Question about Motorola Mobility SLVR L7 Cellular Phone
My fown has a prob..
I cant used my fown.. cause evry time i turn it on... there are lots of number and letters appearing on its screen? (ex. iddle)
    Brigadier General:
  • 7,752 Answers
The phone sounds as if it needs the software to be reflash, take the phone to a mobile service center and have them do it for you there.
Posted on Aug 16, 2008
How would I adjust my carberators for a 1995 honda cbr 900 rr ?
if carbs are worn, have them profesionally cleaned (you can do it yourself by dipping a day in CHEM DIP carburetor cleaner, of course you will need to disasemble ALL the carb and there are a lot of very small o rings take note where are they located, usually under a small washer thats been pressed by a spring and a setscrew)
have new set of needle jets, and main jets (two numbers LEANER!!) Also buy an instrument that called a unisyn,
when reasembly try that all carbs open EXACTLY at same time, all air jets should be opened 1 1/2 turns from closed.
when starting, try to set a medium iddle, engine hot, use the unisyn, and try to sinch all the carbs the same.
lower iddle further, and turn iddle air screw one cyl at a time, 1/8 turn each time, opening or closing, you should hear engine changing tone (IS NOT INMEDIATE and takes up to 30 seconds to tell the difference) until satisfied with THAT CYLINDER, go to the next cyl... until you have all four, by then the iddle is possible to have risen slightly... lower it again and do the air screw procedure again but with 1/16 turn or less each cyl.
dont forget to clean the tank and tank strainer! 23d54551-c891-4d01-bf0d-dc5a0de190a2.jpg 9ebc7e15-3d3b-44e3-a406-4920cdacaba4.jpg
Aug 04, 2014 | 1995 Honda CBR 900 RR Fireblade
My toshiba 32inch tv wont turn on
A lot here would depend on the model number as there are a lot of different ones with different issues.
Got a model number?
Mar 28, 2012 | Televison & Video
Evry time i press a letter key i get a number
It may be because your Function key (Fn key) in your laptop may got struck or there might some special button which you might have clicked it enter into number mode. You may have to find it and click it again to reset back.
Jun 29, 2010 | Computers & Internet
My keyboard is not working well!!!
try to change with new keyboard if prob still persist then prob may be in your system
Sep 30, 2009 | Dell 0Y3740 Keyboard
Single Blue vertical line appeared on the sanyo 42'' LCD screen
vertical ic fult or vertical section supplys missing
Jun 12, 2009 | Sanyo Televison & Video
Keyboard is not working properly-some of the letter keys also have numbers and when I type in a letter the number is coming up
look in bios, for numlock boot
thats why the number function works instead of the letter,
just got 16 odd at work and its my job to put xp pro on, with out a cd drive, if u need xp pro or another os hit me bk
May 18, 2009 | Samsung NC10-14GW Notebook
Problem with entering anti-theft radio code for Honda Fit: The radio screen says: "Enter Code:" I enter the confirmed correct code, but when doing so when the actual code (all numbers) turn into letters or...
when you use the "preset keys" (the keys on the radio with numbers on them) to enter the code, each time you press a code number, a letter appears [c, o, d, e]. once the word is spelled out, from entering the correct 5 digits, the radio is reset, ready to go.
BUT if you miss a number, enter a wrong number, whatever, each number pressed, still makes a letter appear from the word "code". once the word is spelled out, by entering ANY 5 numbers, if ANY of the 5 is wrong, the radio displays a message "Error" and then a number 1 thru 10.
When you see the word "Error..."
the next preset button you push, starts the whole thing over again. The radio says "Enter code". That is when you enter the 1st of the 5 digits, the letter C appears, enter the next digit, the letter O appears, enter the next digit, the letter D appears, enter the last digit, the letter E apperas, the radio is reset, ready to go, if you got the 5 correct numbers entered.
you have 10 chances to enter the right 5 digit code. Each wrong try of 5 digits yeilds a display of "Error 1", "Error 2", "Error 3", etc 'till you get to 10 incorrect tries of 5 digits each.
If you dont get it right in 10 tries, you have to leave the radio "on" for an hour, then it will let you start the 10 tries over again.
Apr 26, 2009 | 2007 Honda Fit Sport Hatchback
Can i turn off the qnotes feature
Your messages are set to 'word' and you want it set to 'alpha'. If you have your user guide this info is on page 45. Here's how to do that. If this helps plz rate this as 'fixya'. If you need more help leave a comment & I'll be happy to help. Thank you kindly.
You can enter text into your phone using the traditional method of pressing a key several times for each character, or by pressing a key once for each letter while words likely to be the one you want are chosen from a database. You can also enter symbols and numbers into a text field. In screens that require you to enter text, you see the following icons. These icons tell you which text input mode you are using: When you access a screen that requires you to enter text, you start in the mode last used.
To choose a text input mode: 1 At a screen that requires you to enter text, press m. 2 Select the text input mode you want to use. A checkmark appears next to the current mode.
Mar 15, 2009 | Motorola Mobility i560 Cellular Phone
Why does the date and time setting screen appear when I turn on the camera?
Turning on the camera while the date and time are not set or after the date and time settings have been cleared due to a total cut off of power (which occurs when batteries are dead and the camera is not being supplied power via AC adaptor) causes the date and time setting screen to appear on the monitor screen. When this happens, be sure to set the correct date and time before doing anything else.
Aug 29, 2005 | Casio Exilim EX-P700 Digital Camera
Motorola Mobility SLVR L7 Cellular Phone Logo
20 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
