Question about JVC Audio Players & Recorders
My jvc "rx-5060 audio/video controller reciver" was playing at about 45 volume and it just turned off. the red light is still on but when i hit the standby button it acts like its going to turn on for a second but then it goes back to the red light.
SOURCE: Shows to be stuck in Standby.
hold down the enter button and the advanced surround button for 5 seconds or so and the amp will restart, the display will come up and hopefully it will be ok. its often caused by using speakers under 8 ohms, or damaged speaker cables etc
Posted on May 28, 2007
SOURCE: jvc rx-5032v audio/vido control receiver
HI MATE YOU NEED THE REMOTE
Posted on Aug 19, 2008
SOURCE: I have a jvc RX-550V
The display is back-illuminated by small incandescent bulbs. Burnt out bulbs equal no display, although the chances of several bulbs failing at once is not high so the power supply for the display/bulb assembly is a good place from which to start fault finding.
It needs a repair shop - as a user there's nothing you can simply dig into to fix.
Posted on Aug 24, 2008
ngfam1
  • 639 Answers
SOURCE: Works, but goes into protect when you turn up/down volume
If its new call Sony and get service????????????
Posted on Aug 28, 2008
SOURCE: Power cuts off after a second after turning on.
There is a very good chance that you have a channel where the output transistors are shorted. Remove the top and pull the center colored ribbon cable going to the power amplifier section. If your display stays on, this is the problem
Posted on Jul 23, 2009
I have a jvc rx-664v audio/video control receiver and it keeps saying overload what should I do
If it says OVERLOAD, you are playing it to loud, to long. Try playing it at 1/2 your normal volume. If it doesn't go into overload, that was the problem. If you have any additional questions, you may contact me at my website, audioserviceclinic.com. Thanks you.
Nov 05, 2014 | Audio Players & Recorders
JVC 6010V shows zero on volume wont go up or down
This is a fault on the D/A digital / Analogue converter , The volume control being analogue is not processing the data in the cicuit and so there is no change in the level. This can be a fault in the IC - the D/A convertor IC which is not giving any response with the turn of the potentiometer. So check this within the amplifier ONLY if you are able to trace the circuit and replace the IC connected to the potentiometer.
Oct 21, 2011 | JVC RX-6010V Receiver
I have a JVC RX 554v Receiver when it's turned on I have no sound their is a mute auto light that's lit in the window....Tried changing the speaker wires with no results...
From the remote control only: Press MUTING to turn off the sound through all speakers and headphones connected. "MUTE" appears on the display and the volume turns off. To restore the sound, press MUTING again. Turning MASTER VOLUME or pressing VOLUME +/- also restores the sound.
Sep 01, 2011 | JVC RX-554V Receiver
On our JVC RX-6030V When we try to play a CD we the receiver flashes "overload then shuts down. Is the receiver done, or is there a fix for this?
Only when playing a cd?? If it does it all the time it probably needs repair of one of the output channels. $80-$120 parts and labor. If it only does it on cd it would be very odd.
Jan 26, 2011 | JVC RX-6030V Receiver
I have a J JVC RX-558V. The mute light is always on so it does not play sound. I can't find the key sequence on the front of the unit to disable Mute?
Apr 19, 2009 | JVC RX-558V
PS3 with this receiver.
I dont know your reciver but if it has a hdmi input plug ps3 into it and set audio on ps3 to pcm,this will give you digital surround eg multichannel,if not you must use a optical cable from ps3 to reciver and set ps3 audio to digital.
hope this helps.
CABLE GUY.
Jun 30, 2008 | JVC RX-6030V Receiver
JVC RX-DV5SL
disconnect the output devices and see if it clears. If it does, connect up the disconnected devices up till the reciver overloads again.
Sep 02, 2006 | JVC RX-554V Receiver
JVC RX-7000V
As per the instruction manual the overload is there because of high volume condidtions and your over heating the unit. They recomend to turn down the volume shut off the reciver wait a few minutes and turn back on the unit with lower volumes. Second it states that the peaker wires or speakers could be shorted so make sure the speakers are good and the wires when you connected them to the reciver are not shorted. If all is hooked up properly then you have a problem in the output stage of the amp and its gonna need service unless you know how to replace the defective output devices? If not Go online at the addy I give you to find about service parts or service manuals.. Good Luck http://www.jvcservice.com
Apr 23, 2006 | JVC RX-7000V Receiver
208 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
