Question about Olympus FE-170 Digital Camera
In my Olympus digital camera, when I switch on my camera, it will show change the battery. I have changed the battery inserted new battery, even then, it will show like that only. Hence, pl guide what I have to do. Which capacity of Rechargable Cell I have to use. Pl advise me correctly to below mentioned email ID Regards. ram
    Scholar:
  • 96 Answers
The best type of battery to use for cameras is the NiMH (Nickel-metal-hydride) rechargeable type. U'll get all kinds of problems if you use the types you use for toys and things like that.
What I recommend to you is go to a studio/cam shop and ask for two AA sized NiMH batteries (I have checked ur cams' stats). they'll have only what's good for cameras (there're cheap NiMHs in the electronics market but those aren't good for cams)
Any NiMH batt. of the appropriate size will work on your cam, they will only differ in the number of hours ur cam can run on them.
Extra: There's an "mAh" rating (milliampere hours) written on batteries. This only decides how long ur cam will run. The power rating of ur cam is written somewhere on the cam (eg- 3.0---2.0A for my cam)
to estimate how long ur cam will run on ur batteries:
  • Multiply the average of that 'A' value by 1000 (A= Amperes. one Amp= 1000mA)
  • Then divide the battery's mAh rating by the answer of above. the value you get is approximately the time in hours you can run your camera on those batteries
Posted on Mar 22, 2011
Will not switch on with new batteries
I wonder what batteries you use? The best would be two AA rechargeable NiMH batteries. But a new CR-V3 lithium battery should work also.
When you have rechargeable batteries, you should check if they are charged. And when inserting, check if you did out them in correct. Only the CR-V3 is protected for inserting it wrong. when you have two batteries, you can put them in the wrong way. Then, if you did not use the camera for a long time, please make sure all contacts in the battery compartment are clean and shiny. If not, try to clean them, with a clean cloth. Never use anything sharp in or close to a camera. Contacts, could be rubbed with a little electronic contact oil, but the oil must be removed afterwards. As strange as it may sound, even the contact oil can be cause of oxidation on contacts.
When the batteries are in, make sure the battery door is correctly closed.
If you checked everything and you are sure the batteries are in correct, just try switching on and of several times, by opening and closing the lens barrier. Also while the lens barrios is closed, press the play back button on the back side of the camera. If both don't work, then again the batteries are under suspicion.
Feb 14, 2014 | Olympus Camedia C-150 Digital Camera
BATTERY SHOWS EMPTY WHEN TRY TO TAKE PICTURE
if its internal and have to charge it with a charger then you need to change the battery. i would recommend taking it to a camera shop and having it evaluated its well worth the evaluation trust me it might be something simple as just getting a new battery to a loose connection inside. Worse case you might have a bad indicator that needsto be fixed.
Sep 22, 2009 | Olympus Camedia D-540 Zoom Digital Camera
FE-160 won't switch off
Try removing the battery, let it stand for 1 hour (it should reset itself), insert the battery and configure your camera again.
AND/OR
Have a look at your manual and or the Olympic WEB site to see how to reset your camera.
Nov 12, 2008 | Olympus Camedia C-160 Digital Camera
Number of pictures
in the menu, change the all reset to off
Aug 14, 2008 | Olympus SP-350 Digital Camera
Olympus FE310 Series, Battery Problem
Hi, I have had the same problem with the battery not working.  I have changed batteries several times, with no change.  I bought the camera when I was pregnant so I could have a camera in my bag to take spontaneous photos of my baby but was disappointed at the birth and ever since because the battery is not dependable! I took it into the shop and was informed there could be a $90 charge if there is no mechanical problems... :-((
Jul 31, 2008 | Olympus Camedia Stylus 300 Digital Camera
Olympus c-160 battery problem
Check your user manual to see exactly what type of batteries you can use. Not all AA batteries will work in all digital cameras. Some require a specific brand of batteries or specific number, even though, they may be physically the same size. Hope this helps :)
May 16, 2008 | Olympus Camedia C-160 Digital Camera
Have battery problem
Hi: My son purchased a new digital Kodak for me since the olympus was no longer under warranty and the money I would have spent on tech assistance;and not knowing if the unit was repairable---just getting a new camera made more (dollar)sense.
May 06, 2008 | Olympus Camedia D-425 / C-170 Digital...
Olympus FE-170 Digital Camera Logo
61 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
