Question about EliteGroup P4VMM2 Motherboard
SD ram problem
3 beeps sound when computer is turned on. no display.. changed new sd ram, same problem.
  • 144 Answers
Try RAM of the same specification & try a different memory slot. Make sure it is properly seated in its place.
Clear CMOS by jumper on your mobo or simply take out battery for 10 minutes from your mobo.
Tell me your mobo model so that i can provide further help.
Posted on Aug 03, 2008
MB keeps beeping 1 long beep no boot.
Hello try to download the manual:
http://support.asus.com/download.aspx?SLanguage=en&p=1&s=4&m=CUSI-M&os=&hashedid=n/a
Select windows xp and open the manual folder
Click on global for download.
Unzip the file and you need adobe reader to read the content.
Here is a list of beep codes:
http://www.computerhope.com/beep.htm
This mainboard uses SD ram and it sounds like a ram problem.
If there is room for a ddr ram block you can`t use SD ram and DDR ram simultaneously.
Try to insert the old cpu again and upgrade the bios to support a bigger cpu. Not all cpu is supported.
Good luck
Dec 22, 2012 | ASUS SiS Chipset CUSI-M Motherboard
Ya i can hear the fan switchin on actually it there is a certain sound that beeps when it is workin properly but now it doesnt beeps, my monitor just shows ''off mode''
dear friend it seems that you have a problem with either a RAM or your Display Crad
Most probably with the RAM
Switch off your computer
remove the RAM and clean both RAM and the slot i think there may be some dust particles present. clean them with a soft cloth, now place it back on the mother board as you removed it
just see the slot for the cuts generall SD ram have 2 cuts and DDR ram have 1 cut a bit out of centre.
also do the same with the display card
thanks
Gagan
Is my information helpful
Mar 16, 2011 | Computers & Internet
When i start my pc it make two beep sounds. And the other problem is, in the booting time it doesnot take any files from cd. My computers conifiguretion is intel d815eea2 board intel p3 processor...
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Dec 04, 2010 | Intel Desktop Board D815EEA2 (BOX815EEAA2)...
I M getting problem When I M turn on my motherboard I listening 3 beep sound after a regular intervel
Beep sound is usually due to an equipment malfunction, is usually ram and display card.was troubleshooting of both hardware (if you have no display card, just do a test on your ram)
> Open the casing cover your computer and remove the ram in the ram slot on your computer by pressing the two pins at the end of slot (Make sure the electrical power source is turned off first)
> Sweep ram slot with a small brush or small paint brush is not used (new)
> After cleaning the ram slot, use the eraser to clean the copper surface on the ram you are.
> When you're done, plug the ram in the slot. (If you have a new ram to do the troubleshooting is better) and I believe your problem is probably due to ram
Jun 30, 2010 | Mercury KVM266PM-U (KVM266PMUD1600)...
I have an msi Notebook Model A4000. I inserted a 2gb sd card into the card reader at which point a message appeared on the screen saying the computer was installing a new driver software or whatever. After...
This is not normal. Try turning off the PC remove the sd and start it again. If no beeping put the sd card in the reader again. If you still have problems post back.
Jun 30, 2010 | Computers & Internet
My playstation 3 is set on the display 1080, i need to change it back to normal sd, but it doesnt display anything on my sd tv. how do i get it back to normal.
Please try the following steps to solve your PS3 problem :
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it and then about 5 seconds later it will beep again. Let go of the power button when you hear this second beep.
Step 3. Wait for your PS3 to start.
This solution basically resets the video output back to standard definition.
Hope this helps and thank you for using FixYa
Jun 04, 2010 | Sony Playstation 3 (PS3) Console
Computer turns on but will not beep or nothing shows on display.
1.On plug the Ram
2.Turn on the System without Ram
if you here Beep Sounds then problem with Ram.
3.Turn Off The system
Fit the same Ram Properly.
3.Turn On .
4.If not Ok,the Buy a New Ram and fit it properly.
Feb 12, 2010 | Gateway (4000274) Motherboard
Please help
The reason you are getting the beeps is because your computer has found Hardware problems. Different amounts and length of beeps mean different things. Laptops are different from Desktops so i cant tell you what it is but its most likely to be the RAM since you tried to change it.
When changing RAM: Not all ram is the same
1. Locate the original Ram. Does it Say DDR1 or DDR2. Make sure you get the same!
2. The Speed of the ram
PC66=66MHz SD Ram
PC133=133MHz SD Ram
PC1600=200MHZ DDR2
PC2100=266MHz DDR2
PC2700=333MHZ DDR2
PC3200=400MHz DDR2
PC3500=533MHz DDR2
PC5300=667Mhz DDR2
PC6400=800MHz DDR2
PC8500=1066MHz DDR2
Make sure both ram have the same specs and try to make it the same as the original stick.
When changing Hardware, be careful of Electro Static Discharge. Touch something metal like your computer case or a aluminum kitchen sink. Then static stored in your body may destroy the ram or your Laptop.
Oct 07, 2008 | Computers & Internet
Adding more memory to my desktop
if the pin placement is some thing like this
...... ............... ............................... its a SD RAM
if it is like this
.......................... ............................ its a DDR RAM
if it is a SD RAM or DDR ram just get it by the a computer store
there are only 3 types avalible for old computers SD or DDR or RD..... you dont need RD RAM it would be SD probably ....just look at a pin allignment.....
Dec 10, 2007 | Computers & Internet
EliteGroup P4VMM2 Motherboard Logo
46 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
