Question about Nintendo Wii Console
My wii is not working
Hi there uhm can you please help me to fix my wii. uhm the power light color is orange an it should be green right? hw can i make it green again? hope youll help me thanks... and by the way whats with the wiiconnect24?... thanks and Godbless!!!!
  • 752 Answers
If it's orange that means it is turned off. It turns green when you turn it on. Insert a disc, press the power button or hit eject.
Posted on Aug 05, 2008
I need a copy of the wiring diagram/color code for the colby stereo system in a 90-FORD AEROSTAR
90 Ford Aerostar Colby Stereo System
Wiring color code:
Speaker Power Ground
Left Front Orange/light green Light Blue/white
Right front White/light green Dark green/orange
Right Rear Tan/light green Brown/black
Left Rear Tan/white Tan/yellow
Other Wires:
Yellow/black = Hot - Key On
Light green/yellow = Hot - Direct to Battery
Light blue/Red = Radio lights
Black = Ground
Black/light green = Ground
This is what I found for you,hope it helps. Good luck.
Sep 26, 2010 | Car Audio & Video
Put in a new battery and when I turned it on, it asked for a nickname, then to pick a color, then suddenly the screen got lighter and lighter and now the screens are blank but the green power light is on. ...
Hi, Power light is green or orange - TV screen is blank
If the power light is green or orange and your screen remains blank, follow these steps.
Completely power down your system by pressing the power button for 10 seconds. If that doesn't work, unplug the AC Adapter from the Wii for a moment, then plug it back in.
Make sure your Wii console has the most current Wii system menu. Download the latest update (how to), and then test your Wii console to determine if the problem has been resolved.
If you continue to experience this issue, there is a problem with the Wii console and it will need to be repaired. Please visit the link below
(nintendo.com/consumer/repair/wii_repair_home.jsp?problem=PWRLIGHTOFF)
Have a nice day.
Sep 15, 2010 | Nintendo DS Console
Trying to wire new stereo for my 98 taurus, but wire colors dont match up! where can i find factory stereo wiring schematics
Hello I have included a wire color code for you installation. Hope this helps you out. Please rate and good luck. Israel
Constant12V+ Green/Yellow
Switched 12V+ Yellow/Black
Ground Black/Light Green
Illumination light blue/red
Left Front + Orange/light green
Left fRont - light blue/white
Right Front + white/light green
Right Front - dark green/orange
Left Rear + gray/light blue
Left Rear - Tan/Yellow
Right Rear+ Orange/red
Right Rear - Brown/Pink
Apr 13, 2010 | Car Audio & Video
Error code 300. How fix
Do the EEPROM initialize reset;
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. release RESUME
3. press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 01, 2009 | Office Equipment & Supplies
Had to cut the factory harness
trick of trade... take a 9 volt battery and touch the wires to it.. the speaker will pop and you will know which one is which... do one color at a time
Apr 21, 2009 | 1993 Ford Explorer Limited
2001 Ford E-150, year 2001, wire harness connection
As for the head units leads they should be marked or identified in the installation manual. There are but only three wires here that I might be able to help you with.
Two of the wires should have in-line fuse links (12+ volt power) and they are the constant feed (for memory) and the switched feed (for operation). The ground lead is typically solid black.
This is a general factory radio color code. Wire colors in your car might be different than colors described here. Use the given colors for reference purposes only. Always test wires to make sure they are correct.
Good luck
Aduz
FORD P o w e r Memory (+12v Constant) Green Yellow Ignition (+12v Switched) Yellow/Black Ground (-) Black or Fat Red Illumination Orange Dimmer Orange/White Power Antenna Blue (varies greatly) S p e a k e r s Right Front (+) White/Green Right Front (-) Green/Orange Left Front (+) Orange/Green Left Front (-) Light Blue Right Rear (+) Pink/Blue Right Rear (-) Green/orange Left Rear (+) Pink/green Left Rear (-) Pink/Blue
Mar 28, 2009 | Car Audio & Video
Canon i950 flashing orange green orange green
2. Release RESUME
3. Press RESUME twice, then release POWER
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i950)
Aug 22, 2008 | Canon i950 InkJet Photo Printer
Wiring a new radio in 1991 ford explorer
1991 Ford Explorer XLT Radio and Speaker Wire Colors
Pulled out the stock radio and found two plugs on the back of it. One plug had 7 wires (Power, Dimmer, Amp etc.) and one had 8 (Speakers).
7 wire plug (I could see these wires immediately from the plug):
Car Radio Battery Constant 12v+ wire = Light Green w/ Yellow Stripe
Car Radio Ground Wire = Black
Car Radio Accessory Switched 12v+ wire = Yellow w/ Black Stripe
Car Radio Dimmer Wire = Light Blue w/ Red Stripe
Car Radio Illumination Wire = Orange w/ Black Stripe
?? Don't know ?? Red Wire (No power to wire Constant or Accessory)
Car Radio Amp Wire = Blue
8 Wire Plug (Wires were wrapped in a grey outer sleeve, had to cut sleeve to get to wires.):
Right Front:
White w/ Green Stripe (+)
Brown (no stripe) (-)
Right Rear:
Purple w/ White Stripe (+)
Light Blue (no stripe) (-)
Left Front:
Light Green (no stripe) (+)
White w/ Orange Stripe (-)
Left Rear:
Light Blue w/ Black Stripe (+)
Yellow (no stripe) (-)
Speaker Wires (found at the individual speakers in the doors)
Right Front:
Green w/ Orange Stripe (-)
Right Rear:
Orange w/ Red Stripe (+)
Black w/ White Stripe (-)
Left Front:
Orange w/ Green Stripe (+)
Blue w/ White Stripe (-)
Left Rear:
Red w/ Green Stripe (+)
Red w/ Blue Stripe (-)
Hope this helps. I spent hours looking for the correct color key and this one works for my '91 Explorer.
Feb 08, 2008 | JVC KD-G230 CD Player
Car stereo wiring (1993 Ford Taurus GL)
My guess is that ford did not change that much in a year.
1994 Ford Taurus Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Green/Yellow
Radio Ignition Switched 12V+ Wire: Yellow/Black
Radio Ground Wire: Black/Light Green
Radio Illumination Dimmer Wire: Light Blue/Red
Radio Antenna Trigger Wire: Orange/Blue
Radio Amplifier Trigger Wire: N/A
Front Speakers Size: 6 1/2′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): White/Green
Right Front Speaker Wire (-): Green/Orange
Rear Speakers Size: 5′ x 7′
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Pink/Light Green
Left Rear Speaker Wire (-): Dark Blue/Orange
Right Rear Speaker Wire (+): Pink/Light Blue
Right Rear Speaker Wire (-): Tan/White
Jan 13, 2008 | Car Audio & Video
On and off and on again
You have a power supply problem, it is in standby . Replace powersupply board or fix it.
Nov 26, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Nintendo Wii Console Logo
175 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
