Question about Westinghouse Dishwashers
Since buying our westinghouse SB916 dishwasher, we have found the smell after opening is revolting. It locks in the smell through the day and it is unbearable. We always use Finish Powder - never anything else. Have run through several Finish Dishwasher cleaners but it has not made any difference. It does not remove tea stains from the tea cups (even though if you run your finger around the cup they wipe off easily). Not very happy with the performance at all. We always run the dishwasher on Heavy Duty cycle.
  • 630 Answers
SOURCE: Soap does not seem to dissolve or clean
Probably a sticky dispenser door. Run for a few times with the dispenser open and put a tablet in the cultery basket
Posted on Jul 02, 2009
  • 5 Answers
SOURCE: Dishwasher is 2 years old. Top shelf dishes not
Sometimes the holes in the arms get blocked up,sweetcorn,rice etc, this then stops the arm spinning and water being sprayed onto plates etc, unscrew it and run water through the centre hole and see what happens.
Posted on Oct 06, 2009
heatman101
  • 43501 Answers
SOURCE: My dishwasher leaves tea stains
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Posted on Sep 08, 2010
heatman101
  • 43501 Answers
SOURCE: Soap cup still has soap at end of cycle, but cup is open
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Posted on Sep 30, 2010
heatman101
  • 43501 Answers
SOURCE: I have a Maytag MDB4709AWS dishwasher that's not
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Residue and Film on Dishes
heatman101
Posted on Feb 20, 2011
My Westinghouse fridge freezer, model WSE6100SF, was affected by a power cut lasting 3 days. It now smells, but not inside. Is there a drip tray under the fridge that collects the water?
yes there is but most are not removeable.... remove the cover in the rear of the fridge, the pan is located around the fan motor that's underneath the fridge... I would try pinesol, bleach or odoban to kill the smell..... good luck
Oct 09, 2014 | Westinghouse Refrigerators
Electrical burning smell coming from control panel on westinghouse dishwasher
Had the same issue with a 903sa. Strong burning smell. Continued to run for a while then just died. Opened the control panel (4 screws holding the plastic part at the top of the door on - open the door to access).
Mains feed into the controller was totally fried. Case was all melted. Very nasty. There was nothing obvious on the Board other than a mains resistor that looked like it had been pretty hot at some stage. The three pin mains connector (at least I think it was 3 pins) was just a big, charred bit of goop.
Feb 09, 2014 | Westinghouse Dishwashers
Westinghouse sb916
check hot water supply. Is the valve open?
Aug 07, 2013 | Dishwashers
Powerball tablet remains in dispenser and has not been dissolved
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
heatman101
Asker
Jan 26, 2011 | Westinghouse Dishwashers
My westinghouse virtuoso sensor wash dishwasher isnt cleaning things as good as it should. I dont have a manual as I have just brought this house with dishwasher. Please help?
heatman101
Asker
Sep 24, 2010 | Dishwashers
Change door seal in westinghouse SB 907
Here is a tip that I wrote about leaking dishwashers...
There also is a link in there to another tip on how to buy parts online for your dishwasher...
Leaking Dishwasher
http://www.fixya.com/support/r4546178-leaking_dishwasher
heatman101
Jul 17, 2010 | Westinghouse 24 in. MDP531 RF...
My dishwasher does not dry the dishes and it smells when i open i
heatman101
zzjy
Jun 20, 2010 | LG 24 in. LDF 7811 Stainless Steel...
Fridgidaire professional series drain smells and won't clean
heatman101
nmsgjh
Jun 18, 2009 | Electrolux Frigidaire Professional Series...
A really bad smell coming from the fridge
I had a similar problem with an unbearable smell, not inside, but outside the refregeration compartment. it was from the defrosted liquid that gets stored in a small open tank at the bottom on the rear side of the fridge. over time , particles settle along with water and gives a rooten smell, cleaning this tank solved it.
Hope this helps,
Feb 10, 2009 | Samsung CoolTech Plus / Basic Bottom Mount...
Dishwashers Logo
113 people viewed this question
Top Westinghouse Dishwashers Experts
JonSnell Electronic
JonSnell Electronic
Are you a Westinghouse Dishwasher Expert? Answer questions, earn points and help others
