Good day, my name is Gabi on Friday 18th March my Telefunken TV was strucked by lightning and is dead. I need the Technician who can fix it for me. regard Gabi Mazibuko, 072 443 7394 or 011 717 1224
  • 4 Answers
My name is tunde i am a technician, i stay in kokstad my cellphone is 0733017413
Posted on Oct 03, 2012
  • 6,993 Answers
We don't stay in the same vicinity, so I don't know precisely where you can a tech to fix this problem for you. Our job here is to give you a DIY (Do It Yourself) solution.....
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck.
Posted on Mar 22, 2011
My TV got struck by lightning what part do I need to get it fixed is a VIZIO E50-C1 LTCWSKBR 2151192
Needs to be diagnosed. Unfortunately this type of damage can range from a few parts to literally the entire TV being toast. I used to be a repair technician and did component level repairs. I have seen lightning fry 1 or 2 diodes all the way up to completely destroying the tv.
Oct 13, 2016 | Televison & Video
Lcd tv hit lightning
So is it dead? or just hit by lightning?
Dec 24, 2013 | Televison & Video
ILO 42" flat screen I think was struck by lightening and now there is no color. Is there anything I can do to fix myself?
tried to reset the tv first, if struck by lightning the tuner will be damaged or the main board but since the tv is still working so i think not the lightning was the main cause.
Aug 30, 2012 | Televison & Video
CAN A TV BE REPAIR AFTER BEEN STUCK BY LIGHTNING CAME THOUGH THE CABLE WIRE
yes it can be repaired,mostly tv strucked by lightning are dead set because of the very high voltage that goes to the circuit coming from the lightning.there are voltage protector on the circuit.they are placed on the high voltage section of the circuit example are,pico resistors,glass fuseand varistors..yuo need to check them out..
Jun 14, 2010 | Toshiba 27A33 27" TV
Lightning struck now my tv won't work.
No,Ur power supply board have a big jolt massive power search.It dead,change the power supply board,will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 08, 2010 | Insignia NS-LCD22-09 LCD HDTV
My tv was struck by ligthning how do i fix it?
fixing the tv after a lightning strike is a higly specialized task, you have to deliver it to a qualified tv technician ,there is nothing you can do yourself to fix it
Jan 26, 2010 | Televison & Video
I have a 58'' HP Pavillion Projection screen TV. It was struck by lightning. the power cord is good. It will not turn on at all, no fans running, etc. What do you think I will have to fix?
As u have just said that it was struck by lightning the only way to get the TV back working is to replace burnt items on the moterboard .becouse lightning must have demaged some components on the power supply, if possible i would preffer a new power supply board
Aug 31, 2009 | Televison & Video
NO POWER ON
Hi! your tv power supply is busted, you need to contact a qualified technician for repair.
Jul 27, 2009 | Televison & Video
Tv struck by lightning
You wont be able to fix the TV your self as the power circuit board may have blown - consult a qualified repair man. Buying a surge protector for your expensive electronic goods is highly recommended.
Jul 10, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Struck by lightning and won't power up
WOW!
Warranty voider there.
Hate to see a $1,000 TV go down the toilet.
If your lucky, you can try checking the fuses inside the TV.
The lightning may have taking out only your power supply board, shopjimmy.com may have replacements for about $100. But, I can't tell you for sure that will fix the problem.
You may have to take to a repair shop to find out for sure.
Good Luck
Feb 11, 2009 | Philips 47PFL3603D LCD TV
Televison & Video Logo
64 people viewed this question
Top Televison & Video Experts
