Question about Soyo DYLM24D6 LCD Monitor
I HAVE REPLACE THE CAPS ON THE POWER SUPPLY BOARD OF A SOYO TOPAZ DYLM24D6 BUT I MADE A MISTAKE AND PLACE THE 2.2 50V CAP IN THE WRONG POSITION ON THE BOARD, COULD YOU PLEASE TELL ME THE BOARD NUMBER WHERE THE 2.2 CAP GOES ON THE BOARD? THANK YOU KINDLY
  • 11,361 Answers
I canot find the free service manual for this model, but if you can post the pictures, then it may help me to tell you since the foot print of the 2.2uF will be so much smaller than the oher large value caps on the board.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Mar 22, 2011
Will not power up
Always, always the problem with monitors is the "power supply board", and that is almost always a blown sixty-seven cent (or so) capacitor.
Here is a seller on Ebay that will send you EVERY capacitor it might be, and will make a few cents on the deal: http://www.ebay.com/itm/Repair-Kit-Soyo-Topaz-DYLM24D6-LCD-Monitor-/330499791194
Open the monitor case up (Google for instructions) and see if you can observe (or smell) the bad capacitor. You will be able to tell what component I am talking about after looking at that ad on Ebay for the capacitor kit. If it is patently obvious to you which capacitor it is (as sometimes it can be), go to the Radio Shack in the local mall, and buy a cheap soldering iron, a bit of solder, and the specific capacitor you need.
(you will have to hurry however: Radio Shack went bankrupt, and all the stores will be closed by the end of this month)
However you do this, the Fixya will be under twenty bucks, and the monitor will be better than new! Read the instructions in that Ebay advertisement, too - you will understand how easy this fix is when you do.
Mar 07, 2015 | Soyo DYLM24D6 LCD Monitor
Won't power up
Bad power supply board capacitor, most likely.
99.99% probability.
(the other .01% is it is not plugged in)
Sep 03, 2013 | Soyo DYLM24D6 LCD Monitor
I have a soyo dylm2284. On power up it displays screen but quickly turns itself off untill I power back up....Any suggestions to fix. It is out of warrenty
It may have backlight power supply problem or inverter circuits problems.
Check for caps with domed tops first.
http://lcdalternatives.auctivacommerce.com/Repair-Kit-Soyo-Topaz-DYLM24D6-LCD-Monitor-P1660441.aspx
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Please leave rating if it helps.
Jan 21, 2011 | Soyo DYLM24D6 LCD Monitor
I have 2 Soyo DYLM246d Montiors when i plug them in nothing happens wont turn on nothing at all. Is there a Fix or are they junk?
Check your power cable and try to replace the cable and clean any dust on the LCD and try to switch on and check the power unit also
Aug 17, 2010 | Soyo DYLM24D6 LCD Monitor
My Soyo DYLM24D6 monitor screen goes black on reboot, can hear Windows XP Pro loading music but cannot even see the start-up screen from motherboard BIOS. I'm trying to find SOYO website but keep getting...
I would not be surprised if it does have bad caps in the power supply section.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Aug 06, 2010 | Soyo DYLM24D6 LCD Monitor
Fuse Blowing in Power Supply SOYO MT-GW-DYLM24D6 24
If you can solder connectors you can build your own power supply for SOYO. Try the following link or google "gbyer external power supply".
http://slickdeals.net/forums/showthread.php?t=1655449&page=5
Replacement power supplies were avilable recently but it seems they are all depleted.
Nov 06, 2009 | Computers & Internet
My Soyo DYLT032 has power but no picture or sound
I HAVE FOUND 2 2200uf CAPS ON THE POWER SUPPLY BOARD THAT ARE PUFFED UP. CHANGING THEM USUALLY SOLVES THE PROBLEM. THERE'S ALSO A RESET BUTTON ON THE MAIN BOARD YOU MAY NEED TO RESET AFTER CHANGING THE CAPS.
May 30, 2009 | Soyo DYLT032C 32 in. LCD Television
Soyo lcd tv
Hi Friends, Teddux, and Guest, have a correct answer,
The Caps is a 2200uf x 6.3volts, reemplace all caps with this spec.
thz.
Aug 30, 2008 | Soyo DYLT032D 32 in. LCD Television
Soyo DYLM24D6 LCD Monitor Logo
290 people viewed this question
Top Soyo Computers & Internet Experts
Roy May
Matson Kurian
Matson Kurian
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
