Question about Canon iR1600-2000 PS
Hi , i've a canon ir1600 copier , i can't print using my pc connected with usb , i've installed softwer many times but no printing , plz help me
SOURCE: free canon ip1700 software
hi sir i need free canon ip1700 software to install my pc plz help me
Posted on Oct 28, 2008
ginko
  • 19396 Answers
SOURCE: canon pixma ip3000inkjet printer
The printhead is clogged.
See the following guide:
Canon iP3000/4000/5000 Printhead Cleaning Guide
If it does not work, replace the printhead: Genuine Canon Print Heads
Posted on Nov 25, 2008
  • 92 Answers
SOURCE: how can I solve the problem E000 on canon ir1600
hello,you have a problem with the thermistor that check the temperature of the fixing unit ,must change the fixing unit and than must do a clear all on service mode.
Posted on Dec 27, 2008
gunninfo
  • 59 Answers
SOURCE: Can't print or scan through USB port on Canon imageRUNNER 5070.
The port should be active. You can look for problems by right-clicking My Computer and then Properties. Under the Hardware tab, press the Device Manager button. Any hardware issues will show either a question mark or exclamation mark, disabled items with a red x. After the printer is connected, turn it on, then go to Start -> Control Panel. Here, go to add hardware. See if this finds it.
If not, have you added the printer after connecting it via USB under Start -> Printers and Faxes? What about inserting the installation CD before connecting the printer?
Posted on Apr 20, 2009
Printer does not print. Display shows "printing" and "on" button is blinking all the time.
What does printers troubleshooting softwere (included in installation cd) say? If you cannot communicate by WiFi, you will need to connect by USB cable.
Mar 08, 2015 | HP Officejet 7210 All-In-One InkJet...
IR 1600 printing problem
These are the features u need for the connectivity of your printer.........
Parallel ( IEEE1284)
USB
10 Base-T, 100 Base-TX (RJ45)
Full Duplex/Half Duplex
CPU - 200MHz RISC Processor
RAM - Std, 8MByte (upgradeable with 32MByte DIMMs to max 72MByte)
Storage - Optional 10GByte Hard Disk
Is your printer satisfying all these options?
Or
Reason is different IC ROM (IC4,IC5 on control board).
You can reprogram for this IC.
All the best
Oct 03, 2007 | Canon ImageRunner 1600 Copier
Message printer offline
Hi
How about disconnecting it completely from PC and from power.
Wait a few minutes and then connect again.
Clear any paper jams and print queues.
Mar 04, 2012 | Canon MP270 All-In-One InkJet Printer
Hi, I have a canon BJC-80 printer& I am using vista. The printer will not print. It has printed twice. But a time delay of about 30 minutes. My laptop is toshiba & I have a usb cable plugged into...
try to remove the cartridge and print it again. Try also to unplug/replug the USB and restart your printer to check if it prints. You may also use another pc to connect the printer and print. Otherwise call Canon to check it for a possible repair...
Jun 05, 2011 | Canon BJC 80 InkJet Printer
I have canon ir 3300 new plz tell me how will connect to pc i open a new cyber cafe which cable i use strait or cross ovver cable
first, do you have print option installed on your copier?
Second, if you are connecting the PC directly to copier, then you need to use cross utp cable, if over router or hub, then use strait cable.
Hope that helps!
emma.servis@gmail.com
Apr 28, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
How can i connect my photocopier canon 6220 to a pc in order for it to print
hi mukamose,
use USB cable and see if there is a USB port in your Copier,Be sure the PC is detecting the machine and install the driver.
mastergani
Mar 03, 2011 | Canon NP 6545 Copier
Canon ir 1600 my copier print copy image is very poor
iR1600 are special machine that needs a little bit more care.
First, clean the laser unit and optics ( beneath copy glass too ). Then use some polisher and polish the developing cylinder and clean/replace developer cylinder blade.
Use GENUINE CANON DRUM UNIT and GENUINE TONER.
Jul 02, 2010 | Canon Office Equipment & Supplies
HUH
Please don't take out my answer on my rankings. I just pass on what I know. Microsoft-certified Windows Vista drivers are not available for the MultiPASS product you are inquiring about. However, you may be able to install an emulation driver and set the machine to Printer Mode that will allow use of your product as a printer in Windows Vista. If you decide to use the Printer Mode function, please be aware that the instructions and support are provided as is and Canon does not guarantee compatibility or print results.
Note:
  • To print using Printer Mode, the printer must be connected via a parallel port connection. A USB to parallel port connection is not recommended.
  • Installing the emulation driver for your product will provide print functionality only. The scan and MultiPASS F50 fax driver, as well as the MultiPASS Desktop Manager and Toolbar, will not be installed and are not available in any Windows Vista environment.
If you need or want an emulation driver I can help. Sorry, please don't rate me bad for news. If you need more help on this just add a comment and I'll be there!!
Mar 16, 2008 | Canon MultiPASS F50 All-In-One InkJet...
Scanner connection to the PC
i solved mine by replacing the usb cable with one that is 2.00 high speed and inti noise shelded benton-r
Nov 04, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Ip4200 - printing issues!
Hi, Perhaps you can try: remove the USB connection of the printer; uninstall and remove all drivers of the Canon IP4200; reboot your PC; plug in your usb to the PC from the printer; power on your printer; let windows auto detect "New Hardware found"; let windows auto install drivers; test print. If after plugging in your usb and powering your printer Windows did not auto detect "New Hardware found", it's possible that your printer's usb cable is defective. If Windows auto detected the Canon IP4200 and auto installed all the necessary drivers but failed in the test print, repeat above steps but instead of auto install, use the original CD driver and not the new drivers (Let me choose which drivers I want". RESET - User manual is available from the Canon site. There are 2 versions, 1 is a Quick Start Guide in pdf and the other is a User's Manual (On-Screen). Both does not say anything about reset, however you may want to google "fix your own printer" and variations of resetting all sorts of printers are available. Some works, others are ... well you can always give it a try. Or in the On-Screen Manual,you can also try the Troubleshooting/Printing Does Not Start. Another thing that you can try is installing the printer in another PC using the old CD drivers and see if it works. If it does, then it is a driver issue with the new PC. If it does not, you're back to reset . Hope this be of some help to you. Good luck and kind regards.
Jul 30, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Computers & Internet Logo
59 people viewed this question
Top Canon Computers & Internet Experts
Aashish Chaudhary
Aashish Chaudhary
Computer Links
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
