Question about Meade ETX-80AT-TC Telescope
Can't see anything through the viewfinder, only when I remove the cap for the camera T does light pass through the tube. NO view through the eyepiece at all, only through the open T adapter hole.
  • 3,186 Answers
There is a small mirror in the back with a knob there that you turn-- one way is for the rear port view the other way if for the top eyepiece view.
Here is the manual--
http://www.meade.com/manuals/TelescopeManuals/ETXtelescopes/ETX-80AT.pdf
Posted on Mar 22, 2011
When i put the camera to eye there is a round circle i can see through the rest is black I have tried every nikon lens i own . Nothing changes please help.
I have never used the D2X, but if it is anything like newer cameras, such as the D3, D800, etc., there is an eyepiece cover lever near the viewfinder that allows you to open and close the internal cover. It is used to to prevent stray light from leaking into the camera via the viewfinder when your eye isn't near the viewfinder such as when remotely triggering the camera. If your camera has that feature, it may be closed or partially closed.
Nov 13, 2015 | Nikon D2X Digital Camera
View is blurry through eye finder
While looking through the viewfinder, turn the little knob at the upper-right corner of the viewfinder to adjust it.
Refer to the "Adjusting Viewfinder Clarity" subsection of the "Basic Operation" chapter of the manual (page 36 in my copy) for full details.
Dec 21, 2011 | Canon EOS Rebel XSi Digital Camera
I cannot see anything, just blackness... i have removed the lens-cap and put in the eye-piece as well as the front dust cap but all i see is black, also the red finder is not helping me aim.
Use the eyepiece with the LARGEST number written on it. Practice focusing on a distant object during the day time. You must adjust the red dot finder to MATCH the view in the main tube.
Point the scope at a distant telephone pole, and without moving the main tube adjust the red dot so it lands on the exact same spot. DO NOT use the 2x barlow if you have one.
Dec 26, 2010 | Optics
I can see the moon clearly through the viewfinder but when I look through the eye piece holder I cant see anything. only a dim white blur. I assume that the black felt on the front lense needs to stay...
I don't understand about looking through the eyepiece holder. Is there an eyepiece in the holder? Without it you won't see anything. With it, you will see fuzzy blobs if it isn't in focus. Try using the least powerful eyepiece that you have to start with. Finding focus with the more powerful ones takes practice.
I also don't understand what the black felt you refer to is. Telescopes normally have a protective cap over the front opening, which is removed for viewing, but I have never seen one made of felt.
Nov 21, 2010 | Meade DS114-EC Telescope
All my photos are slightly out of focus-no matter what setting i'm on.
One possibility that you can correct:
The eyepiece (viewfiender) diopter is out of adjustment for your eyesight.
Look at the viewfinder and locate the "slider".
Now look through the eyepiece (viewfinder) while in auto-focus mode.
Adjust the slider, left or right, until the image looks sharp to you.
If you wear corrective glasses, you can adjust the diopter whether you use your glasses or not.
This solution assumes that you are shooting in auto-focus; however, this also works in manual mode.
If you require more info, please post a comment for me, or view other expert advice.
-Just Gort.
Sep 21, 2010 | Canon EOS 40D Digital Camera with 17-85mm...
Don't know what buttons on back of camera are for.
Besides the auto-flash mode, you can select fill flash, flash off, self-timer, and nighttime-view with or without flash.
Press the MODE-SELECTOR BUTTON until the desired indicator appears on the LCD PANEL.
c3015.gif Fill flash and flash off modes remain selected after you take the picture. To cancel the selection, press the mode-selection button or close and reopen the lens cover/flash to return to the auto-flash mode.
Fill flash
c3014.gif When bright light indoors or outdoors comes from behind the subject (backlighting), dark shadows (especially on faces) may occur. Use fill flash to lighten these shadows.
  1. Open the LENS COVER/FLASH to raise the flash and to turn the camera ON.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the FILL-FLASH INDICATOR appears on the LCD PANEL.
  3. Frame your subject within the VIEWFINDER EYEPIECE.
  4. Partially depress the SHUTTER BUTTON. When the FLASH/CAMERA-READY LAMP turns off and the fill-flash indicator on the LCD panel stops blinking, fully depress the shutter button to take the picture.
Flash off
c3013.gif When you do not want to use the flash, especially indoors where flash is prohibited, such as in theaters and museums, or when you want to take twilight scenes or distant subjects that are beyond the flash range, or capture the ambiance of existing light, use the flash-off feature. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed in these situations will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the FLASH-OFF INDICATOR appears on the LCD PANEL.
  4. Press the SHUTTER BUTTON to take the picture.
Self-timer with auto flash
c3016.gif Use this feature to include yourself in pictures.
  1. Use the TRIPOD SOCKET to attach the camera to a tripod or place it on another firm support.
  2. Open the LENS COVER/FLASH to raise the flash and to turn the camera ON.
  3. Press the MODE-SELECTOR BUTTON repeatedly until the SELF-TIMER INDICATOR appears on the LCD PANEL.
  4. Frame your subject within the VIEWFINDER EYEPIECE.
  5. Press the SHUTTER BUTTON. The SELF-TIMER LAMP will glow and then blink during the last three seconds of countdown.
    • To cancel the self-timer selection before the shutter releases, close the flash.
    • The self-timer automatically turns off after the shutter releases.
Night-view with flash
c3012.gif In this mode, the camera balances the flash and existing light exposure so you can take beautiful pictures of people at sunset or at night. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed at night will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the NIGHTTIME-VIEW INDICATOR with flash appears on the LCD PANEL.
  3. Frame your picture in the VIEWFINDER EYEPIECE.
  4. Press and hold the SHUTTER BUTTON for 12 seconds without lifting your finger. Note: If you remove your finger from the shutter button before 12 seconds, the shutter will time out immediately.
  5. After 12 seconds, release the shutter button to take the picture.
Night-view without flas
c3011.gif In this mode, you can capture the natural existing light of city-night scenes or fireworks at night. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed at night will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the NIGHTTIME-VIEW INDICATOR without flash appears on the LCD PANEL.
Jun 17, 2010 | Kodak Advantix C400AF APS Point and Shoot...
Veiwing is like looking at a do-nut? nothing in center
The focuser and eyepiece are POINTED UP toward the sky -- the mirror is at the bottom of the tube.
Put the eyepiece with the largest number written on it into the focuser, and during the day time, practice focusing on a distant object.
Aug 13, 2009 | Bushnell 78-9669 Telescope
What is a Veiw Finder
It's where you find a view of what the light coming through the lens. Today's consumer camcorders place the viewfinder center-rear usually with a rubbery piece around the end as an eyepiece/cup. Many units shut off the image to the eyepiece if the flip-out LCD screen on the side is used.
Jan 15, 2009 | Sony Handycam CCD-TRV68 Camcorder
Viewfinder
The shutter remains closed on a DSLR until you take a picture. There is no way to preview an image that does not exist yet.
Being stuck with the tiny viewfinder as earlier cameras had is a good thing. Holding a camera out from your body will give mixed results due to your movements. You will get better results with the traditional method
Jun 08, 2008 | Nikon D40x Digital Camera
Optics Logo
159 people viewed this question
Top Meade Optics Experts
Experi
Level 1 Expert
Joe Wright
Level 1 Expert
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Meade Optic Expert? Answer questions, earn points and help others
