Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Switch on it shows "test" and cannot programme
    Brigadier General:
  • 6,277 Answers
It depends on what date the machine was manufactured. The date should be on the plate which is probably in an awkward position on the back ;-0(
Date code 39 March 2005
Press start/cancel until ALL LEDS are lit
Press both start/cancel AND on/off together until 'dOFF' is displayed
Date code 39 March 2005 to date code 42 June 2005
Press the cancel button and the machine should return to normal
Date code 43 July 2005 onwards
Press both start/cancel AND on/off TOGETHER with top left option button until 'dOFF' is displayed.
John C
Posted on Mar 22, 2011
Hotpoint 720 part fills but goes no further and no faults show
Hotpoint 720 incorporates a fill pressure switch, it monitors the fill level and passes instructions that sufficient water level has been reached, and instructs the programmer to continue to the next stage of the cycle.
Accepting, that enough water has entered the drum, the level switch could be faulty, however it is most likely to be the programmer.
To test any of the fault finding to cure this fault requires removing panels and I would not recommend you doing this unless you are qualified.
If you are however qualified and satisfied that you can proceed safely, with concerns for your own safety, I will send you, a process on how to proceed, checking out weather it is the pressure switch or the programmer.
Trust you find this answer helpful
Adam
Jan 14, 2018 | Hotpoint Washing Machines
CREDA FLASH PROGRAMMER 2S, I can programme the current time and the comfort / reduced mode, however when i set the slide switch to 'auto' all that is shown is 2 moons. According to the manual
Reset digital timers before programming to eliminate trace testing memories and restore full functionality
Make sure you're in correct mode fro programming: Time setting mode, with selector moved to top next to clock symbol
Compare your timer manual with Hagar manufacturer's generic manual for the 2-channel: English on page 3.
http://waterheatertimer.org/pdf/Hagar-monotron-200-2-channel-manual.pdf
http://www.credaheating.co.uk/assets/kb/operating_instructions/0/Flash_2S_Programmer_Instructions_Issue_1.pdf
Contact Creda
www.creda.heating.co.uk
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 18, 2013 | Hardware & Accessories
"jar file is over max size" show, when install
It seems that the programm you try to install is to big for your mobile. Try to free some space on your phone but if it still doesn't work it must be because your mobile simply can't handle such a big programm.
May 10, 2011 | Samsung SGH-E251 Mobile Phone - Black
My Woods 59202 Lamp Timer doesn't have a switch labelled "ON/AUTO" as per the instructions, but obviously the only switch on it, labelled "ON/OFF" is the manual override. The problem is...
There are two timers that look very similar.
Woods 59201 programmable timer with settable on-off functions and switch with ON-AUTO
Woods 59202 random vacation timer that has preset on-off functions and switch with ON-OFF
http://waterheatertimer.org/Woods-timers-and-manuals.html#59201
Random vacation timers are not programmable.
They have internal pins that are preset for random on-off functions so house appears occupied while you vacation.
Random timers do not have AUTO setting, instead they are either ON or OFF.
Technically, programmable timers are also either ON or OFF, but usually these timers use the word AUTO, so you know lamp will turn on AUTOmatically based on settings.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 05, 2011 | Woods 59202 7Day Vacation Security Lamp...
Son bought a HP Desktop F4280, which will not copy, etc., although new fr. Staples last year. was on clearance table - this is the first time it has been used. ink reads full, appears as if it...
I expect the cartridge is blocked unless it prints a test page alright. If the software shows a working printer, try running the cleaning programme.
Feb 24, 2011 | HP Computers & Internet
Timer has worked in the past as programed. However, upon resetting timer to correct time of day then setting "ON" & "OFF" porch light seems to come "ON" two hours...
I test timers.
Timers go bad.
EJ351 has 1 year limited warranty.
Wiring is correct or timer would not operate.
Bulb is good.
I would reset timer again and re-program.
If timer still will not function, then timer has gone bad.
Following page has manual:
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/in-wall%20timers/ej351c.aspx
Reset instructions: Move the control lever to the OFF-CLEAR position for about
20 seconds. The red indicator light will go off and any previous
time settings will be cleared from memory.
For a price, expert works with you via e-mail while you work on timer or any do-it-yourself project.
Feb 23, 2011 | Intermatic Programmable 24 Wall Switch...
Mine is a Honeywell st9400c also (same as "andyrobbens") and it also shows "INTERNAL" (not internal fault, just the word "INTERNAL") Switching power off is not resetting it,...
By the way the battery is a common CR2032 battery and can be swapped out in 2 minutes. Turn off the unit at the mains, 2 screws at the bottom, push in the plastic connectors and the battery can be slid out
Jan 15, 2011 | Honeywell Electronic Programmable...
I changed the battery and then the timer did not work. So now the lights will not turn off. I press on the on/off switch and it goes from clock to a message stating "NO OPs" "SEE...
http://waterheatertimer.org/ST01C-program.html#battery
I have done testing on the ST01C
The link above shows the battery carriage
You might try cleaning the connectors, and the battery poles, or spreading the connectors apart just a bit to see if they reconnect.
http://waterheatertimer.org/Intermatic-st01c.pdf
The manual shows troubleshooting.
My testing shows that if the battery will not connect, then the timer has gone bad.
The battery operates the clock and programming functions and there is not a work-around.
When it's working, the battery lets you operate the manual override, even without programming, so the battery is crucial for timer operation.
The advantage of the battery-operated timer is the simple wiring.
There are lots of programmable in-wall timers with 7-day programming.
Most of the other timers do not have a battery, and they require slightly different wiring.
If you buy one of these timers and have difficulties with wiring, add a comment with the model number and I will assist.
Aplus supply sells ST01C
http://www.aplussupply.com/intermatic/timer.htm
Smarthome
http://www.smarthome.com/2509A/Heavy-Duty-Digital-7-Day-Timer-Switch-ST01C/p.aspx
Nov 08, 2010 | Intermatic Inc. ST01C Digital In-Wall...
My smeg dishwasher stopped during a cycle and warning lights E2 come on. suggesting that it has drawn too much water and to contact customer technical services, any idea what i need to do
E2 shows that the water level switch has been tripped or its faulty,interupt the programm and switch off the dishwasher then switch it on ,programm it again and start the washing cycle again,if the problem persist then test the water level switch for possible replacement
Jan 10, 2010 | Smeg Dishwashers
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
53 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
