Question about Cameras
Does kodak zm1 record in pal or ntsc - Cameras
  • 262 Answers
It's neither, really, it's 640 x 480 @ 30 frames per second. The assumption these days is that you're going to keep your movies on your computer and play them there. However, if you're considering converting your movies to a DVD, or some other format that uses PAL or NTSC, then your answer will be "NTSC" because the conversion from ZM1 to NTSC will be painless, whereas the conversion from ZM1 to PAL will lose one out of 6 frames, resulting in very slightly stuttered motion.
Posted on Mar 22, 2011
Honestech tvr video recorder
The Color subcarrier is different on pal. NTSC tapes , cameras, VCR's will all show B/W on a NTSC TV.
May 09, 2013 | Fulltone Ruby GrabBee Deluxe USB 20 NTSC...
Vertical addjustment for a DVD recorder
It should be inbuilt to switch on the vetical adjusment! or else you have to find another! 1
Dec 08, 2007 | Samsung DVDR120 DVD Recorder
I have converted some NTSC vhs to PAL dvd, when i play them on my LG DVD player, it says disc error
U must copy NTSC to NTSC.PAL to PAL.Check ur DVD recorder/VCR combo menu set up regions auto, if it have it.Will play all regions DVD discs.
Mar 26, 2010 | LG RC897T DVD Recorder/VCR Combo
Hy does a colored tv record in black and white on
I suspect that you have the video standard is incorrect. Ensure you are recording in the same format as the signal you recieve. IE: NTSC or PAL. Whatever but they should both be the same. IE: Signal recieved = NTSC Video recorder must be set NTSC as well. Same goes for PAL.
Jan 13, 2010 | Quasar VV-2002 20 in. TV/VCR Combo
How to switch from pal to ntsc
Camcorders have only one color system to record accordingly, either PAL or NTSC
Sony DCR-HC36 is NTSC camcorder and DCR-HC36E would be PAL camcorder.
Hope this info will help you.
Thanks.
Nov 28, 2009 | Sony Handycam DCR-HC36 Mini DV Digital...
Won't record, and is not in colour
Make sure to check PAL / NTSC settings if your Display is NTSC and your trying to use PAL your image will appear Black and White.
Apr 26, 2009 | Computers & Internet
Converting NTSC home Video tapes to Pal DVD or NTSC DVD
You need either an NTSC DVD recorder (keep in mind that the US has 110 voltage, while Australia does not), or a computer card that supports NTSC. Some video capture cards support both NTSC and PAL (often switchable). Choose good quality, and pay attention to video/sound sync - some bad quality cards loose sync. Once the tapes are transferred to DVD - and keep it native NTSC all the way, they can be played on virtually any PAL DVD player/TV combo. With an NTSC source, it's best NOT to convert to PAL, while with a PAL source in the US, you'd need to convert to NTSC or only show the DVD on a computer (where NTSC/PAL doesn't matter).
Feb 19, 2009 | Panasonic DMR-ES35VS
When I try to play PAL tapes, there is no picture
You also need a PAL television or monitor to be able to view them. If you don't have a PAL compatible monitor or TV it will not work because the resolution and scanning is very different than an NTSC monitor. Your canon camera is probably designed only for NTSC use if it was sold in North America and can't be used for PAL use.
Jul 31, 2008 | Sony DSR-11 DV / Mini DV VCR
Pal to NTSC
If you bought a converter it would convert 25 frames a second to 29.97 or 30 frame 625 to 525 NTSC no adjustments and thats been that way for decades. You can rent a sony or Aiwa deck with legal converter on board and do this easy. So go and get a real converter!
Dec 08, 2007 | Televison & Video
Pal to NTSC
Hi, Based on your post/description, you need to get a multi-system TV to go with your multi system VCR if you are going to playback VHS tapes from different regions. You are quite correct "Plays NTSC tapes to NTSC, Will not Play Pal to NTSC" to play PAL (even Secam) you would need a PAL/Secam TV. They have a different system for color and audio. In some cases, you can still play PAL but you get it in black & white and picture squeezed from top & bottom. Hope this be of some help to you. Good luck and kind regards.
Aug 22, 2007 | Samsung SV5000W VHS VCR
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
