I am experiencing a problem with my frigidaire acqua sensy washer - it is not draining. Please advise.
    Brigadier General:
  • 6,277 Answers
Sorry but I do not know your particular machine BUT I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 22, 2011
Washer is draining water into pedestool
I appreciate your post, friend!
It sounds like you could be experiencing a possible leak within your drain pump, gasket, or hoses. You may want to have a technician come out to help diagnosis the leak and locate the cause. This can prevent you from making unnecessary part purchases and avoid any future issues with your Frigidaire washer. If you need further help please feel free to reconnect. -Matt
Oct 09, 2014 | Frigidaire ATF6000ES Front Load Washer
Frigidaire washer will not wash or spin
Hello friend, thank you for your post!
I understand that your Frigidaire washer will not wash or spin. Typically if your washer is not spinning it could be a potential issue with your drain hose. I would check to assure that there are no kinks in your drain line or that the drain hose is not too long. Those could be some possibilities.
If the drain line is clear you could be experiencing an issue with your timer or drain pump. I would recommend seeking assistance from a professional to come out and properly diagnosis your washer. I hope this helps. -Matt
Oct 08, 2014 | Frigidaire Washing Machines
What does E23 mean?
Hello Friend, that's a great question!
If you are getting error E23 on your Frigidaire washer, it usually means one of three things: your drain pump relay has possibly failed, a wire may be disconnected from the pump, or your main control board probably needs replacing. One of the best ways to determine if this is a false error code is to reset the power to your appliance by either unplugging it or flipping off the breaker for about ten seconds. If the error code persists, it would be advisable to contact an experienced appliance repair tech to assist further.
Jul 21, 2014 | Frigidaire Latest ATF6000FS ATF6000FS...
E21 frigidaire affinity won't drain
Good Morning Friend,
I understand you are receiving an E21 code on your Frigidaire Affinity washer, model# ATF7000E, and it is not draining. The E21 code can possibly mean that the water is not draining out fast enough. Please check the drain hose for any kinks or clogs. Also, make sure that your home's drain pipes are not clogged as well. This could also be a false code. Try resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Sometimes there can be a miscommunication between the different boards inside your appliance. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 28, 2014 | Frigidaire Affinity ATF7000E Front Load...
Why won't frigidaire fwtr445rfw clothes washer drain during spin cycle
Good Afternoon Friend,
I understand your Frigidaire washer, model# FWTR445RFW, is not draining during the spin cycle. First, please check the drain hose for any kinks or clogs. Next, check your home's drain pipe for any clogs. After you have checked the drain hose and drain pipe, I suggest resetting your appliance, by either unplugging it or shutting the power off at the circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
-Best Regards-
WP
Jun 19, 2014 | Frigidaire Washing Machines
My frigidaire washer does not drain
I understand that the washer on your Frigidaire laundry center, model# FEX831CS, is not draining. First, check the drain hose for any kinks or clogs inside of it. Secondly, make sure that the drain pipe is not clogged. Finally, reset your washer, by either unplugging it or shutting the power of at your home's circuit breaker, for 3-5 minutes. Restore power and try starting any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire FEX831CS Top Load Stacked...
Why does my washing machine does not drain the water inspite of replacing with a new drain pump
I understand that your Frigidaire washer, model# GLWS1339CS, will not drain the water even if you program it to just drain. I also see that you just replaced the drain pump in your appliance. I suggest checking the drain hose to make sure it is not kinked or clogged. I would also check your home's drain system to make sure that it is not clogged either. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 21, 2014 | Frigidaire GLWS1339CS Top Load Washer
Lafw7000lw reviews
I understand that the fabric softener cup in your Frigidaire washer, model# LAFW7000LW, never drains and is filled with dirty water. This is a result of the siphoning action and is part of the normal operation of your washer. You may remove the water by removing the dispenser drawer and draining the water into the empty drum or sink. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed. Hope this is helpful.
-Best Regards-
WP
May 15, 2014 | Frigidaire Dishwashers
My frigidaire afinity washer was not draining. I opened up the washer and there was a small sock in the drain. i removed it and started the washer again, but the washer still will not drain. it gives me a...
Hello Juan, thank you for your post!
If you are getting an error code E23, it usually means one of three things: your drain pump relay has failed, a wire may be disconnected from the pump, or your main control board possibly needs replacing. One of the best ways to determine if this is a false error code is to reset the power to your Frigidaire washer by either unplugging it or flipping off the breaker for about ten minutes. If the error code persists, it would be advisable to contact an experienced appliance repair tech to assist further.
Best regards - Z.
Apr 04, 2014 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
