Question about Samsung Washing Machines
My machine door will not unlock the icon wont go out on the display and the machine is working perfectly otherwise
    Brigadier General:
  • 6,277 Answers
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 22, 2011
The machine door wont open after it finish the wash cycle
There should be a LOCK ICON with an LED to tell you whether the Front Load door is locked or unlocked.
If the machine door wont open after the wash cycle, the dryer function or the drainage function hasnt completed.
What you can try is just choose the dryer function after the completed wash cycle if the problem arises again.
IF that doesnt work, then look at bottom of the machine; there should be a flap present which you generally open up to get to the manual drainage valve.. you just pull that open and drain any leftover water .. After the water recedes.. the LOCK icon should be off and you can then open the front load door
Dec 07, 2014 | Indesit W 123 Front Load Washer
Oven light wont turn off
make sure the door is shut tight and making the switch
Jan 04, 2014 | Maytag 30" Built-In Single Electric Wall...
Like to reset central locking system on a slk230 1998
go to main menu on display go to settings go to locks and try to reset if wont then control module may be at fault.
Jul 29, 2012 | Mercedes-Benz SLK Cars & Trucks
BEKO WMA 765 S Hi there, my washing machine wont start any program that I select. The display and functions appear to work but wont start? I was unsure as to whether a fault with the door switch was...
Although it is always difficult to diagnose from a distance I think you could be right! Either the locking mechanism or the sensor. Can you hear it locking? Does the lock look as if it could be adjusted and, if so, could you do it yourself?
Otherwise it is a service call-out ;-0(
Good luck,
John C
Mar 02, 2011 | Washing Machines
E o4 displays. will not unlock. tried pouring
turn off at mains checking no water left in drum should release after that sound like faulty door lock or not draining fully, it wont let you open the door till the water has gone well below the door seal.
Oct 27, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Not spinning out, all icons flash, so therefore door remains lock
This is a major control fault within the chip set on the main control board. replacing this damaged control will fix this issue you are having at this time.
Jun 13, 2009 | Washing Machines
Unusual display on panel (padlock) machine can't be programmed door is not locked however
i just went through the same thing.......you need to hold the option and extra rinse buttons simultaneously for 6 seconds, this will unlock it.....so turn the machine on and press the two icons, dont worry about the beeping and flashing after 6 seconds the padlock symbol will go and you can use the machine as usual.....i wish they put that 'minor detail' in the manual...cheers!!
May 31, 2009 | Electrolux EW1000i Front Load Washer
Lover oven door did not unlock after cleaning cycle.
if it is cooled enough then try this
hold back and enter hold for three seconds , unlocking door will appear in display when control and door are unlocking
good luck
Jan 29, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
My hotpoint ultima plus washing machine door wont open after wash
Hi,I have a 2nd hand Hotpoint Ultima digital washing machine & cant seem to use it as when i turn it on on display screen the childlock icon flashes & beeps,even when door is open/closed,when i select a programme the icon still flashes & beeps therefore i cannot use machine.hope you can help me with my question Thanks.GILLI37
Apr 14, 2008 | Washing Machines
Washing Machines Logo
61 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
