Question about Proxim Tsunami® MP.11 5012-SUR (5012-SUR-US) Wireless Bridge
I want the default IP of proxim wireless MP11 5012
2 Suggested Answers
  • 394 Answers
SOURCE: what is the default IP
Hi, I am Steve, lets get you some help
the IP address you need is 169.254.128.132
Posted on Jan 28, 2011
I have EarthLink Internet modem is a zyxel p-600 can I connect a wireless router? And if yes what kind should I bye or can it be any wireless router?
yes you can add any wireless router to your network and configure one setting in your new wireless router called default route
the default route to your existing router ip address
for example your existing router ip is 192.168.1.1
your new wireless router ip is 192.168.1.254
you need to put ip net 0.0.0.0 mask 0.0.0.0 default gateway 192.168.1.1 in your wireless router
thats all
thanks
Apr 13, 2013 | Computers & Internet
When I connect my modem dorectly to my pc it works fine with IP address 192.168.1.33. When I go through My D100 I have no connection anf the IP has changed to 192.168.0.100 If I reinstall on dynamic IP...
Improve the Fixya.com experience for everyone by voting!
I think a functional explanation may be of some assistance to you.
The IP address is assigned to the server or client software, but not to the physical workstation which the software or device is installed.
D-Link and virtually every other provider uses IP addresses from a Private IP Address class, which is special class of IP addresses that is reserved for private local networks (not to be confused with Virtual Private Networks, or VPN).
The default IP address is 192.168.0.x and assigned automatically. The most common IP address in any local system is 192.168.0.1.
Over the years, I've found that it is unnecessary to manually TCP?IP settings unless the automatic settings or configuaration has failed When I do have to change the settings, the following are used on Local Area Networks (LANs):
IP Address 192.168.0.1
Subnet mask 255.255.255.0
DNS Do not change
Gateway IP
Address None because the default should be 192.168.1.0 or whatever was
automatically assigned.
Some additional information that should assist you in better understanding a LAN.
The SSID (Service Set IDentifier) is a token which identifies a 802.11 (Wi-Fi) network. The SSID is a key which is set by the wireless network administrator. You must know the SSID to connect to a 802.11 wireless network. However, the SSID can be discovered by network sniffing/scanning. By default, the SSID is part of the packet header for every packet sent over the WLAN.
SSID access points continuously broadcast radio signals which are received by client machines if enabled. Based on the automatic or manual configuration, the client can connect to the access point. A SSID is generally 32 bit long, but when displayed to the user, it is projected into a human readable ASCII format. Multiple access points can possibly share the same SSID if they are for the same wireless network. Many wireless access points support broadcasting multiple SSIDs, permitting the formation of Virtual Access Points. Such Virtual Access Points partition a single physical access point into many logical access points, each of which can have a special set of security and network settings.
SSID Security Issues
Every user of the network must configure the SSID into their system. If the network administrator seeks to lock a user out of the network, the administrator must change the SSID of the network, which will require reconfiguration of the SSID on every network node. Some 802.11 NICs allow you to configure several SSIDs at one time.
Default SSID's
Most 802.11 access point vendors allow the use of an SSID of "any" to enable an 802.11 NIC to connect to any 802.11 network. This is known to work with wireless equipment from Buffalo Technologies, Cisco, D-Link, Enterasys, Intermec, Lucent, and Proxim. Other default SSID's include "tsunami", "101", "RoamAbout Default Network Name", "Default SSID", and "Compaq".
Every time a client connects to the wireless network, the SSID is communicated in plain text format, which can easily be sniffed by eavesdropper using sniffing applications like Kismet. Hence, additional security techniques are required to be implemented in order to enhance the wireless security.
All the best
Ben
Jun 06, 2011 | D-Link DSL-2640B Wireless 11/54Mbps ADSL2+...
Default Password for Proxim AP 4000 MRLR
The default password is should be "public" if it was factory defaulted.
Dec 04, 2010 | Proxim ORiNOCO AP-4000MR (8670-MR-LR)...
IP address missing pls give default ip address
default ip is 169.254.128.132 sub mask 255.255.0.0, but yes if you are going with a router then look for an ip that is assigned by the routher dhcp settings.
Dec 14, 2009 | Proxim Orinoco AP-4000 802.11a, 802.11g/b...
Default IP and password
192.168.1.245 is the IP
default password is admin without username
Jul 02, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
Where to find password to join wireless network?
Hope this helps
Chris (ziraffa)
Jan 11, 2009 | 2wire HomePortal 100W (1000-400026-000)...
Reset AP-700 failed
Simple solution, firstly do not press the reset button to long as it will erase all software, or you will have to do this the hard way. google the software called ScanTool run that from either ethernet or wireless, this tool shows you the AP-700's ip, mac, and name (some techs run these AP's coadjacent so it shows the name as well). You can change the ip of the AP-700 from here most of the time with the proper pass, then you should be able to connect to it regardless. if this dont help ... Proxim/Support/AP700 you will find more of an in depth approach of these things there.
Oct 30, 2008 | Proxim Orinoco Ap-700 802.11a, 802.11g/b...
Proxim Tsunami® MP.11 5012-SUR (5012-SUR-US) Wireless Bridge Logo
147 people viewed this question
Top Proxim Computers & Internet Experts
Prashant M
Prashant M
kj henriksen
kj henriksen
Are you a Proxim Computer and Internet Expert? Answer questions, earn points and help others
