Although we live near the Whitehawk, Brighton transmitter, due to high buildings we get our TV reception from Isle of Wight. During recording on our less than year-old Sony RDR 100 we notice that the picture and sound freeze, then pick up again. We have pit this down to atmospherics, but are concerned whether it is the HD. Any thoughts?
    Brigadier General:
  • 8,909 Answers
If the signal level drops too low, the picture will freeze followed by the sound track.
I would say that if the RDR was faulty, it would not playback properly either on a more permannent basis.
Posted on Mar 22, 2011
Testimonial: "Many thanks. I will now look at the possibility of reception by dish. Great help."
Our fm radio reception sounds like it's being broadcast in an echo chamber. What could be causing that? We live in a rural part of Ohio. Might we need a strongervfm aerial?
You might be picking up a spurious signal (that is being bounced from something) as well as the main signal and your radio is processing both - one signal will be a small fraction of a second behind the other.
When this happens to a tv signal it manifests as on-screen ghosting. This used to be fairly common in the days when tv was transmitted in the vhf band, in spite of highly directional aerials being used.
Many FM aerials are omnidirectional and if that is the type of aerial you are currently using it could be a large part of your problem. I suggest you try a directional aerial with as many reflectors as your local aerial specialist suggests.
The aerial should be mounted at a suitable height to clear nearby buildings and aimed exactly at the transmitter you want to receive. The aerial should also be "polarised" correctly - if the transmitter antenna is horizontal then so should the receiving aerial. If the transmitter uses a vertical polarisation then the receiving aerial should be fitted with the reflectors vertical.
Coaxial cable isn't hugely expensive and so buying good cable won't break the bank. 75 ohm air-spaced double-wrapped might seem overkill for a radio but it is worth the extra as it will lose less signal and more importantly it will collect less noise and interference.
Sep 26, 2017 | Audio Players & Recorders
All functions working except TV. Reports no signal. Manual/Autotune find no stations between approx 400-900 mhz.
Antennal positioning is the first thing to check out. It is a pretty tight pattern you have to hit for a digital signal. Next, I don't know how you are checking your signal strength but it will have to be check the strength at the point of entry into the house. If you are using a splitter to multiple TVs then there will be line loss for every output with you will need to cap off with a 75ohm terminator. After that then it is a wire problem or the wrong input selected at your TV. The RF port is usually input 1 but does vary from time to time. The last is the type of tv you are using. An HD signal will not come in on a tv that can not handle at least 720P. Anything lower than that you will need a scan converter to get it to work.
May 01, 2016 | Televison & Video
I have a week signal can yu tell me why please
Hi
Assuming your location receives an average signal strength from the transmitter, a weak signal reception, could be due to:
- Wrong location of your aerial.
- Is it obstructed by vegetation or other buildings?
- Is the aerial pointing in the right direction?
Check the internet for your nearest transmitter or repeater station in relation to your location so you can align you aerial properly (one trick is to look at the direction other aerials around you are pointing and follow accordingly)
Have you installed a good quality cable and connectors?
Have you checked the cable is not shorted or damaged in any way?
Do not introduce kinks of more than 90 degrees
If you live in a weak signal area:
Have you installed a high gain multi-channel aerial?
If you install a good quality cable with good quality connectors and aerial you should have no problems receiving digital TV signals.
Hope this helps
Sep 30, 2014 | Televison & Video
My freeview picture occasionally goes entirely black for a few seconds
You are in range of several transmitters, so I suspect that you may have duplicate channels or a mixture from different transmitters. Whitehawk Hill should be your best choice (aerial pointing East). You may need to manually tune to avoid signals from Findon or Brighton Central.
Mar 11, 2014 | Toshiba HDR5010KB Digital Recorder
How do I know which direction to point my TV antenna?
Well TV transmitter stations are usually located on top of high hills or really tall buildings. So you want to point your antenna towards something tall. If you live in a largely flat area just face it straight up.
Jan 31, 2013 | Electronics - Others
Ever since digital TV started, I have had a problem with my picture occasionally glitching/pixilating, plus the sound freezes when this happens and I lose part of the broadcast. I currently have an HD TV...
Basically you are not going to get good quality TV reception on an internal antenna unless you live very close to the transmitter aerial with no significant metal structures (including buildings) in the way. You may get a slight improvement by placing the antenna near a window and away from any large pieces of metal or other electrical devices, especially any with a large magnetic field (anything with a motor in it). You may improve the signal / noise ratio by making sure that you have good quality, foil screened (satelite grade) cable between your antenna and TV set.
If the building has a (shared) roof top antenna you might get a better signal, which can be boosted using an in-line signal amplifier from that - but only if it is pointed at the right transmitter. However, as you will be installing the amplifier close to your set it will (just like the amplified antenna you are using) also amplify any electrical interference picked up by the cable as it passes down through the building - including from cars outside.
However your best bet is going to be cable or satelite TV
Feb 17, 2011 | Terk FDTV2A Omni Directional Amplified...
I live 20 miles, south of Seattle, WA. Please give me hints, how I can receive Radio signal, for my E. Howard, E23GA, Atomic watch. I haven't been getting daily signals. Thank you, Dave Harvey,
Place the watch near a window that faces Colorado. best reception is at night although you should get a signal during the day where you are. The signal comes from a transmitter in Colorado. Also, make sure your watch is a model with the US frequency as there are different frequencies used in other parts of the world. Read more at http://www.ntp-time-server.com/atomic-clock.htm.
May 23, 2010 | La Crosse Technology E. Howard Ambassador...
Picture freeze lockup and no sound
It Was Solved by removeing the unit from its present site and retuned unit to winter hill in a good signal area, when unit was returned to original site it was retuned again. and operated ok. as to what was the course i have not a clue, can only think that due to thie site being a fringe signal area may be the transmitter was on reduced power or something?
Apr 10, 2009 | Humax DRT800
Cable box
Yes, this TV will need a converter box if you are getting off-the-air reception. It does not have a DTV tuner built in (too old) although is a high-def capable set.
Dec 06, 2008 | Mitsubishi WS-55807 TV
Televison & Video Logo
77 people viewed this question
Top Televison & Video Experts
