My hotpoint wma 34 wont drain water out. I think it might be due to ablocked pump. What do I do?
    Brigadier General:
  • 6,277 Answers
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 22, 2011
The water wont drain out of machine Hotpoint Ultima WMA 74 on any cycle - have checked the outlet pipe, doesn't apperar to be blocked as water will come out when pipe laying on floor.
If your washer does not drain you need to check this parts.
  1. Inspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch(some models)
  4. Inspect the water pump
  5. Inspect the drive belt(belt drive only)
  6. Inspect the motor coupler
Mar 28, 2010 | Washing Machines
Help my machine hotpoint ultima wma 60 wont empty water tried 5 times water sitting there had turn machine off
p my machine hotpoint ultima wma 60 wont empty water tried various times water sitting there had turn machine off
Dec 21, 2009 | Hotpoint Washing Machines
How do i drain and clear filter as machine wont spin on hotpoint wma 76?
Remove lower rear cover from washer.
Remove large black hose onto bottom of drum.
Remove and clean plastic filter inside hose.
Remove hose onto pump, and check for obstruction here and in the pump.
This should helpo solve your problem.
Nov 29, 2009 | Hotpoint WMM65 Front Load Washer
Wont drain water
inside hose at back ,take back lower panel off black hose filter inside.
Dec 19, 2008 | Hotpoint WMA48 Front Load Washer
My washer does not drain all of a sudden
If you're washer is working (water in-coming, then agitiating, but does not drain/spin at the "spin cycle"; the typical problem is either the door/safety switch or the electric water pump (belt drive machines). I would test the door switch for continuity; replace as necessary.
Mar 24, 2008 | Whirlpool Duet GHW9150P Front Load Washer
The water will not drain on my first edition wma 10 hotpoint washing machine so does not spin either any clues to where the filter is???????
Most likely something stuck in the pump. Remove front panel and hose that goes into pump. usually you will see the object. if not remove pump and look inside.
Jan 06, 2008 | Hotpoint First Edition WMA12 Front Load...
Hotpoint WMA 58 not draining
I would check pump to make sure its not blocked with object.
Jan 05, 2008 | Hotpoint WMA58 Front Load Washer
Hotpoint Aquarius WMA56 wont drain properly water leaking onto floor
pump is working water is only a trickle coming out so wont final spin
Nov 07, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Washing Machines Logo
69 people viewed this question
Top Washing Machines Experts
