Simpson eziset 750 t/l stops at first rinse with lid lock led flashing and alarming!
    Brigadier General:
  • 6,277 Answers
There is likely to be a problem with either the lid solenoid/lock or the 'lid closed' sensor. Both require a service engineer's attention I suggest ;-0(
Good luck,
John C
Posted on Mar 22, 2011
My Simpson toploader Eziset 750 will not start, the power point is ok.
Maybe the lid inhibitor switch is faulty,or not being pushed in when lid closed
Sep 20, 2014 | Washing Machines
Simpson EziSet 750 washing machine won't drain the water. please help me.
Lid switch faulty, pump blocked, outlet filter blocked (If fitted), pump needs replacing.
Dec 19, 2013 | Washing Machines
Simpson eziset 550 stops at rinse cycle, light flashing
I had the same problem before, but removing the kink in drain hose does the trick. Maybe yours is more complicated but try it.
Aug 28, 2012 | Washing Machines
I have a simpson EZIset 750 7.5kg washing machine, model # 22s750m When the machine fills up and start it cycle everything is fine until it comes time to do the first drain and spin, the lid lock light...
Hi There, I have the same machine with the same problem. I replaced the lid lock switch with the new upgrade kit, though you might need a tec to install it! approx $100.00
Jan 02, 2011 | Washing Machines
I have just brought a second hand simpson eziset 750, it worked at the shop and now only goes halfway through the cycle. The water level lights are all flashing and beeping like crazy. i have tryed to...
There is a magnet in/under the lid on the left hand side inside a plastic housing. I also got a second hand machine in which the magnet had totally broken down due to corrosion. You can test if this is the problem by placing a magnet where this magnet would be positioned when lid closed. Replace magnet
Sep 05, 2010 | Washing Machines
Simpson eziset 750 manual
Hi our eziset 750 simpson washing machine has stopped working. It randomly just turns off and then will start again few days later. Cheers
Aug 28, 2010 | Washing Machines
Hi, my simpson eziset 550 washing machine wont start, I press power on then the start button and beeping alarm starts with the three water temp lights flashng, this has happened intermitantly in the past...
5 beeps with the 3 temp lights flashing means lids not closed. or lid switch not working
i just fixed this problem. the magnet in the lid had come loose. I undid the two screws on the side of the lid put the magnet back where it should sit then i poured candle wax over it to hold it in place and working fine now.
Nov 30, 2008 | Washing Machines
Simpson EziSet 750 washing machine won't spin - what am I looking for to fix it? Appears to be working in all other respects.
the lid-lock button keeps beeping on my simpson eziset 750washing machine. how do i make it stop!
Sep 20, 2008 | Washing Machines
Washing Machines Logo
1,031 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
