Question about Kenmore Kitchen Ranges
Can't start thye self cleaning function on my kemore gas oven
  • Kenmore Master
  • 43,501 Answers
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Posted on Mar 22, 2011
I used the self cleaner the other day and now my maytag gas oven will not start
the problem with the self clean feature is the oven gets up to 1000 degrees,this can and will over time damage the electronics in the oven,usually it takes out the clock assy. this is where all the oven functions are that control the oven,most likely this is what got damaged,after all the things i've seen working on ovens i will never self clean an oven,i use easy off,if you do use the self clean don't use it near holidays or any family functions,if you take out the clock assy. the day before say thanksgiving and the clock has to be ordered you won't be cooking for that day.next time send the full model number off of stove,usually you open the bottom draw under the oven door,look on the left side or right and you'll see a tag on the frame with model and serial numbers,you need the model number to order parts.good luck with your stove you can go here put your model number in to look up parts
https://www.searspartsdirect.com/model/search.html?q=DGRSC
Jan 20, 2018 | Maytag Kitchen Ranges
I have no manual. When i hit clean nothing happens. Help. A little hesitant because of gas
This is the manual for a Whirlpool oven, Page 14 has the self clean instructions. Your unit may have a manual latch that initially locks the oven door close and as the clean process starts a second lock is activated preventing the door from being opened.
https://www.whirlpool.com/digitalassets/MLPDF/Use%20and%20Care%20Guide%20-%208522776.pdf
The second link is an article that describes pros and cons of using the self clean cycle. My experience has been on three occasions that repairs have been necessary after the self clean process so I do not recommend using it.
Why You Should Almost Never Use Your Oven Self Cleaning Function
For more information we needed the specific model and manufacture.
Jan 09, 2016 | Kitchen Ranges
Door locked after self clean
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
May 12, 2010 | KitchenAid KGSS907SSS Gas Kitchen Range
HOW TO USE THE SELF CLEAN FUNCTION ON A KENMORE FREE STANDING GAS STOVE
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
heatman101
Apr 23, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Trying to get gas self clean/oven to start. Getting error E1 F5.
E1 F5 is bad door lock assembly. Only way to repair is to replace the locking assembly completly. Sorry. Hope this helps.
Mar 06, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Kenmore Gas Range
Hey Alan- 'Self clean' sells. Techs call this function 'self- destruct'. Depending on age and number of previous 'clean' cycles, the control may have developed errors, or lockout switches may not function. If inside is thoroughly scraped, and bottom pan checked, removed, and cleaned if necessary, oven should work fine. Preventitive drip pans and a lot of aluminum foil keep the 'Self Clean' Gremlins away. Hope this helps- Thanks- ED
Feb 25, 2010 | Kenmore 73053 Gas Kitchen Range
How do I clean my amana gas self cleaning oven
I have an Amana self-cleaning oven, Model AGR5715QDQ. I can't find my manual - how do I start the process of cleaning? Elizabeth
Nov 22, 2009 | Amana AGDS902 Gas Kitchen Range
I have no users' manual and would like the basic instruction for the self-cleaning function
The only thing I can offer is this: Most electronics cannot recover from the extreme 900 degree temp of self clean cycle. It is therefore recommended not to use the self clean on newer models. Why not get some oven cleaner and do it the old fashioned way?
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 14, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Self-cleaning gas oven
Door lock motor has probably failed.....Self clean on many
ovens can be a self destruct mode. Door latch motors, sensor
probes and even the electronic controls can be destroyed by
this operation. On many freestanding stoves the lock motor is located in the right rear (looking from the front) with a long rod connected to the lock. remove the motor and unhook the rod from the motor cam. Sometimes bending a coat hangar into a hook and sliding from the right side into the lock you can unlock the door.
Jun 02, 2008 | Frigidaire Ovens
After self cleaning, Range trips circuit breaker when using convection
self cleaning ovens use super hot seting to bake the oven clean and it sounds like it melted a wire and it is shorting out the oven on that setting. look at the wires you can see or easy to remove panels
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Dec 22, 2006 | GE Profile JGS968 Gas Kitchen Range
Kitchen Ranges Logo
60 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
