Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
At the end of the wash program it makes a pulsing/pumping sound and the wash enhance light goes on. Once it has stopped there is steam coming out of the machine. I haave tried switching off at the mains to see if it would re-set
    Brigadier General:
  • 6,277 Answers
Sorry but I do not know your particular machine BUT I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain pump filter and the drain pump motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 22, 2011
I have aquarius+ wf740..... when I switch machine on the wash enhance is flashing and power on/off is solid. Once I click any button the wash enhance stops flashing However the buttons do nothing on off...
Thank you for providing detail in your question and typing in coherent sentences, you are the first person today!
As you have checked basically everything the best option is to get a quote for a fixed price repair. You may well have a faulty control module, these are expensive to replace and require specialist tools to program the replacement.
Aug 03, 2014 | Washing Machines
Does not empty at end of wash cycle (not blocked or pump)
faulty program board not progressing
call a technician
Jan 01, 2018 | Hotpoint WMA46 Front Load Washer
We have a 4 month old gaggia titanium. Today, the steam wand stopped working. (It makes coffee just fine.) I've cleaned the steam wand. When I turn the steam dial, very little steam comes out and I hear a...
Sounds like the steam wand is getting blocked some where either at the metal end or in the parnello wand if you machine has one at the end of the steam wand, if both of those are clean then try this push in on the steam knob if that works then tap rod assemble or steam valve needs to be replaced, make sure to ask about the stainless steel valve instead of the plastic one.
Oct 06, 2010 | Gaggia Titanium Espresso Machine
Steam comes out strong for 25 seconds, then almost completely stops and water dribbles from the steam tube, then strong steam for 25 seconds, then it stops and dribbles for 25 seconds, then strong steam,...
Check the thermostats on the steam boiler, one of them is not working, also check the main board for damage, if the pump is not pulsing when you are steaming.
Feb 26, 2010 | Gaggia Titanium Espresso Machine
Blinking red water light on SAECO ITALIA with full tank of water
Your tank may be full but water is not getting into the system. The only way for the red light to go away is to have water come out of the other end...either the coffee spouts or the steam wand. The word they use for this is "pump priming". Thus, either the motor is not sucking water in or there is blockage. Unless water gets out to the other side, the red light will stay on. Before getting dirty with the system, check the tip of the steam wand...if old milk is blocking that end. You will know this is the case when you turn the steam knob counter clockwise to release water but you only hear a semi-startup on the motor and then abruptly stops while the steam knob simultaneously pops out a little bit. It indicates a "blowback"...that there is blockage at one end of the pipe (ie steam wand). Get the residue out by dipping the wand in a tall glass of hot water...wait for a few minutes and blow it out with using the steam knob. Should be ok after that.--Mabada1
Jun 26, 2008 | Saeco Easy Espresso Machine
Ge profile WNSB8060BWW VERYYYYYY LOUD
Rear ball bearing broken change half drum or buy new washer ????????????
the super tech
Sep 04, 2017 | GE WNSB8060BWW Top Load Washer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
