Question about KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher
Dishes are cloudy, looks like water deposit. Also, the dishes feel like soap is still on the dishes,a grainy feeling substance. also, some dishes were not clean. this is a new kitchenaid dishwasher...
    President:
  • 2,468 Answers
Is your water softener working?if not this will happen
Posted on Mar 22, 2011
  • msnewm Mar 23, 2011
    I do not have a water softner, any other suggestions
Dishwasher not cleaning very well.
Hello do it heat up ok is the water Hot please
Nov 13, 2015 | Siemens Dishwashers
The dishes look clean but there is residue left on cups and cereal bowls. I invariable need to rewash them manually. in addition there's a sandy or grainy deposit in the bottom right by the door which I...
You are using to much liquid soap or you need to buy some speed dry tablets for the drying cycle. Or put a water purifier on your main water line coming into your house. You may have what some people call hard water.
wvrain2006
Sep 29, 2010 | Maytag Dishwashers
I get a film on the inside of dishwasher as well as dishes at the end of a cycle. You can really see the cloudy film on glasses. Dishwasher is only 18 months old.
Cloudy film is usually from hard water. Or it means the dishes arn't drying properly. you wanna make sure your using jet dry and that your not using liquid soap. Liquid soap is a killer of dishwashers and creates mineral deposits. If you have hard water getting a water softener helps too. Theres a cleaning agent called dishwasher magic that works to clean the dishwasher . You wanna make sure your heater is coming on too.
Jun 15, 2010 | Kenmore Dishwashers
Film on dishes
the film on your elemend and dishes is more then likely soap residue.try useing less soap. if this is a new dishwasher it probably uses less water then your older one did so you will need to modify your soap usage. if you have had the dishwasher for a while then your valve is clogged or not opening all the way. check the brass elbow for mineral deposits and replace it and valve if buildup is seen
Apr 24, 2010 | Tappan 18 in. MDR251RE Built-in Dishwasher
CLOUDY DISHES IN DISHWASHER SOMETIMES THE DISHES COME OUT CLOUDY
modern day dishwasher use less water than the older ones so you have to use less soap a lot less only 2 tablespoons but you also have to use rinse aid with the very little soap the cloudy residue on the dishes is left over soap
Apr 04, 2010 | Maytag MDB9600A Jetclean II Built-in...
My dishes come out with cloudy film on them.
From Whirlpool:
*Film is due to either etching or silica film. Silica film is a milky, rainbow-colored deposit and etching is a cloudy film. Sometimes there is a water/chemical reaction with certain types of glassware.
o Silica film and etching are permanent and cannot be removed. Both can occur in any automatic dish washing machine and result from a water/chemical reaction with certain types of glassware. They are caused by some combination of:
+Soft or softened water.
+Alkaline washing solution.
+Insufficient rinsing.
+Dishwasher overloading.
+Heat of drying.
+Long/hot cycles.
To slow the down this process:
*Use a minimum amount of detergent but not less than 1 tablespoon per load.
*Use a liquid rinse aid.
*Under load the dishwasher to allow thorough rinsing.
*Do not use heated drying.
*Wash glasses by hand.
Do the following:
1. do you use a rinse agent
2. clean out the drain.
3. if you have a food disposal, run hot water through it and turn it on to clear it out before you turn on the dishwasher. The dishwasher drains into that sink. If you notice food or dirty water backing up into you sink when the dishwasher is draining, then the sink could have a minor clog and is backing up and being re-sprayed onto your dishes.
Source(s):
Use SANIVAC to clean lime deposits and extend the life of your dishwasher. If you have heavy water.
Run your dishwasher empty and pour in a cup of bleach and a cup of white vinegar to get the residue out.....run a regular cycle.......How hot is your hot water tank set on? The hotter the water the better a dishwasher washes and rinses, be careful it's not to hot as your shower and other sinks also will get this hot water......cut your dish soap down and make sure to use a Jet Rinse Aid. Again, be sure to use a liquid soap, and rinse agent, powders will cause a caustic reaction. Hope this helps. Let me know if there is anything else I can help you with.
JimmyC
Sep 30, 2009 | Bosch Dishwashers
Cloudy dishes
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Sep 22, 2009 | Maytag MDB9100A Dishwasher
Just not cleaning
run a cycle thru with no dishes and 2 cups of vingar this will flush out the unit then run a normal load should be ok let me know THERE also is a product called dishwasher magic you can run that thru as well but the vingar is cheaper
Mar 15, 2008 | Maytag 24 in. MDBH955AW Built-in...
Soap film on dishes
Rodney B if you are sure that the white film is detergent and not hard water deposits, then look at how you are using the detergent. When you watch the TV ads for dw detergents, they are showing baked on/extemely dirty dishes being put in the dishwasher and coming out clean. Well they do this as the dw detergent is designed to break down protein based food products. Fats, oils, and such. If you are prewashing your dishes before putting them in the dishwasher, then there is nothing for the detergent to attack and attach to, so it ends up staying in the dishwasher. If you are going to rinse your dishes, then you need only 1 tablespoon of detergent. Dishwashers are designed to clean using 4 parameters, hot water of 130 degrees, water, detergent,& pressure of the water jets. That is how they clean dishes. Now if this is hard water deposits, switching to an enviromently friendly detergent which is high is Citric Acid (What gives Tang drink its tartness) this will reduce this issue. Hope this helps
Jan 30, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers
What you are likely seeing is the solids from household soap products. Household soap has too many "fillers", and doesn't dissolve fast enough for a 4 minute cycle.
If you look into the bottom of your wash tank, I expect you'll see large tan deposits. Invest in a commercial liquid soap system.
Jan 23, 2008 | Hobart AM14-253 Free-standing Dishwasher
KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Logo
141 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
