Question about Kitchen Ranges
I accidently dropped a glass jar onto the edge of my ceramic hotplate on the side where the controls are there is a chipped area about the siz of a ten cent piece and a hairline crack about 3cms in length. How can I fix it? Also what can I do to stop the crack extending any further?
  • 93 Answers
Ordering the broken part and replaced it - that is the best solution for safety purposes. send us the model number of your unit- we get the part for you or call any repair man to fix it for you.
Posted on Aug 03, 2008
Creda Cooker
It is under the ceramic top. Fixings are at the rear.
Dec 18, 2014 | Cars & Trucks
Hotplate and oven temp
There are several possibilities. Make certain your fuse at the main electrical box is correct for a 220VAC line. You do not want to OVER POWER the range. If that is normal, check all cords for insulation and flexibility. Check thermostat controls on the burners and/or oven.
If parts are normal, the only thing you can do is manually set temps lower when using the oven. Glass tops generally stay hot for several minutes after they are turned off. That is Normal, for example, to avoid Glass from fracturing; temperature slowly declines. Lastly; if all is lost, call for a serviceman to check it out, as you do not want a house fire.
Jan 11, 2018 | Ovens
Yes i have a westinghouse ppl776 ceramic cooktop and can not regulate temperature on any control knobs ,plates run flatout, is the problem with the control knobs or hotplates
When this occurs the problem is always with the hotplate controllers. Has this happened to all hotplates at the same time or has it occurred over a certain time period?
Mar 06, 2011 | Ovens
I have a scratch on the top of my ceramic stovetop. How can I repair it?
Instructions for repairing scratches on ceramic cooktop
Things You'll Need:
  • Nonabrasive cleaner
  • Dishwashing liquid
  • Cloth
  • Razor scraper
  • Ceramic crème
  • Sponge or cloth(s)
  1. 1 Clean the cooktop with a nonabrasive cleaner, such as a glass cleaner or warm water mixed with a few drops of dishwashing liquid. Wipe with a clean, soft cloth.
  2. 2 Use your fingernail or the flat edge of a razor scraper to remove any raised surfaces on the scratch.
  3. 3 Apply a ceramic repair crème, available at most hardware or home repair stores, to the scratched area. Work in gently with a soft cloth or sponge.
  4. 4 Allow the crème to sit for 15 to 20 minutes. Wipe away with a clean, damp, soft cloth.
  5. 5 Repeat as necessary until the scratch is no longer visible.
Nov 10, 2010 | KitchenAid Microwave Ovens
Hotplate on ceramic cooktop not working, another won't turn down.
If 1 of the plates is not working at all, then it is going to be the plate itself, or a faulty regulator, you will have to take it apart to check the plate.
The other plate that you cannot control, needs the regulator replacing.
Mar 25, 2010 | Ovens
Have broken the glass on a new world hotplate unit. Hotplate number CKG 21822. G.C No 11.641.19. G.C No 079513 cover top assembly brown part number 931337000. Hotplate unit is ok but require a replacement...
hi...first thing to do is canvas the price of the ceramic glass top,coz the price of the glass is half or more compare to the new u think if u buy a glass only it is reasonable or waste ur money?then dont try to fix it by it ur self,coz the glass u buy is no warranty for wrong an expert technician to do it to get an assurance for the warranty for installation.
Sep 07, 2009 | Cooktops
Replacing faulty regulator for hotplate
Remove hotplate and oven control knobs. Under the 2nd and 5th knobs is an extra screw which holds on the front cover. Unscrew these and free the cover then access is gained to the screws (2 on each edge) which removes the plate to which the regulators are fixed.Remove the faulty regulator by unscrewing it from the plate,(2 screws) It is an easy job then to install the new part taking care to put the correct wires on the correct terminals. Reassemble, job done!
Jan 11, 2009 | Belling Cooktops
Supporting a ceramic cooktop
Yes. It is. i always feel weary when i see it to however the top is not glass its ceramic so it is a little stronger.if you are in fear wrap tape all the way around the top and tight. if the top is tempered then wrapping the tape around it would make it almost indestructable.
Nov 21, 2008 | Cooktops
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
