I have a Texet Fx 1500 calculator and answers i get are all rounded up to a whole number. I cant get the answers with decimal points...Eg When i press 8/9 the calculator gives the answer '1'...But on the screen it says RAD and STAT...What are those? How do I reset to normal mode?
SOURCE: Sharp ELSIMATE EL-240SA - how do you stop this
From the manual:
SETTING THE NUMBER OF DECIMAL DIGITS
Numbers of decimal digits of calculation results can be specified by pressing [C-CE] twice, then press [C-CE]and [M+] simultaneously.
The decimal digit assignment will appear as “F” (for “floating point”), “2” or “0” on the LCD. (The default is “F”.)
Press and hold [C-CE] and [M+] until the symbol changes.
Posted on Sep 29, 2009
SOURCE: I am trying to get
You should press SHIFT then MODE (setup). Then press 2. Done! If you want to change it back, just do the same again, but press 1.
Posted on Sep 01, 2008
  • 4 Answers
SOURCE: Any way to make decimal answers the default? (casio fx-83ES)
you want a line output
Shift > Mode > 2:LineIO or on the graphics one its sometimes 10:LineO etc.
look for something with line in it
Steve :P
Posted on Aug 28, 2009
  • 102366 Answers
SOURCE: Convert to/from Decimal/Binary
Press MODE 4 to enter the BASE-N mode. If the display doesn't say Dec, press SHIFT DEC (the x^2 key) to set base 10. Enter the number to convert. Press SHIFT BIN (the log key) to switch to base 2.
Each time you switch the base the current value is redisplayed in that new base.
Posted on Aug 04, 2010
SOURCE: change decimal placement on calculator
pressing the tab button displays the number of decimal places 0, 2, 3, 4, A, F on the bottom of the screen.
Posted on Aug 06, 2010
I don't know if maybe my calculator has a function turned on that rounds the answer to a whole number? But here is an example: 106 x 6.32 = 670 according to my calculator, which is wrong. The real answer...
Your calculator is set to display no digits after the decimal point. To change this, you have two options: press 2nd [SCI/ENG] then select "FLO" for floating decimal or press 2nd [FIX] then select the desired number of digits after the decimal point (or F for floating).
Feb 14, 2014 | Texas Instruments TI 30XIIS Scientific...
Changing from x10^-3 to decimal
Two alternatives:
Press SHIFT MODE 6 then a digit greater than 2 to specify the desired number of digits to the right of the decimal point. For example, of you select 3 the number will be displayed rounded off to 0.004 .
Press SHIFT MODE 9 2 to select the NORM2 mode.
Be aware that in any mode if the magnitude of the number drops below 10^-9 then the calculator will automatically switch to scientific mode. The calculator can't display more than nine digits after the decimal point---the display just isn't big enough.
May 17, 2013 | Casio FX-115ES Scientific Calculator
Texet fx 1500. i press pi key. instead of 3.14 gives me the answer 3. why
Do you have the display set to give you any digits after the decimal point? What do you get when you multiply pi by 100: 300 or 314?
Mar 19, 2013 | Office Equipment & Supplies
Casio FX-115ES Scientific Calculator How can I get more of an answer...my answer automatically rounds to 3 decimals but I need to see more of the answer??
Change the display mode. Press SHIFT MODE 6 then the number of desired digits after the decimal point. Alternatively, press SHIFT MODE 8 and select one of the "Norm" modes.
This is all in the "Specifying the Number of Display Digits" section on page E-8 of the manual.
Sep 28, 2011 | Casio FX-115ES Scientific Calculator
Is their away to round whole number on a ti30 calculator
To do this you need to set your calculator to a fixed decimal value. You can do this by Pressing 2nd + FIX (decimal point) and then setting it to 0 decimal places. This will round a number to the nearest whole number.
Hope that helps.
Apr 22, 2011 | Texas Instruments TI-30XA Calculator
I cant get a anser it comes out in scientific notation
Press [SHIFT][MODE] to enter the (SETUP) screen, then select the number to the left of FIX. Once you do you will be prompted to enter a number between 0 and 9. If you enter 4 all your decimal results will have 4 decimal digits. If you choose 0, all decimal numbers will be rounded to the nearest integer (whole number).
Regardless of the floating display mode (SCI, FIX or NORM) the calculator is configured for, the decimal results will be in SCIENTIFIC format if they are too small or too large.
May 21, 2010 | Casio fx-300ES Calculator
Fx-300ES Calculator: i cant get a anser it comes out in scientific nota...
May 18, 2010 | Casio fx-300ES Calculator
Everytime I put decimals into my calculator, it just rounds the answer to the nearest whole number.
Increase the number of decimal digits in display.
  1. Press [SHIFT][MODE] to access the {SETUP)
  2. Enter the number (6) corresponding to option [6:FIX]
  3. In screen that is displyaed, enter the number of decimal digits you want (2, 3, or 4). If you enter 0, all decimal numbers will be displayed as integers (rounded). If you enter 9, you will have long numbers but that is hardly ever necessary.
Feb 21, 2010 | Casio FX-115ES Scientific Calculator
How to round up to 2 decimal places?
can you tell me the answer to this question
round 618 to two decimal places
Sep 19, 2009 | Casio FX-115MS Plus Calculator
381 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
