Question about Ovens
I have a VisiCook halogen multi-function cooker, CR3, but the instruction leaflet got wet and is now illegible! Where can I get another copy?
I'm looking for a copy of the instruction Manual for my Halogen Oven
www.manualsonline.com
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 19, 2016 | Ovens
Where do I get a manual for quest 8-1 Multi function Cooker?
Try Amazon customer service, since they sell the unit
Jan 05, 2015 | Ovens
Creda problems
Hi, if there is no regulation on the hob, it is typically the switch that is faulty unless halogen, then it could be the thermal cutout.
warmest regards
Richard The Repairman Colchester Oven Cooker Washing machine repair
Mar 30, 2014 | Creda Ovens
I have a stoves cooker which was working fine until we upgraded to the seventeeth edition consumer unit and rcds. Now I have a negative earth fault.Rcd trips out, circuit is fine up to the cooker. Any...
The clue will be when the rcd trips out. If everything is switched off on the cooker with the exception of the clock when you power it up and then it trips out, it could be in the wiring to the oven from the control switch and or the wiring in the oven. The only way you are going to find this is to take the oven out of the housing and test the wiring, isolating components until you find the problem.
Jul 31, 2011 | Stoves 720EF Electric Double Oven
I have an elgento e452 halogen oven, need cooking instructions.
need to replace fan on my elgento e452 halogen cooker
Aug 28, 2010 | Ovens
Locked oven door to clean. Need instructions to
These might help you get the door off
These Videos will help with your cooker problem.
If you need more video help on appliance repairs visit our Video Tutorial Library at our website
1 how to remove your oven door for cleaning or repairs and how to reseat the door when finished.
2 How to change and fit oven door hinges.
We can not allways cover Every model but hope this helps. Remember to send us an email if you can’t find the part you need.
We also supply all the Parts you need for Repairing your cooker oven Door.
Oven Door Hinge Spare Parts
Oven Door Glass panels
Cooker Door Handels ETC
Cooker Door Catches ETC
Cooker & Oven Door Seal / Gaskets
Remember to Leave feed Back and pass our site on to your Friends:
Our Shop http://www.apart4u.co.uk
Our Video Help Section http://www.apart4u.co.uk/video-tutorials.html
Mar 04, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Clock on cooker flashing
Just to let you know that i have solved the problem with my cooker, (clock flashing after electric going off) i held down the cook period button and the end time button, then i was able to reset the clock by pressing the +button.
Apr 28, 2009 | Hotpoint UY46 Style Line Stainless Steel...
Halogen ring not working
Hi .
It sounds like the temp control is faulty.
Either way you are going to have to remove the hob top to access the controls and elements, Then you can check if the element is getting a feed to it.
Sometimes you can see if the element has gone, .
If you need any further help, let me know.Good luck.
Nov 23, 2008 | Ovens
DIPLOMAT SELECT 920/AHY4401 S/S OVEN MANUAL
I have a copy of the Select 920 double oven instruction manual. Send an email to sharemonger@tiscali.co.uk and I will reply with a copy in .pdf file format.
Dec 24, 2007 | Ovens
Ovens Logo
217 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
