it yourself otherwise get an engineer to do it. Good luck.
Aug 24, 2014 | Fisher Televison & Video
Dear Sir, We have Toshiba REGZA 24PB1E LCD TV. I want to test our Gigabyte PC GA-G41M-Combo MB with VGA port (15 Pin Connector) Pls let us know how to connect & get the solution ASAP. For...
Hello
With either the PC IN or HDMI connection, you can watch
your computer's display on the TV and hear the sound from the
TV's speakers.
When connecting a PC to the PC IN terminal on the TV, use an
analog RGB (15-pin) computer cable and a PC audio cable.
To use a PC, set the monitor output resolution on the PC
before connecting it to the TV. The following signals can be
displayed:
Format Resolution V. Frequency
VGA 640 × 480 60Hz
SVGA 800 × 600 60Hz
XGA 1024 × 768 60Hz
Other formats or non-standard signals will not be displayed
correctly.
Note:
The PC audio input terminals on the TV are shared with the
HDMI-1 analog audio input terminals
Some PC models cannot be connected to this TV.
OK.
Mar 24, 2011 | Toshiba REGZA 47HL167 TV
Can someone please tell me how to connect my logitech z5500 to my lg 42ld460-ta LCD television to get the optimal sound value from the surround sound system? Thanks very much!
Your LG TV has an audio out socket at the back . Your Logitech has a cable with a green pin (headphone type) which normally goes into the PC's sound out. The same pin can be connected to the TV's out. Now if your TV has a digital out at the back, get yourself an optic fiber cable ( make sure its long enough to reach the Logitech ) and connect it to the z5500 for the best in sound !!.
Mar 09, 2011 | Audio Players & Recorders
Please help. Hooked up Toshiba Satellite to l40fhd41 RCA using VGA cord and video shows up on PC channel of TV. My problem is the sound. Trying to get sound to TV using earphone port on Laptop with...
If you look real close at the VGA port on the TV, you will see a small mini phone jack 'AUDIO' that is for attaching the audio cable with mini stereo phone plug at both ends, one end is to the TV PC audio input jack, another end goes to the PC AUDIO line out or headphone out.
Dec 31, 2010 | RCA L40FHD41 40. in HDTV
No audio when connecting Aspire 5315-2326 to TV.
Use a cable out of the headphone jack with an adapter to the red and white (left and right) audio jacks of your TV.
May 16, 2010 | Acer Aspire 5315 15.4-inch Notebook PC
I HAVE TRIED VARIOUS CABLE TO CONNECT MY ACER
Pls try a S-Video to S-Video cable. Power on TV, then PC.
pls send us your feedback if the above helps. Thanks!
Mar 05, 2010 | Acer Aspire 5520-5908 Notebook
I cant get a picture in my bedroom got a tv and didi box, i am in shared accomadation but wen i take tv downstairs it works on the outside ariel and also so does the didi box am at wits end please can some...
have you tried an active booster/amplifier, indoor aerials are very bad on digital signals. the best way is to fit a booster in the loft and run a new cable into the room, but it may be difficult in shared accommodation, do it when every one is out :) hope this helps.
Feb 13, 2010 | Gateway AR-230 DVD Recorder
How to use a samsung 2494sw as a tv
If you have a 15 Pin D connector on the TV set top box then you can connect the monitor with the help of a cable but for sound you would have to use the another cable as you do on a PC. There you have a separate line for sound. Unless it is a silent movie like the real old times.
Dec 09, 2009 | Lands Phones
No Sound on TV/SAT setting on Receiver.
Most TV has Audio Out RCA jack at rear and it gives same TV Sound as coming from its speakers.
Hook audio wire red white RCA pins at TV Out and plug these pins to TV/SAT input of receiver. Select TV/SAT input in receiver to get TV program sound coming out from TV.
Hope that info will help you.
Sep 15, 2009 | Pioneer VSX-D509S Receiver
Samsung HLP6163W 61" Rear Projection HDTV-Ready Television Logo
82 people viewed this question
Henry  Thomas
Henry Thomas
