Question about Samsung Washing Machines
My machine doesn't empty - gets to a certain point in wash, and get the message SL flashing.... need a repair person probably - any ideas for Stellenbosch area?
    Brigadier General:
  • 6,277 Answers
Hi from retired Englishman in SW France, Not emptying
Because you say it will not empty and before calling for repair try this- but no promises as I do not know your particular machine's 'SL' fault code. I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Repair
As for repair person in your area- sorry. I doubt anyone on this forum could give you that information. It's just made up of ordinary guys and gals, probably at home, from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will either have to search in telephone directories OR stay on line and search for 'samsung washer service' for instance or 'samsung washer spares' and hope that you can find someone reasonably local. Sorry again ;-0(
Here are my guidance notes for checking both the drain filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 22, 2011
Cabrio washer stops spinning and doesn't restart
it sounds like the water pump is not emptying properly, blow down the water outlet pipe to see if is clear if not go to the water pump and clean it out there is probably a button , paper clip or other debris preventing it from doing its job eric
Dec 25, 2017 | Whirlpool Cabrio WTW6600SBT Top Load...
My bosch maxx stops mid cycle and the spiral icon that represents spin starts flashing. Its seems that it can not drain or spin yet the drum rotates when washing. Now i have washing stuck and i can not...
This is almost certainly a simple problem with your empty pump filter being clogged. Without knowing the model I can't be certain, but I would suggest that the empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum. While it's trying to get the water evacuated, you will probably see the machine doing a slow tumble for up to 8 minutes and you may also hear the empty pump running too.
You need to locate and clean the filter. Depending on the model, there is probably a round filter cap on the front of the machine at the bottom (It may be behind a small door or hidden behind a clip on panel on the bottom) Many models of this design also have a small hose to the right of the filter cap that you can pull out, remove a plug from and drain off any water in the filter before you remove the filter and get your floor wet, so take a look for this before you remove the filter and get soaked.
In the event that this doesn't work and you just want to get your washing out, you will find that turning the machine off at the wall for 20 minutes will reset it and allow you to open the door (With the power still off). IF THERE IS WATER ABOVE THE LEVEL OF THE BOTTOM OF THE DOOR, then pull the machine out and (With some help, because it's heavy!) Tip the machine backwards at about a 45 degree angle, so that the water line falls below the door before you open it.
If the above doesn
Aug 12, 2011 | Bosch Washing Machines
My machine does part cycle than all lights flash than when restart it will start washing but want go throw the cycles ie rinse spin drain
Teh make and model of the machine is important here, because WHICH lights flash and the number of times they flash is an error code taht we can look up if you tell us the make and model. However, from what you have said so far, this likely to be a problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum. You need to locate and clean the filter. Depending on the model (not familiar which with the model you mention) there is probably a round filter cap on the front of the machine at the bottom (It may be behind a small door or hidden behind a clip on panel on the bottom)
Jul 06, 2011 | Washing Machines
Lg washing machine suddenly stop during washing
It would help to know at what stage the machine stops, however, lete me take a blind guess that it stops just before the spin cycle. If I'm guessing wrong, please tell us when the machine stops and if it displays an error code or any flashing lights (Please note WHICH lights flash and the number of times they flash, as this is an error code that will help pin the problem down).
If I'm right, then........
This is almost certainly a simple problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum.
Jul 05, 2011 | LG Washing Machines
Machine dot draining, not completing cycle.
check pump filter may be blocked . Pump always got water in it even when empty put towels down and if possible lean machine back wards .and always remove plug from wall before doing any repairs .
Feb 11, 2010 | Washing Machines
WMA 54 Hotpoint Aquarius washing machine lights flashing
the problem here is the machine is not emptying when its supposed to, you will find it is stopping at the rinse cycles. there is a sump underneath the machine that needs to be emptied. From my experiences, 9 out of 10 hotpoints that i would of repaired with the same problem as you are having is usualy caused by using the color catcher sheets, they are a disaster.
appliancesdav@hotmail.com
pallesappliancerepairs.com
Feb 03, 2010 | Hotpoint Washing Machines
Wont spin
Probably down to the water not emptying from the machine in the empty cycle and the machine won't spin because there's still water in the drum. If this is the case, the root of the problem is almost certainly a blocked filter, restricting the draining of the water and not allowing it all to pump out in time during the empty cycle. You probably need to find and clean your filter.
Feb 02, 2010 | Washing Machines
0E flashing on Westinghouse LF708C Washing Machine
Had the same problem. After checking that all the hoses etc were clear and no blockages, then suspected that the pump (cost $90 Australian dollar) was faulty. The Westinghouse service technician acknowledged that that was probably the problem, which I then confirmed by pulling out the pump, and then carefully connecting 240V across the pump terminals. Certainly was a faulty pump. So I spent the money on a new pump and installed it and now the washing machine (6 to 7 years old) works fantastically.
Apr 10, 2009 | Westinghouse Washing Machines
0E Error
Apr 10, 2009 | Westinghouse L2046NV Monitor
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Washing Machines Logo
76 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
