Question about Maytag Atlantis MDE6400AY Electric Dryer
Everything works on my dryer but not heating up, checked fuses and no lint built up.
  • Maytag Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101=-=-
Posted on Aug 13, 2011
Replaced all parts for dryer because of no heat dryer runs drum turns had breaker and wiring going into dryer everything ok still no heat could wires be backwards going to replacement parts?
Electric dryers have as many as three thermal fuses. See if you might have missed one. One next to coils, one next to drum and one near the lint trap at air outlet. All three have different trip settings.
Jan 04, 2016 | Dryers
Dryer wont heat up
Small 3oo f fuse mounted on the heater element is probo blown from over heat due to vent blockage.
Dec 30, 2015 | Roper REX3614KW Electric Dryer
Kenmore Electric Dryer , 700 series, MOD 64722400 , SER MR4136705 , Type DWJR-ELE-2406028-FM64 . Dryer is not heating, checked fuse it's fine, cleaned every nook and cranny with a swifter duster and...
Hi.
Be sure that you have checked the thermal fuse. The part is tested using a multimeter set on Ohms (impedance). Remove the fuse from dryer and read impedance touching the fuse contacts with the two multimeter probes. If impedance is Ohm infinity (open), then the fuse is bad.
If the fuse is OK because tested good or replaced, then the problem is either one of the three thermostats located in the heating group, or the heating element. All parts are tested similarly to what described for the thermal fuse. If any of the parts read open (infinity), then the part is faulty. After finding the defective part remove all the lint from heating assembly and air duct. The lint causes overheating and blows thermostats, fuse or element.
Regards.
Ginko
Jul 14, 2011 | Kenmore 64722 Electric Dryer
Whirlpool AWZ7303 condensing tumble dryer . Drum not turning although it is heating
If your Whirlpool dryer has mysteriously stopped producing heat, a blown thermal fuse may be the cause of your problem. In Whirlpool dryers, thermal fuses are safety switches that are designed to disrupt the flow of electricity to your dryer's heating mechanisms once the dryer reaches a predetermined maximum temperature, usually somewhere around 180 degrees F. Thankfully, troubleshooting the thermal fuse in a Whirlpool dryer is easier than it sounds. Instructions:
  • Clean out the lint screen in your Whirlpool clothes dryer. Lint buildup can cause your dryer to overheat, triggering the thermal fuse to disrupt power to your dryer's heating mechanisms. Take the lint screen out of your Whirlpool dryer and wash it in warm water. Dry the screen thoroughly before replacing it.
  • Look behind the dryer to check its flexible exhaust hose for kinks or obstructions. Disconnect the exhaust hose from the back of your dryer and clean out any lint that has built up.
  • Go outside and check your Whirlpool dryer's exhaust vent for obstructions. Lint buildup, bird nests or other obstructions in the outside exhaust vent can trigger your dryer's thermal fuse.
  • Disconnect your dryer from its power source before attempting to access its thermal fuse.
  • Access the thermal fuse in your Whirlpool dryer by removing the back panel. Remove the screws that hold the back panel in place and it should easily come free.
  • Look between the dryer's blower housing and exhaust to locate its thermal fuse. The thermal fuse in a Whirlpool dryer looks like a white plastic strip that has two wires connected to it.
  • Bypass the thermal fuse in your Whirlpool dryer while you perform a quick diagnostic test. Use electrical tape to tape together the two wires connected to the thermal fuse. Reassemble your dryer and plug it back in. Set the dryer to a timed heated drying cycle and press "Start." If the dryer produces heat with its thermal fuse bypassed, it means the thermal fuse needs to be replaced.
  • Replace a blown thermal fuse in your Whirlpool dryer. Disconnect the power and remove the back panel. Remove the electrical tape that you used to perform the diagnostic test and disconnect the wires from the thermal fuse. Remove the screws that secure the thermal fuse to the dryer and discard the blown fuse. Attach the replacement thermal fuse by replacing and tightening the screws. Attach the wires to the new thermal fuse.
  • Apr 20, 2011 | Whirlpool AWZ7303 Electric Dryer
    I replaced the thermal fuse because there was no heat. Now the dryer over heats and shuts off. Everything checks ok on ohm meter. The timer works in the "no heat" mode. Could it be the timer...
    after you changed the thermal fuse did you clean out the dryer and the vent line?if not you blew the fuse again and it will keep doing this until you clean out the duct that the lint filter slides into,vac and blow out the motor and the cabinet where the motor is and blow out the vent line,if it's a long run remove the vent line from the back of the dryer and blow it out with a leaf blower.the dryer went over 300 degrees from lint buildup and popped the thermal fuse,it's a safety so the dryer doesn't run hot and start a fire.if the dryer is running and sfter like 20 minutes it shuts down and won't start for a while until it cools down then the motor is bad also probably from the dryer running to hot from the lint build up.
    Apr 08, 2011 | Amana DLE330RAW Electric Dryer
    Kenmore Electric Dryer will not Heat
    Define checked everything. Usually when your dryer is not heating but blowing air its one of three things...
    1. Thermal fuse in dryer
    2. Thermistor in the dryer
    3. Heating element in dryer
    You need a signal meter with continuity check to accurately test all three componets. Normally the fuse and thermistor are in a set and cost less than 25 bucks. They are easy to replace if you are good with taking things apart. If the element is bad then you need to make sure your lint trap and exhaust hose are clean and kept clean. That is the main cause of the element burning up when it gets lint collected inside the dryer cavity.
    In a pinch if the element is bad you can simply find where the metal has broken and try bending the rod so that it touches. The element has to be one solid piece so if there is breaks try and connect them back together until a new one can be purchased.
    Please unplug the dryer before doing anything mentioned above.
    Hope this helps
    TankMurdock
    Apr 27, 2009 | Kenmore 73952 Gas Dryer
    Whirlpool Electric Dryer Model GEQ9800PW1 - No Heat
    Well your high limit is blown. It mounts up top of the heat element chamber.
    Jan 31, 2009 | Kenmore 62602 Electric Dryer
    Kenmore 70 Series Dryer
    The fuse probably blew due to a blockage of some sort. Check your ventpipe. It may be full of lint. The fuse is a small white part held onto the blower housing with 1 screw. It usually can be found under the dust cover on the rear of the dryer.84a81ce.jpg It has 2 small wires hooked to it and it is wired in series with the door switch. When the lint gets built up and dryer over heats and fuse blows. The result is just as if you opened the door.1d45fbe.jpg
    Dec 16, 2008 | Whirlpool LER4634J Electric Dryer
    Maytag Atlantis MDE6400AY Electric Dryer Logo
    Top Maytag Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Are you a Maytag Dryer Expert? Answer questions, earn points and help others
