Question about Yamaha RX-V363 Receiver
When I have my yamaha rx-v363 set to 5ch all the speakers (including the sub woofer) work fine except the center speaker. Is there any reason why this may be?
    Brigadier General:
  • 8,546 Answers
Back up and run the speaker setup routines. Does it work there?
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Yamaha-RX-V363-Receivers-manual/id/13748dj481/t/2/
Posted on Mar 22, 2011
When I set my Yamaha rx-v363 amplifier to 5ch Music Enhancer all my speakers (including the sub woofer) work fine except for the center speaker. I can't even adjust the center volume on the amp (but I can...
The receiver automatically pick the best configuration for the source audio. Most music is 2 channels being up-sampled to 4 channels. (Sub-out is separate.)
Mar 22, 2011 | Yamaha RX-V363 Receiver
I hv a Denon AVR 3805, i tried to set it up but after doing all the necessary, i found out that it was only running on 3 speakers (FL,FR & SW). I did connect the center speaker but the sound just...
SW means sub woofer, not necessary means center speaker in all receivers. Instead of setting 5ch stereo, if you have 3 speakers. try to set "3channel" or "simulated". If you own more than 3 speakers, you may refer to the user´s manual to correctly wire them to get the full sound.
Sep 18, 2010 | Denon AVR-3805 Receiver
What do i hook the sub woofer to
the sub woofer speaker should be connected to the Center, the main speakers should be set to the front and the secondary ones in the rear....(front = main just in case surround is not on, center = is for that ump / boom sound, rear = that just pass you by (make you look behind yourself)
Aug 30, 2010 | Yamaha RX-V659 Receiver
Yamaha RX-V861 no sub woofer output
It sounds like you have switched off the sub channel.
Keeping pressing C Level on the remote till you see SWFR.
Press D l / h to adjust the speaker output
level.
Jun 25, 2017 | Yamaha RX-V861 Receiver
I have connected all speakers but not getting anything coming through the subwoofer? I have connected all of my existing Sony suround system speakers 4 corner and one middle and the sub woofer to the...
You need to use an amplified sub. The Yamaha receiver is only sending "Pre-Amp Signal" not amplified audio like the rest of your speakers. If your sub has a crossover built in, connect it's speaker level (wires) to the "B" side of the receiver which will send audio to your sub and it will cross it over internally. Not the best sounding, but it works. Amplified subs range in price from 200 and up. Hope this helps
Jun 14, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
Poor dialog sound of Yamaha RX-V363
I'm working on one right now. It seams that you are not selecting to correct program for the dialog. I would not use music enhancement on dialog content.
Jul 15, 2009 | Yamaha RX-V363 Receiver
Sound not coming through speakers correctly
Check that the speaker setting on the receiver is set to large not small. (if you have 6inch or larger woofers)
If you have only small speakers you will need a subwoofer.
Feb 22, 2009 | Yamaha RX-V363 Receiver
Fuzzy sounds quality from receiver
your surrounds are probably set too high and the the center set too low
Mar 06, 2008 | Yamaha RX-V661 Receiver
No subwofer operation 2year old system
Some systems don't send signal to subwoofer if speakers in SPEAKERS SETUP are set to LARGE, they redirect signal to center and front speakers. Maybe that's problem.
Oct 07, 2007 | Yamaha RX-V1500 Receiver
Yamaha RX-V363 Receiver Logo
194 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
