Question about Sony Playstation 3 (PS3) Console
My ps3 makes sort of a motor, fan thing sound, what do i do?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 48 Answers
Do not panic, its not a mojor problem.
sometimes your ps3 fan mite make a horrible sound which is louder than usual, i have found. by leaving it for a while it will return to normal.
fans **** in dust, and the dust sticks to your circitry inside your ps3, which makes your ps3 get hot alot quicker.
to avoid this make shure the area around your ps3 is dust free, another way the help prevent thins is byplacing your ps3 in a cubbard or under something, this will collect dust on top stopping it from laying on your ps3.
reguarly hoover out your ps3.
i would also suggest buying more cooling fans(i think they sell on ebay) this will put less stress on the fans inside.
hope this could be of some help.
Posted on Mar 22, 2011
  • coolguy973 Apr 21, 2011
    almost all ps3s do this dont worry
OCCASIONALLY A SQUEALING NOISE COMING FROM UNDERNEATH FRIDGE FAN GOING OUT? WHATS DOWN THERE THAT WOULD MAKE THIS NOISE. HELP
sounds like the condenser fan motor may be on it's way out.clean the coil and make sure there is nothing geting into the fan.i have found ALL sorts of things down there.
Dec 04, 2017 | Refrigerators
My ps3 turns off completeley after five minutes the red light also goes off when i press the power button the red light comes on then the same thing happens all over again help please??
Greetings joseph, it sounds like your PS3 may be overheating. I would suggest disassembling it and cleaning out the dust and gunk that has most likely gotten into it. Also, you'll want to make sure that the cooling fan is running, if it is not, replacing it is a necessity.
I hope that helps.
Dec 17, 2014 | Sony Playstation 3 (PS3) Console
Game keeps freezing and game disk is red hot ps3
hi there,
it sounds like your ps3 is overheating, which is a common problem with the console. this happens when you play a lot and for long periods, it also can happen if the fan has stopped working or there is not enough air getting into the system to keep the gpu and cpu cool. games are very graphic power hungry thus putting the gpu under pressure and causing it to heat up, and if there is no air or not enough air getting into your system to keep the gpu cool, it will overheat and cause your game to freeze. 1st thing you should do id make sure that the fan is working at the back of your console, just turn on your console and look to see that the fan is spining, if this spinning then thats good, if not thats your problem there and will probably need to be replaced. If it's spinning then most likely there is just not enough air getting into the system, so you should move your ps3 outm into an open space to allow plenty air to get into it, you can also give the fan a clean of any dust and dirt, and if you have some sort of an air blower, give the ps3 a quick blow out through the air vent at the back of the console. Hope this helps.
Jan 28, 2011 | Sony Playstation 3 (PS3) Console
Leibherr Refigerator is making a constant noise
What sort of noise are you refering to. If it's a whining noise or a screech, check the fan motor. try spraying a little WD40 on the shaft. sounds like a dry front bearing. better still replace the motor.
May 17, 2010 | Liebherr KIKNV3056 Bottom Freezer...
My sub zero 642 just starting making a humming
It is your evaporator fan. When the door opens power is cut to the fan motor.
Apr 29, 2010 | Sub-Zero 642
A noise coming from freezer, sort of howling and surging
CHECK FOR ICE AROUND THE FAN BLADES AND CHECK TO SEE IF THE FAN BLADES ARE TOUCHING THE SIDES OF THE AIR FLOW DUCT OPENING. WHEN THE BLADES TOUCH THESE OBJECTS THEY CAN MAKE A NOISE LIKE THIS. A MOTOR THAT IS ABOUT TO GO BAD MAY ALSO MAKE THIS NOISE. IF THE BLADES ARE'NT TOUCHING ANYTHING THEN YOU MAY NEED TO REPLACE THE FAN MOTOR. ALSO THE FAN BLADE MAY BE LOOSE ON THE SHAFT THAT IT SITS ON,TRY SLIDING THE BLADE BACK OR FORWARD AND SEE IF IT CONTINUES TO MAKE THE SOUND.
Apr 12, 2010 | GE Profile PSW26P Stainless Steel Side by...
When I start my MPV, there is a rattling sound from behind the glove compartment box. I removed the box and there is a unit that seems to have a motor of some sort inside. WHat is that for. If I disconnect...
this is the interior fan motor and housing.The rattle may be a piece of debris in there(i.e. leaf or a piece of paper)or a thing in the electric motor called a brush.Run the fan at different speeds and if the sound gets quicker with the fan,its probably just a bit of debris.The other,the fan wont run as well and may may need replacing when it gives up and wont work
Jun 29, 2009 | 2002 Mazda MPV
1st 80Gb ps3 model gets hot really fast..
Make sure that your not placing your system on any sort of carpet or rug this will cause the system to overheat. Also check the fan on the back of the system and make sure that the fan is clean and not full of dust and other sorts of stuff. If this does not stop then i would go buy a cooling fan for it just to make sure it dont fry the motherboard!!
Jan 31, 2009 | Sony Playstation 3 (PS3) Console
Unusual fan noise
sounds like you need a new fan motor or blade
Jun 03, 2008 | Amana ARB8057CSL Bottom Freezer...
Motor bussing sound system slow
have a look at the fan on the processor if its running slow it will be making that noise so your processor is over heating and in turn making your pc run slow. replace this fan now. if your processor overheats too much it will burn out.
Apr 25, 2008 | Toshiba Satellite A15-S129 Notebook
Sony Playstation 3 (PS3) Console Logo
106 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
