How can i install programs for administrator only ..
    Scholar:
  • 150 Answers
Hello ericsonreyes:
When you get ready to click on the program to install just right click the .exe file to install and it should give you the option to run as administrator. At least it does in Windows 7.
Hope that helps, Peter N.
Posted on Mar 22, 2011
Abusript instalation could not open registry
It wasn't started with administrative rights. If this is in windows 7, 8, or 10, right click and run the installer with administrative rights. If the program still can't access the registry, it is likely that a registry file it requires is locked down by a security program (anti-virus, anti-rootkit, anti-spyware, anti-adware, anti-malware). Try disabling these programs before installing.
Jan 19, 2015 | Computers & Internet
Tip
How To Diagnose Timeslips v9.0 and Higher
This feature is only available in Timeslips v9.0 (Service Release 11), v9.1, and higher. If you have a Service Release of Timeslips v9.0 lower than SR11, please download it from <a href="http://www.timeslips.com/Support/downloads"><b>http://www.timeslips.com/Support/downloads</b></a>. Be sure to install the update on each computer that has Timeslips installed.<br /> <p style="font-style: italic;"><br /><br /> <p style="font-style: italic;">If you have not already installed Station Administrator, install it from your Timeslips CD-ROM using the Custom installation option and selecting only Station Administrator. If you are using Timeslips v9.0, then you must reinstall SR11.<br /><br /><br /> <p>We recommend performing this procedure on every computer when you:<br /> <ul> <li>First install Timeslips</li> <li>Update Timeslips</li> <li>Update your computer's operating system</li> <li>Experience data corruption</li> <li>Experience errors starting Timeslips that tells you to use this feature</li></ul>Prior to performing the Diagnose This Computer procedure you must exit Timeslips as well as any other program which may access the Borland Database Engine (BDE). If you are unsure what programs may use BDE, close all other programs.<br /><a></a><b></b><br /><br /><a></a><b>Steps to perform the Diagnose This Computer procedure:</b><br /> <ol> <li>Close Timeslips and any other program that uses the Borland Database Engine (BDE).<br /><b>Note</b>: If you are unsure what programs may use BDE, close all other programs.</li> <li>Open Station Administrator on the computer you wish to diagnose.<br /><b>Note</b>: If you have not installed Station Administrator, install it from your Timeslips CD-ROM using the Custom installation option and selecting only Station Administrator.<br /><b>Note</b>: If Timeslips is operating in a network environment, and Station Administrator is not installed on the workstation, then use Windows Explorer to locate and run <b>Statadmn.exe</b> from the Timeslips installation folder on the server. [From the Windows Toolbar select <b>Start</b>; <b>Run</b>; <b>Browse</b> to locate and open <b>Statadmn.exe</b> from the Timeslips installation folder on the server.]</li> <li>In Station Administrator select <b>Options</b>; <b>Diagnose</b> <b>This</b> <b>Computer</b>. Click <b>OK</b> to confirm that all programs using Borland Database Engine are closed. Station Administrator will attempt to analyze your system.</li> <li>When <b>Analyze System</b> completes, the Diagnose This Computer dialog box will open and alert you to problems with your Timeslips database and operating system. Each of the four areas has an associated Fix button. If any Fix button is enabled, click it to either solve the problem or receive instructions for doing so. Click <b>Help</b> for further information.<br /><b>Note</b>: Even if no problems are reported, Station Administrator may make other necessary changes (<a href="http://kb.sagesoftwareonline.com/cgi-bin/sagesoftwareonline.cfg/php/enduser/popup_adp.php?p_faqid=14967&p_created=1122586187&p_sid=TUvWvcnk&p_lva=15461&p_li=&p_redirect=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MjE4LDIxOCZwX3Byb2RzPTUxMzQsNTE0MCZwX2NhdHM9JnBfcHY9Mi41MTQwJnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTE*#does">see above</a>). </li> <li>If you have experiencing data corruption errors click <b>Change Operating System Settings</b> to open the Windows 95 and 98 Settings dialog box and unmark <b>Enable file system caching</b>. Click <b>OK</b> to return to the Diagnose This Computer dialog box. </li> <li>Click <b>Done</b>. If prompted to do so, restart your computer.</li></ol>
on Feb 21, 2011 | Computers & Internet
Trying to install a programme
You need administrator rights to install programs on your computer. If you are using a work computer or school computer (maintained by an IT group) you should contact them to determine if and how you can achieve administrative rights.
If this is your personal computer then this problem is coming from your Operating System. You need to right-click on the installation file and click "Run as Administrator" to give the program the rights to change files on your computer. A warning will pop-up asking if you are sure you want to give this program the right to change files, just click yes/OK and follow the on-screen instructions for installing your software.
please rate my solution
Jul 19, 2010 | Pinnacle Studio v9
Hey there; I couldn't install programs on my PC since I have no admin. previlage. How can I do that on my account? my PC is networked and network administred.
You can install programs on your PC ONLY with Administrator privileges!
It could be either by logging in as an administrator (or any other account with administrative privileges; Sometimes even Power User privileges is enough) OR right-clicking on the setup file of the program and choosing "Run as..." and specifying a suitable user account.
Other way will be cracking/resetting the Administrator's password - but I won't get into it... Anyway, it's probably set on a server and not in your local PC.
PS: You can ask your network administrator to grant you privileges as a local administrator (ie, only for your own PC) - if he agreed - that should solve your problem! :)
Mar 10, 2010 | Microsoft Windows XP Professional SP3 Full...
I need to add a registration code but i have to log in as an administrator to put the code in how do i do this with windows 7 without screwing up my computor
hi
by adding ur registration code you mean you are instaling a program and want to put its serial number?
if so, you need to know your local administrator password
-when you log in is there any other user accounts than the on you use try to log on by on of them
- try to run the program that you are installing in administrator mode.
-right click on the installing program that you run.
-choose run as administrator.
all the best
Feb 09, 2010 | Acer Computers & Internet
Is cs3 Compatible in Vista Home Basic
Did you run the install as an administrator? Try right-clicking on the setup icon of the program and choose "Run as administrator" Most programs have repair options during installation, try repair if you can. If you dont try to remove. In ALL cases you must do this as an administrator under Vista.
Mar 03, 2009 | HP Pavilion dv6000z Notebook
GIGA WARE PC CAMERA WITH MIC 1.3 MEGAPIXEL.....help me!! =[
That looks like a permission problem.
Do you have administrative rights on that machine?
If you are trying to install, right-click the installation icon for the program, and then click Run as administrator. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
If the program installs but does not run, right-click the program icon, click Properties, click the Compatibility tab, select the Run this program as an administrator check box, and then try to run the program.
Jan 02, 2009 | Radio Shack VGA PC Camera Webcam
I need to install my epson dx 6000 series to vista but the cd wont install
Ensure that you are running the programs as administrator. If you are not sure , then locate the installer file, click the right button of mouse, and chose "run as administrator" from drop down menu.
If it still does not install from disk, try downloading the software from here, and use "run as administrator" option to start the installer.
Link to download.
Unplug printer USB before running the driver setup program, the install wizard will tell you when re-connect the printer.
Oct 25, 2008 | Epson Office Equipment & Supplies
Install my HP D1520 printer on XP
Using the SubInAcL tool from Microsoft to fix permission issues in the registry has solved installation errors for several products including this
Download SubInACL
InstructionsIn the File Download dialog box, do one of the following:
  • To start the installation immediately, click Open or Run this program from its current location.
  • To copy the download to your computer for installation at a later time, click Save or Save this program to disk.
once that is installed then copy this not including
subinacl/subkeyreg HKEY_LOCAL_MACHINE /grant=administrators=f
subinacl/subkeyreg HKEY_CURRENT_USER /grant=administrators=f
subinacl/subkeyreg HKEY_CLASSES_ROOT /grant=administrators=f
subinacl/subdirectories %SystemDrive% /grant=administrators=f
subinacl/subkeyreg HKEY_LOCAL_MACHINE /grant=system=f
subinacl/subkeyreg HKEY_CURRENT_USER /grant=system=f
subinacl/subkeyreg HKEY_CLASSES_ROOT /grant=system=f
subinacl /subdirectories %SystemDrive%/grant=system=f
and Paste it in to Notepad and then Save as RESET.BAT in the "C:Program FilesWindows Resource KitsTools" in that folder and then run that by clicking on it twice
then restart the system
remove any Hp printer program from the system (from add and remove) and then restart once again
then Install the Hp software
Aug 13, 2008 | NetGear DM602 ADSL-Modem
I am trying to install a photosmart all in one C5180 on my pc running Vista. It keeps saying that the program cannot be installed as use by and asking me to log on as the Administrator. I AM the...
This is normal with Vista, Vista log in users as standard (not Administrator privileges) , then ask if to run programs as administrator for security reasons. Once you tell the system to run program as administrator it should install with no problems.
If you really cannot install the program, you can restart computer and login as administrator:
At the "pick a user to login" screen, hit CTRL-ALT-DEL to get the classic login screen. Then you can type in Administrator for the user name, default password is blank.
Read here for more.
Jun 08, 2008 | HP Office Equipment & Supplies
Computers & Internet Logo
37 people viewed this question
Alun Cox
David Payne
David Payne
