Question about Refrigerators
While the freezer compartment cooling is OK the regular area suffers from insufficient cooling. The outer skin of the fridge is warm to the touch. What could be wrong and how to set that right ?
  • Babu Raj
    Babu Raj Mar 22, 2011
    Your Refrigerator Frost free model or old type d-freeze? Outer skin warm no problem. may be frost free controls working not properly.
    Problem Solver:
  • 53 Answers
Outer skin warm not problem. Frost free system working not properly. Timer / heater / fan may be not working properly.
Posted on Mar 22, 2011
Fridge/freezer not cooling
check the door switch ok or not
if the door switch not ok replace it if ok ch the cooling cycle
Mar 16, 2014 | Siemens KG34NA13GB
Refrigerator too warm
If this is a bog-standard fridge... then its the freezer compartment which actually cools the rest of the fridge. Air needs to circulate throughout the fridge... is the freezer compartment full of ice and need defrosting... if so, do not use sharp objects as there is a thermostatic temperature sensor wire in the vicinity of the ice-box.
Mar 06, 2014 | Sanyo Refrigerators
Refrigerator warm freezer too cold
If you have already adjusted the controls for temperatures in both compartments and allowed 12 - 24 hours to stabilize and the trend is continuing, there may be a problem with the fans that move the cold air from the freezer to the fresh food compartment. The fridge may also start allowing temperatures to rise in the freezer soon, too.
All of these problems originate in the freezer compartment, where the cooling is done. Behind the back wall; inside the freezer - lies the cooling coils, defrost heater, circulating fan(s) and defrost terminator sensor. Unplug the fridge. Empty the contents of the freezer, remove the ice maker assembly and the back wall plate and you should see these components. If it looks like a large block of snow and ice, the problem is with the defrost circuit components. If clear with a minimal amount of frost, the warm fridge is the result of blocked or limited airflow from this area to the fresh food compartment - likely a failed circulating fan. Plug the fridge back in and check to see if the fan is running - since the fridge is warm, it should be running. The fan or the thermostat will probably need replacing if it is not.
If icing or frost is the problem, you'll need to isolate and replace one or more of the following: defrost heater, defrost terminator or defrost timer. The last two are the usual suspects for this type of failure - but the heating element can fail too. Many times, the defrost timer is accessible from the front of the fridge, behind the kick plate below the freezer door on the right side. Other times it is located in or near the temperature control area.
Jun 18, 2010 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Our fridge model has the freezer on the bottom. When the fridge door is open, the front of the fridge above the freezer compartment is hot to the touch - also had a one time incident where the...
It is normal for the strip between the freezer and fresh food compartments to be warm to the touch. It's called the mullion strip and uses gas from the compressor discharge line to prevent moisture from forming there. Older models used an electric heater to do the same thing.
As far as the one time operational failure......it's a bit difficult to even guess not knowing the brand and model. Talk to us if it fails again.
Aug 20, 2009 | Refrigerators
Freezer fine / fridge warm
check for defrost element not working ice build up will cause it not to cool fridge,check continuity of element with unit unplugged!!!if continuity ok then check defrost timer!!! :)
Jul 07, 2009 | Refrigerators
Freezer is building up frost and refrigerator is not cold enoough
Almost certainly, you have a leak within the freezer compartment.
The cooling system will use a divertor valve to concentrate coolant to the fridge or freezer compartment - whichever is necessary to maintain selected temperatures.
If a seal within either compartment is compromised and leaks then the coolant will be excessively diverted to that area in an attempt to lower it's temperature - the other section will suffer since more coolant is diverted to the weaker area; the weaker area that is being excessively cooled will also have more moist air circulating, hence moisture will contribute to a build up of ice - exacerbating the problem.
Ensure that both fridge and freezer doors are closing properly, if they appear to be secure then also check that the seals are airtight - there should be no ice accumulating around them.
You might need to re-align the doors, or less likely, replace the door seals.
Please reply if you require further clarification or help.
May 31, 2009 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Westinghouse fridge: no cool air circulating inside
Art, I need to get a little more information from you. Does the condenser fan under the refrigerator seem to work and blowing warm air from below and or behind the refrigerator? The motor feeling warm is OK. Only when too hot to touch on top. Needs to cycle also. When you opened the freezer did you hear the fan blowing? Thanks, JT
Apr 18, 2009 | Westinghouse Refrigerators
I have a Maytag 500ltr fridge freezer model GT1727.The evaporative area behind the rear cover in the freezer compartment freezes solid also the freezer door has ice inside it which then drips water,in turn...
The problem is the ice inside it is clogging the Fridge and it is causing the temperatures to be wrong
take everything out of it unplug it and use a hairdryer to melt off every bit of ice inside and behind the back wall.
Jan 11, 2018 | Refrigerators
Samsung side by side
Check for snow on the back wall of the freezer compartment, Air to cool the refrigerator is supplied from the freezer section. If the coil is frozen over the air circulation becomes retarded and the refrigerator suffers. Snow on the back wall indicates a defrost problem.
May 15, 2008 | Refrigerators
Fridge not working
I've had this happen to my Kenmore 73503 several times. The 1st time took me a few hours to figure out what the problem was.
Basically the fridge is cooled from the freezer, so when you say your freezer is -2 degrees, it's a big tip off to the problem.
If you look very close in the freezer compartment at the back, you'll notice an opening with a little door at the top of the freezer compartment. This opening extends up the inside of the back of the fridge to the top of the fridge area via a square plastic tube.
Basically what happens in my fridge is the family loads the freezer to high especially at the top/back. This restricts or closes off the opening for the cold air to the fridge portion of the appliance ....resulting in a warm fridge, but cold freezer. Just remove the articles at the back of the freezer to correct problem. (It will take a few hours for the cold air to cool the fridge down)
Note: the temperature control unit in the fridge area controls the little door at the top of the freezer compartment, so if you haven't blocked off the opening, the next place to look would be either at the mechanical parts of the little door or the temperature control unit itself in the fridge
Mar 22, 2008 | Kenmore 73503 Stainless Steel Bottom...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
