Question about GE GSHS9NGYSS (291 cu ft) Side by Side Refrigerator
How to remove door handle - GE GSHS9NGYSS (291 cu ft) Side by Side Refrigerator
    Problem Solver:
  • 53 Answers
May be small plastic cap above screw hole. remove cap loose the screw.
Posted on Mar 22, 2011
Remove interior door panel 2002 Chevy tracker
No you don't need any special tool . Find all screws on out side of door trim panel and the window handle , the mirror cover plate , then just pull on edge of the panel .
Gently pry the front side door trim panel (3) from the front side door by disengaging the plastic retainers which secure the panel.
Position the door trim panel (3) away from the door in order to gain access to the front side window switch electrical connector, if equipped.
Disconnect the window switch electrical connector, if equipped.
Remove the door trim panel (3) from the vehicle.
Remove the front side window switch from the door trim panel (3) by releasing the 4 plastic retaining tabs, as needed.
Use a cloth in order to pull off the snap ring which secures the front side door window regulator handle (1), if equipped.
Remove the window regulator handle (1), if equipped.
Remove the front side master window switch, if equipped. Refer to Power Accessory Switch Panel Replacement .
Remove the front side door inside handle (1). Refer to Front Side Door Inside Handle Replacement .
Remove the outside rearview mirror opening cover (2).
Remove the screw which secures the front side door pull handle (4).
Removal Procedure
Remove the screw which secures the front side door inside handle (1).
Slide the inside handle (1) forward in order to release the retaining tabs which secure the handle to the door.
Open the front side door inside handle rod retainer and remove the front side door inside handle rod from the inside handle (1).
Remove the inside handle (1) from the vehicle.
Check out youtube video showing how to do it !
How To Remove Install Front Door Panel Suzuki XL 7
Jun 10, 2017 | Cars & Trucks
Remove door handles
Search Results
    Refrigerator Door Handle - How To Replace - YouTube
    ? 2:54
    https://www.youtube.com/watch?v=O5q0WhxMfmQ
    Sep 17, 2012 - Uploaded by AppliancePartsPros
    Follow these simple step-by-step instructions to replace theRefrigerator Door Handle on Whirlpool, Maytag ...
    How to remove or take off Whirlpool fridge door handles ...
    ? 2:22
    https://www.youtube.com/watch?v=tmYz4FVqVnw
    Oct 3, 2014 - Uploaded by way22good1
    How to take off whirlpool refrigerator door handles. ... How To Fix Your GE Refrigerator Handle by removing ...
    Whirlpool Refridgerator Door Handle removal - You
Dec 20, 2015 | Refrigerators
How to remove door handles only, not the whole
For inside door handles, a special tool is required. It slips behind the door handle or window crank and moves the clip down so the handle will come off. For the outside door handle, Take the inside handles off using the special tool (available at any auto parts store). Remove the inside door panel. Remove the retainer clips for the door/lock linkage.The outer handle is held on by bolts on the inside of the door. Good luck
Sep 26, 2014 | Cars & Trucks
Driver side door handle
open door remove panel,put window up,locate and remove fastner behind door handle,install opposite.
Jan 01, 2013 | Mercury Capri Cars & Trucks
How do i remove the fridgerator door handle
HOW TO REMOVE DOOR HANDLES (LFX25960
To move refrigerator through a house door, it may be necessary to remove the refrigerator door handles.
1. Removing Refrigerator Handle
Grasp the handle tightly with both hands and slide the handle up (this may require some force).
The keyhole slots on the back of the handle allow the handle to separate from the mounting screws.
CAUTION:The handle could be damaged if you hit it with a hammer while removing or attaching.
CAUTION:When you assemble or disassemble handle, you must push or pull with reasonable force.
2. Removing Freezer Drawer Handle
Press the handle against door first.
Grasp the handle tightly with both hands and slide the handle to right (this may require some force).
If you need help:
http://us.lge.com/download/product/file/1000003873/LFX25960_LFX21960owners.pdf
Apr 29, 2011 | LG LFX25960ST Stainless Steel French Door...
I need to replce the drivers side mirror. Just seeking instructions on how to.
Remove front door handle bezel screw cover Remove inside handle bezel screw Remove inside handle bezel Lift upward on the rear of the front door inside handle bezel Disconnect electrical connector Remove handle screw cover
Remove handle screw Remove door trim panel upper screw Remove door trim panel lower screw Remove door trim panel (pull the door trim panel outward to release the pin-type retainers)Remove front door sail panel
Disconnect mirror electrical connector Remove 3 exterior mirror nuts and exterior mirror
Mar 07, 2011 | 2009 Ford Fusion
Thank you for your response , been going crazy here...got panel off enough to put hand in but don't know where to pull to unlock door.
Jaguar 2000-06 - Locks & Lock Systems
Power Door Locks - Removal & Installation
Door Lock Switch
Door Lock Diagnosis & Testing
  1. Visually inspect the following:
    Misaligned door(s), hood or luggage compartment lid Door latches Actuating rod Exterior door handle Interior door handle Door lock cylinder Cable Luggage compartment lid exterior release switch Fuse(s) Wiring harness Electrical connector Door lock actuator Remote transmitter batteries Vehicle battery Remote transmitter Door lock switch Front electronic module
  2. If an obvious cause for an observed or reported concern is found, correct the cause (if possible) before proceeding to the next step.
Door Lock Motor
Coupe And Convertible
  1. Turn ignition key to position II.
  2. Motor door glass to fully raised position.
  3. Turn ignition key to position O.
  4. Disconnect the negative battery cable.
  5. Remove door casing for access.
  6. Remove door water shedder.
  7. Position PVC secondary water shedder for access.
  8. Slacken and remove the door glass rear runner lower securing screws.
  9. Reposition door glass rear runner. Mark the position of the glass rear runner upper securing screw.
  10. Slacken and remove the upper securing screw and move the runner away from the glass.
  11. Disconnect door handle and lock barrel (driver door only) operating rods from latch links.
  12. Slacken and remove the three latch assembly securing screws and position latch for access.
  13. Remove latch motor harness multiplug from mounting bracket and disconnect multiplug.
  14. Release operating cable from door handle. Move inner door handle to the locked position. Remove operating cable outer abutment from support bracket. Disconnect cable inner from door inner handle.
  15. Remove lock motor assembly from door.
  16. To install, reverse removal procedure.
    Fig. Removing door lock actuator
Sedan
  1. Remove the door window glass
  2. Detach the interior door handle.
  3. Detach the actuator remote cable from the interior door handle.
  4. Remove the interior door handle.
  5. Detach the door window glass run.
  6. Remove the exterior door handle retaining screws.
  7. Remove the front door actuator retaining screws.
  8. Reposition the front door actuator and exterior handle.
  9. Remove the front door actuator and exterior handle.
  10. Disconnect the front door actuator remote cable.
  11. Detach the door lock cylinder connecting rod (1).
  12. Detach the exterior door handle connecting rod (2).
  13. Remove the front door actuator (3).
  14. To install, reverse removal procedure.
    Fig. Removing door lock motor-Sedan
Hope this helps.
Dec 31, 2010 | 2002 Jaguar X-Type
How to install outer door handle of Ford Focus
remove inside door panel, remove bolts/screws of old door handle, install new handle
Sep 30, 2010 | Ford Focus Cars & Trucks
Replace left front door outside handle pot metal tip broke off
SECTION 501-14: Handles, Locks, Latches and Entry Systems 2001 Escape Workshop Manual REMOVAL AND INSTALLATION Exterior Front Door Handle Removal and Installation
  1. Remove the front door trim panel. For additional information, refer to Section 501-05 .
  1. Position the watershield aside.
  1. NOTE: The tie strap does not need to be reinstalled.
    If equipped, remove the tie strap from the anti-theft guard.
  1. Remove the screws and position the anti-theft guard aside.
  1. Release the clip and disconnect the exterior door handle actuating rod.
  1. Remove the anti-theft guard.
  1. Remove the exterior door handle screw.
  1. Remove the exterior handle actuating rod.
  1. Remove the exterior door handle lock cylinder cover.
  1. Remove the exterior door handle.
Apr 25, 2009 | 2001 Ford Escape
Remove the electric mirror switch
Remove the front door speaker. For additional information, refer to Section 415-00.
Remove the speaker watershield.
Remove the 2 speaker standoffs.
If equipped, remove the window regulator handle.
Separate the handle cover from the handle.
Remove the screw.
Remove the window regulator handle.
Remove the spacer.
Remove the window control switch. For additional information, refer to Section 501-11.
Remove the bolt.
Remove the 2 front door lower bolts.
Remove the door handle cover plate.
Remove the 2 door handle screws.
Remove the front door handle.
Guide the door handle through the opening in the trim panel.
CAUTION: Do not pull directly outward on the front door trim panel, as damage may occur.
Lift upward to remove the front door trim panel.
To install, reverse the removal procedure.
Jun 22, 2008 | 1992 Ford Explorer
GE GSHS9NGYSS (291 cu ft) Side by Side Refrigerator Logo
69 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
