A) Lan driver does not be found and can not use lan port b) Infra port problem and can not find driver
  • Computers & ... Master
  • 27,725 Answers
If you are trying to connect through a modem/router you it should have come with a disk then
you might have to connect the usb lead to your modem to get a connection then
click start control panel,administrive tools,computer management,device manager scroll to network adapters should see a yellow question mark? right click install drivers if you cant find the driver hopefully one of these will help you
http://majorgeeks.com/SiS191_Gigabit_LAN_&_SiS190_LAN_Driver_d5923.html
http://majorgeeks.com/IntelR_PROWireless_LAN_2100_Network_Connection_d4598.html
http://majorgeeks.com/VIA_LAN_Driver_d5240.html
Posted on Mar 22, 2011
Computer cant find a lan port
check device manager if ethernet adapter is installed or not installed. for this you type 'devmgmt.msc' on run.If ethernet adapter is not installed you can use your motherboard driver cd for installation of drivers
Jun 22, 2010 | E-Machines T6420 PC Desktop
Lan driver problem
A D-Link Router is a "plug-and-use" device.
Just connect its 'WAN' port to your cable-modem (or DSL-modem) and connect one 'LAN' port to the network-port on your computer, and you'll be connected -- there is no need for a "LAN-driver" for the DVG-2001S Router.
Apr 16, 2010 | D-Link (DVG-2001S) Router (DVG2001S)
My compaq G60 laptop dont have ethernet lan driver how i can solve this.
buy a adaptor callled "USB LAN adaptor" ....connect to ur USB port and then connect the LAN cable to that adaptor...ur USB port turns to a LAN portb67261b.jpg
Feb 02, 2010 | HP Compaq Presario F500 F700 and G6000...
Driver
not sure why you will need USB drivers for your adsl2+ modem/ wireless router and 4 port LAN switch. It would help you had provided the model number.
The device uses a LAN ethernet port to connect to the computer. You will need atleast one computer to be on the LAN port for setting it up. Once setup is complete you can use wireless connection for every computer.
The user manual & drivers or the DSL-2740B which appears similar to your product description
http://www.dlink.com.au/tech/Download/download.aspx?product=DSL-2740B
Not sure if you need these. Your computers will need LAN or wireless drivers to connect to this DLINK modem/ router.
Good luck
Dec 25, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
No LAN driver for nvidia 630i geforce 7100 mb
hav nvidia based xfx motherboard GeForce 7100/ 630i. After installing all the driver i found there is no LAN driver. I download driver from nvidia webite but there is no matching LAN driver.
Jun 07, 2009 | Pine Technology Motherboard Xfx Nforce...
Onboard LAN detected , drivers properly installed but not responding
The Problem is in your onboard LAN, get PCI LAN card, plug into your PCI slot, install the driver of that PCI LAN Card..
Apr 27, 2009 | Computers & Internet
Network driver
if u mean wired lan driver that is also called network lan driver then here is the file
http://dlcdnet.asus.com/pub/ASUS/mb/socket775/P5GL-MX/LAN.zip
if u want to update directly from the manufacturer REALTEK of the lan card u can download here the updated driver
http://www.realtek.com/downloads/downloadsView.aspx?Langid=1&PNid=6&PFid=6&Level=5&Conn=4&DownTypeID=3&GetDown=false#RTL8100B(L)/RTL8100C(L)/RTL8101L/RTL8139C(L)/RTL8139C(L)+/RTL8139D(L)/RTL8100(L)/RTL8130/RTL8139B(L)
pls rate me FIXYA if i have fixed ur problem
Mar 03, 2009 | ASUS P5GL-MX Motherboard
ASUS P5RD2-VM MOTHER BOARD - lan port is not working not showing led on lan port jpshah j5p10shah65@yahoo.com
You have to install lan card driver to show your lan connection.
Check the cable is connected both end properly and other end pc is connected modem or switch is turned on.
Aug 26, 2008 | ASUS P5RD2-VM Motherboard
Lan ports dont work
Where you able to check the Network adapter on the Windows Device manager?
How to verify your Network card is working properly
If you are unable to resolve the problem with your intergrated lancard then you can add additional LAN CARD on your computer or you can also buy USB to LAN CARD adapter.
http://www.techdeals.eu/electronics-store/images/tduc0205-1.jpg
Mar 07, 2008 | ASUS M2N32-SLI Deluxe/Wireless Edition ATX...
Configuration of LAN fax
The best solution I use is Smart Net Monitor, which is supplied with the Ricoh disks or can be downloaded from www.ricoh-usa.com . First you need to install the lan fax driver, after that then install Smartnet Monitor.
From there click start, and then control panel, then printers and faxes, then right click on the Ricoh LAN fax driver, from there click properties, click ports, then click add a port, under available ports you will see smartnet port (highlite) and then select new port, a new box will come up and then select search, the software will then make the connection and add the port. Besure to click ok and apply and then you are connected
Oct 09, 2007 | Office Equipment & Supplies
Computers & Internet Logo
David Payne
David Payne
