I need a replacement areial for my Durabrand DIGITAL radio model LEDAB0701 How can i obtain this please?
  • 2,098 Answers
Hi Peter,
If you are looking for the replacement of telescopic antenna of your unit, click this link http://shop.ebay.com/i.html?_nkw=telescopic+antenna&_sacat=0&_odkw=digital+tv+antenna&_osacat=0&_trksid=p3286.c0.m270.l1313
Hope I helped you. Have a nice day!
Thanks for using Fixya.
Posted on Mar 22, 2011
ASDA durabrand radio model no. LEDAB0701 information bar has stopped working
Hi - As per original question, NOT A TV, the LEDAB0701 is an ASDA Durabrand DAB Radio, so no remote! Just hit this problem - and found a work-around. Sound always worked - display and backlight failed. Could not spring radio apart - as well as the screw in the battery compartment - there seems an anchor the other end that defeated me. I run off the supplied Power supply and rechargeable batteries. The batteries ran down and I plugged the psu and display came back - for a few minutes! The sealed Power Supply unit (psu) is probably unregulated non-switched mode type. It gave 15.6v unloaded. Unregulated psu's normally run 1.4x nominal voltage with no load and are pulled down to the nominal voltage as the load current is taken (i.e. ASDA psu should have been 9v x1.4 =12.6v not 15.6v).
Seems the radio is sensitive to high psu voltage as when I ran off a regulated psu - problem partly went away. Regulated means you get whatever voltage you set whether no load, half load or full rated load.
Also once switched off fault appears the internal batteries were keeping the display off setting. I used a 12v 1A variable regulated psu. It has 9v, 6v, 5v settings. 5v is too low. 6v works when already running but it needs 9v to start. However the problem is that the display will still switch off if I run for a long time on 9v, so I have to switch down to 6v. Alternative, start on battery and plug in 6v works [6xAA=7.2v nominal, range: 8.5v down to 6v]. Seems some internal components of radio or psu have drifted/become faulty.
You need a positive center/hole polarity. Ideally aim at 500mA or greater replacement psu. Ideally use a variable one so it can be used for other things if your problem is different and this is not the solution. If you have an unregulated variable psu (400mA or greater) try running at 6v (will be higher but perhaps not too high) then switch to 4.5v or 5v (again will be 1.4x higher) but make sure it is set to positive centre/hole.
Apr 12, 2014 | Televison & Video
LG DA-3520 manual
my radio will only play AM WONT PLAY FM I HAVE NOT GOT THE AREAL IT CAME WITH TAKEN ONE OF A DIGITAL RADIO DO YOU THINK I WILL NEED A AM FM AREIAL THANKS
Jun 26, 2012 | LG DA-3525 Theater System
Looking for battery replacement for Durabrand DVD player DUR-7
I have Three places in mind Ebay or Best buy and Radio shack and ask them what you need.
and on ebay in the search type in the dvd and go from there
Good luck
Nov 15, 2009 | Durabrand DUR7 Portable DVD Player
AC/DC Adaptor
Greetings jack71471, there are a couple options to obtain a replacement AC adapter for your Durabrand DVD player. One option is to purchase a universal adapter from a store such as Radio Shack. The other option is to buy a dedicated 9 volt AC replacement adapter from a couple sources on eBay. Just do a search for "PDV-709 adapter" and you will find some AC adapters and 12 volt car adapters as well. If you choose the universal replacement option, make sure you bring the player and adapter with you so the salesperson can configure the settings and polarity to match the original adapter. That is unless you are confident enough to set it yourself, in which case you can purchase a universal adapter most anywhere as long as the current rating ( rated in milliamps or "ma") is equal to or greater than the original. Best of luck to you.
Oct 25, 2008 | Durabrand PDV-709
DVD Durabrand
Hi
You can obtain the User's Manual which contains easy instructions and with code list from the link below
http://www.expressfix.net/manuals/remotes/URC-3021
Aug 27, 2008 | One For All URC-3021 Remote Control
HIGH I NEED A NEW POWER CORD FOR OUR DURABRAND PVS223 PLAYER HOW AND WHERE CAN WE GET ONE? GARYT@NPACC.NET OR 1-570-596-4372
Hey handletree,
Since Durabrand is a Wal-Mart exclusive brand, you would most likely need to speak with a sales associate at your local Wal-Mart store to see if the manufacturer ever produced separate replacement parts for their products. With many private label brands, original equipment manufacturer (OEM) replacement parts are unfortunately not always made. If this is the case, you should be able to obtain a universal power cord/adaptor from a third-party specialty retailer, such as Radio Shack.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jul 02, 2008 | Televison & Video
Connection problems with Philips DTR220
There is such a thing as a HD areial, but in this case it sounds like you need to point the antenna in the right direction. If your freeview is digital then there is a diredtion the areial needs to piont, and there is a front and a back to it. You need to find where the signal source is located and point the areial in that direction.
Mar 30, 2008 | Televison & Video
 Grubhead
Grubhead
