Question about Areca ARC-1280ML-4G PCI-Express x8 SATA II (3.0Gb/s) Card Storage Controller
Areca 1280ML RAID - version 1.49 BIOS Fail to detect Hard disk during installation with windows 2008 only at BIOS Raid Diagnose HDD detected
2 Suggested Answers
  • 39 Answers
SOURCE: Need password
The default username is admin
The default password is 0000
Posted on Aug 29, 2009
Mother board masi km4am-l H.D.D. 1 TRA WES 64MB when installing win xp hard not detected by win setup. I updated bios but not worked. advance thanks
you should not update the bios...the issue is the hard disk is on sata ...and you need a raid driver installed to detect the hdd...so ...either get into BIOS and under advanced features..look the place where the drives are detected..and select the hdd and look for a feature called AHCI ..and disable it ..and leave sata like ide..and save with f10 and restart ...after that the hdd will be seen ..
another way is to make a floppy disk with the raid driver on it (the one from the mothermoard drivers disk ) ..and when it ask you to press f6 for 3rd party software ...press it ..and insert the floppy ...it will pick up the raid driver and will go like a charm ..
if you do not have a floppy ..install a second cd drive ..and use a cd ..and after pressing f6 for 3rd party ..browse and point to the raid driver on the mobo driver cd ..
Jul 15, 2011 | MSI KM4AM-L VIA KM400A CHIPSET ULTRA...
I have problem in asus A8V-vm motherboard in that hard disk is not detected in BIOS but Win-XP is working properly and when I tries to install new windows XP it shows an error that hard disk cannot be...
Asus A8V-VM Motherboard coming with SATA RAID option, thats why you could not see the detected HDD in system BIOS. But you can see the the detected HDD in RAID BIOS. You can enter to RAID BIOS that will pop up after system BIOS. If you are using old version of WinXP it will not detect the RAID controller of you motherboard. Thats why you cannot able to install WinXP. While you booting from WinXP CD press F6 key when the WinXP installer prompted for third party driver. Copy the RAID driver provider in driver CD to a Floppy Disk (INF file) and insert it, hit enter to continue the installation. If you are using WinXP Service pack 2 or higher you do not need this step it will automatically detect the HDD.
Nov 25, 2010 | ASUS A8V-VM Motherboard
RAID drivers in Windows 7 Ultimate 64bit Setup not detected
Delete the '32bit' folder from your USB drive, and try again to re-install Windows. Hopefully, it will find the '64bit' folder, and will install from that folder.
Mar 01, 2010 | Microsoft Windows 7 Ultimate for PC
RAID drivers in Windows 7 Ultimate 64bit Setup not detected.
PLS....give me some of this because my OS was expired and idon't have any back-up so pls may i barrow that windows ultimate OS..??? whom It may ConCern T_T
Feb 28, 2010 | Microsoft Windows 7 Ultimate for PC
ABit-Th7 raid Drivers
This problem is very simple.... Using RAID in booting in cd/dvd cannot be done in this kind of processing. you have to change the setting of Hard Disk and CD/DVD to IDE in BIOS . To change the setting in the BIOS you need to press the Delete After you power on the computer.. In Main menu in the bios you will find the hard disk or cd/dvd settings to IDE, SATA, and RAID. change both hard disk and cd/dvd to IDE configuration. make sure the first boot in the Boot menu is the cd/dvd, where your windows cd installer is inserted. Save the settings by pressing F10 key in the keyboard.. I have the same problem as of you because i try it to change SATA, RAID but cannot boot to cd and cannot detect the hard disk when installing OS, but in IDE settings its okay.. and it works perfect.. after you installed the windows properly, you can change the Hard Disk or cd/dvd configuration to SATA or RAID. TY
HOPE I CAN HELP
Dec 08, 2008 | Abit KT7A-RAID Motherboard
Installing windows on SATA HDD
That happens because the BIOS uses a SATA controller that is not included in Windows XP install disk.
Usually you can solve the problem going to BIOS settings and changing SATA/RAID settings.Check your BIOS settings, and disable SATA RAID mode.This is done in different ways depending on the BIOS.
On HP/Compaq computers for example you press F2 on startup to enter BIOS, then disable SATA mode on bios settings.
On other makes the procedure can be slightly different.
Another way to fix the problem, is by creating your own XP setup disk with SATA drivers included, see:
Resolving "Setup did not find any hard disk drives" during Windows .
Sep 08, 2008 | Soltek SL-75FRN2-RL Motherboard
Sata hdd detected but problem with booting&installation
i have sata hdd 160 gb of seagate and hdd detected in raid channelbut when start installing window it shows message press enter for fresh installation "no hdd found please check power card,bios configuration
Jun 30, 2008 | ASUS P5RD1-VM Motherboard
Cannot Detect Hard drive Winxp On Toshiba Satelite L200
Hi ,
u can not detect HDD during installing win-xp coz in u r laptop u have SATA hard drive.
to detct hdd in setup u want to make sata netive mode diseble in COMS setup
Plz check COMS thereis sata netive mode is available ....
if this information is useful for u please rate me......
Jun 14, 2008 | Toshiba Satellite Pro A200-EZ2204X...
Version number?
Bios 7N is for the following
  1. Support up to 137GB HDD and above.
  2. HPT 370 RAID BIOS version 1.11.0402. The RAID function is for KT7-RAID / KT7A-RAID only. This BIOS version is also for non RAID boards and HPT BIOS will be automatically disabled while RAID controller chip not detected.
Version A9 is the last update
  1. Fix nVidia GeForce4 Ti 4x00 AGP card compatible issue with Windows XP.
  2. HPT 37x BIOS version 1.11.0402.The RAID function is for KT7A-RAID only. This BIOS version is also for non-RAID boards and HPT BIOS will be automatically disabled while RAID controller chip not detected.
  3. BIOS Compile Date: 7/11/2002.
LINK
The above link is for the KT7a with Raid, however the standard KT7a also lists the same bios updates, the KT7a Raid ver1 lists different bios that won't be compatible with your board.
Apr 12, 2008 | Abit KT7A Motherboard
Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
Areca ARC-1280ML-4G PCI-Express x8 SATA II (3.0Gb/s) Card Storage Controller Logo
101 people viewed this question
Top Areca Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you an Areca Computer and Internet Expert? Answer questions, earn points and help others
