Question about Dishwashers
We have a Diplomat dishwasher ADP 8242 and its intergrated but have no manual, the machine switches on fine and starts its cycle, i switched it on before going to bed and in the morning it was still running so obviously knew something was wrong, when i opened it the dishes were not clean and there was water in the bottom which took a while to drain away, also the salt inlet is full of water, should it be like that? Any advice would be great thank you.
eagle338
  • 4889 Answers
SOURCE: Diplomat intergrated dishwasher error code FA
FA is a problem with the tubidity sensor. By holding down the power button, it stops, but just repeats everytime you try a new wash cycle. So keep doing it and you can atleast use it. If you want to go one step further and find a permanent solution try feeling around in the sump (where the filter slots in) being careful for any broken glass. Other than that it will probably be a strip-down job to examine the internal hoses and the pump; not a DIY job to be honest.
Posted on Feb 03, 2008
  • 351 Answers
SOURCE: Whirlpool dishwasher ADP 4732AL
sound like you have a valty inlet valve if your model has the valve built into the hose you will have to replace the hose assy.
Posted on Mar 20, 2008
  • 1073 Answers
SOURCE: whirlpool adp 8540 - 7 flashes
replace the control board in the console
Posted on Apr 10, 2008
grandadfixer
  • 99 Answers
SOURCE: Salt tray full of water
Just pour a bag of dishwasher salt in water will come out.Then light goes out.
Posted on Oct 12, 2008
  • 1462 Answers
SOURCE: diplomat adp 8520 dishwasher no hot water
two things to check
check continuity thru heater
remove outer door panel and check for faults in wiring loom
get back to me is these are both ok
Posted on Nov 14, 2008
Intergrated cooker heats up and blows fuse!! diplomat adp 3650
check the circuit and see what you have plugged inthat is pulling juice at the same time
Jan 03, 2012 | Dishwashers
Feb 03, 2008 | Dishwashers
Why does my Diplomat ADP 8902 dishwasher beep twice when i switch it on and the 4th wash program light flash and do nothing else?
Can I say thank you for the above advice. Hit the programme button 4 times and closed machine. Now running rinse cycle. Let hope it works afterwards. Will post ant let you know.
Nov 20, 2010 | Dishwashers
I have a Diplomat Fully integrated dishwasher model ADP 8242 when put on any program it fills and seems to be washing then stops after 5 minutes and the dispenser door has not opened. There is a lot of...
Check the small drain pump. Possibly its asking the pump do drain to allow for fresh water, but because low level is not detected it shuts down. The dispenser draw normall opens when the hot wash cycle starts.When you think its washing,briefly open door and see if eater is spraying out of the nozzels.If no water visible, check the main wash motor for sticking
Sep 24, 2009 | Dishwashers
Diplomat dishwasher bleeping showing FA
We have just experienced an FA audible error on our Diplomat ADP 8332 dishwasher...after pulling the dishwasher out and removing the low front panel we found the drip tray full of water. We tipped the dishwasher onto it's front and removed the drip tray and found a float pressure switch...it appears that once the drip tray is full the float switch activates and causes the FA fault (prevents the dishwasher from continuing) drain off your drip tray replace all covers and you should be good to go!!
Sep 16, 2009 | Dishwashers
Diplomat adp 8242 beeps twice one flashing light not working. turn off leave for hours then might work.
Turn off plack power button, turn back on, then press cycle selection button 4 times very quickly. flashing lights should change, shut machine and it should fire up and work...... it worked for me. May have to try it several times as getting the 4 button press timed right can be a bit tricky.
Jul 13, 2009 | Dishwashers
Diplomat adp 8520 dishwasher no hot water
two things to check
Nov 14, 2008 | Dishwashers
Diplomat Dishwasher Model ADP 8132
Please can you give me the dimentions of this Dishwasher Diplomat Model ADP 8132, as I have got to get a replacement and have been told that the Hotpoint FDL570X is the replacement offered,Many Thanks,
Mar 28, 2008 | Dishwashers
Dishwashers Logo
78 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
