Question about D-Link DIR-655 Wireless Router
MY IP ADRESS IS 62.171.198.11 BUT I NEED MY WPA2 KEY CAN U TELL ME IT
    Problem Solver:
  • 12 Answers
To connect to the DIR-655, by default, you have to enter in 192.168.0.1 in your web browser's search bar. When prompted for a username and password, the user is "admin" and there isn't a password. This can all be changed in the setup but by default, there isn't a password.
Once connected, we are greeted with the config screen. From here, we can setup our wireless networks as we see fit. There should be a wireless security tab that will allow you to change your WPA2 key.
Posted on Mar 22, 2011
How do i set the wireless connection
You have to login in your router/ap to change setting of your wireless device. Default acess is available on the internet, keywords as "myrouter + access" maybe help you, You must get the ip adress of your router, than you go to your router and find out wifi setting where you set WPA2-PSK only, this is most of powerfull security standard which is hacked available by wordlist only, and this is far future to do it with our computers which we have today. Don't forget to change your ip by static way if your device need it, all recommended setting is in your manulal of your device.
Feb 16, 2015 | Computers & Internet
I need internet on my dsi
Well, have you done the homework?
1. DSI needs WiFi, ie, wireless internet. Do you have a wireless router or wireless modem router in your place?
2. If yes, have you enabled the wireless radio in the router. This can be done by opening up the router options by typing the IP Address of the router (it should be somewhere written in the router itself) and login. If you don't know the password, google your model number and you will get all information like default ip address, login etc. If possible download the manual from the manufacturer website and go through it to familiarize the options. (If you have an apple router, you will need "airport utility"..google).
3. Once logged in as "admin", look for "wireless" options (Manual will help you), enable "radio", "ssid", note down the ssid name, and for troubleshooting purposes, leave the security "off/disabled". Save/apply changes.
4. Make sure wireless "G" is selected or a mode thats compatible with wireless "G" (go through the options, mostly default option will suffice). If this is in another page, again, save or apply changes.
5. Reboot the router, wait for a couple of minutes till the lights for internet and wireless appears.
6. From DSI, search for available networks, find the ssid name that you have noted down and click connect.
7. Hopefully, it should connect, otherwise, you may have to manually enter DSI IP Adress, subnet mask (255.255.255.0), gateway and dns servers (both router IP Adress). If your router address is, say 192.168.1.1, then give dsi an ip adress 192.168.1.xx where xx is a number between 2 and 255. That is, what ever ur router ip address is, just change the last digits to anything under 255, excluding the router address. Now try again, hopefully everything should be settled.
8. Look into DSI manual to see whether it supports wpa/wpa2 security or just WEP. You may also have to take into consideration any other devices that connect to router wirelessy, like laptops, smart phones, tablets etc. If all of them supports wpa/wpa2, go back to router options and select that security, create password, write it down. Otherwise select "WEP" encrryption. (The point to remember here is the lowest common denominator, ie, if DSI supports only WEP, selecting WPA/WPA2 will be useless, as DSI will not connect, even if it sees the SSID.
9. Save changes, reboot router, wait for lights to steady.
10. From DSI, again select your SSID name from available networks (just to make things easier, shut down DSI, restart to disconnect earlier connections), it will ask for password or both password and security type. If DSi supports WPA/WPA2, and ur security is set as such, and DSI is not connecting, play with the options, if any, like "WPA only", WPA2 only" WPA/WPA2" and try to connect.
You should succeed with this much details. Good luck
Jan 15, 2012 | Nintendo DSi Matte Blue Console
Ip adress timed ou
Try power-cycling the router (unplug and plug back in). Make sure wifi is enabled on psp (green light @ bottom left, toggle switch is on bottom left of psp). Also, when typing in encryption key, make sure the encryption protocol settings on the psp are the same as what your psp is broadcasting. So if your router is broadcasting WPA/WPA2 encryption, make sure psp is set to that.
Hope this helps.
Oct 25, 2011 | Sony PSP 3000 (0 MB) Black Console
I can not print, and when I try to discover a new IP adress, there's no IP adress found. How can I be able to print again?
The way to find your ip is to printout the configuration page on your printer. You may need the network configuration report if it has one. Now you know the ip address you need to make sure the printer is set to DHCP which will mean it will automatically assign itself an ip address.
Go into the pc and find Add a printer. Tell it its a network printer and it will search for it and find it.
The rest is history!
Jul 14, 2011 | Office Equipment & Supplies
How do i find my wpa2 key for this router? i have tried typing in th ip adress on my adress bar and it wont let me access the page.
What IP address were you entering in your web browser? Were you prompted for a username and password, or was the browser simply timing out when attempting to make a connection? I believe the default IP address for the router is 192.168.0.1 so make sure you're entering http://192.168.0.1 in your browser. If you're then prompted for a username and password then enter 'admin' for the username and try and leave the blank field blank then click 'OK' and see if you're able to login, unless you've changed this information.
Mar 01, 2011 | D-Link DGL-4500 Wireless Router
IP address of samsung jet
hey i cant seem to conect to my home roter on my wi fi on the samsung jet. do i need to put a proxy adress in or something . can you send me a list step by step how to do and that many thanks elliot
Jul 18, 2010 | Samsung Jet S8000 Cell Phone
How do i hook up a d link wireless router? I don't have the manual.
Go on line to the manufacturer there should be an option on the home page for support and drivers. Click there, and you should be able to download everything you need to install your router.
Feb 13, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Wireless connection
My PS3 would only connect using WEP encryption , so I had to downgrade my WPA capable router in order to go wireless.
Aug 03, 2008 | Sony Playstation 3 (PS3) Console
Driver help...Anyone?????
For Router drivers is not required ,U can configure though the command prompt
I can tell some configuration try it,
the default ip adress of the router will the 192.168.1.1 OR 192.168.0.1
In your Lan card configure,
1. obtain Ip adress automitically
go to command prompt----type ---ipconfig---check the ip address which ip is getting---
go to internet explorer ----type the ip address in adress bar-----------login page will get---
login as, user name admin
password admin------configure your internetip adress & DNS ip address,save & check.............
Mar 21, 2008 | Actiontec GT704WG Wireless Router...
D-Link DIR-655 Wireless Router Logo
125 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
