Question about Samsung Microwave Ovens
My microwave is not heating food. Its model is MW73C (digital). Its brand name is Samsung microwave TDS. I lost my manual. Please help me solve this problem..
    Sniper:
  • 113 Answers
Http://downloadcenter.samsung.com/content/UM/200305/20030529154046218_MW735WB_XAA-01.pdf go to this site, this is where you'll be able to download the manual for this oven.
Posted on Mar 22, 2011
  • Samsung Master
  • 6,993 Answers
Investigate these three areas if your microwave won't heat
Power Diode
A diode is an electronic component that readily passes current in one direction only and blocks the flow of current in the opposing direction. If your microwave's diode has become defective, your microwave will not heat and you will hear a buzzing noise. Test the diode to determine if this is the cause of your problem. Replace it if it is defective.
Testing a diode
NOTE: Before you test your diode, make sure your microwave is unplugged, and that you discharge the microwave's capacitor.
Whether it is shorted or open, a defective diode will most likely show some sign of defect. Defective diodes will usually emit an electrical burning smell, signifying its defectiveness. Also, it may have split in two, or it may exhibit a burned crack, or possibly even a blistered spot.
A shorted diode is indicated by a loud humming noise from the high voltage transformer, and no heat produced when a cook cycle is initiated. Whereas little or no heat produced in your microwave, with an absence of a humming noise is indicative of an open diode. In either case, the diode has to be replaced.
With your microwave unplugged, and your capacitor discharged, use extreme caution to remove the lead that leads to the capacitor. You can leave the ground connection attached. The side of the diode that goes to the ground is usually marked with a dot, stripe, or arrow. Set your ohmmeter to R x 10,000 or higher. Touch the positive meter probe to the anode and the negative meter probe to the cathode to measure the resistance across the diode terminals. Remember that the cathode is on the side that goes to the ground, which is often marked by a dot, stripe, or an arrow.
A normal diode, that is a non-defective diode, will read anywhere from 50,000 to 200,000 ohms. Differences in microwave make and model account for this large range in resistance readings.
Reverse the meter probes and measure resistance while touching the positive probe to the cathode and the negative probe to the anode. Reversing the probes like this should result in a reading of infinity. Unless a bleeder resistor is present. The presence of a bleeder resistor would produce a reading of the value of the resistor.
High Voltage Capacitor
A capacitor is an electrical device which stores electricity. A defective capacitor may be why your microwave is not heating but you are hearing a buzzing or humming noise. The capacitor will have to be tested to determine if this is the cause of your problem. A defective capacitor will have to be replaced before your microwave will work again. Make sure you discharge the capacitor before you test it, though.
Magnetron
A defective magnetron is the third possible cause of why your microwave is not heating, but you can hear a buzzing noise. Test your microwave's magnetron. Replace it if it is defective.
Testing a magnetron
NOTE: Before you test this component, make sure your microwave is unplugged, and that you have discharged the capacitor.
There are two tests to conduct in order to determine whether or not a magnetron has become defective. If you receive results other than what are detailed below, you will have to replace your microwave's magnetron. Each test is described for you here:
TEST 1: Locate your magnetron and label each of the wires attached to it so that you know which wires are to be replaced where. Set your ohmmeter to the lowest resistance scale. Take a resistance measurement between each of the magnetron's terminals by touching each probe to one terminal each. Reverse the probes and take a second resistance measurement. Each measurement should read less than one ohm.
TEST 2: Set your ohmmeter to its highest resistance scale. Touch one of the meter's probes to a magnetron terminal. Touch the other probe to the metal magnetron housing. Take special caution to not touch the two probes together. This could result in an inaccurate reading. This test should produce a reading of infinity - indicating an open circuit.
Read the tips on the below links on how to replace your microwave oven's diode and how to discharge the capacitor.
http://www.fixya.com/support/r7088355-replace_microwave_ovens_diode
http://www.fixya.com/support/r7088317-discharge_microwave_ovens_capacitor
I hope the above is helpful.
Good luck.
  • Brendan Mar 31, 2011
    walesarumi - thank you very much for your detailed information.
Need a user manual for Samsung TDS Microwave model no MS143SCE
Hello, Ismail -
This is the link to the web page where you can download the manual:
http://www.samsung.com/za/support/model/MS143SCE/XFA
Scroll down that page until you see MANUAL DOWNLOAD in large print.
Look on the right side on that section of the page and find the DOWNLOAD link.
Click or tap on the download arrow.
You will see all the pages of the manual, which you can download and save to the Documents folder of your computer (look for the icon in the upper right corner of the page; the icon looking like a piece of paper with a downward pointing arrow in the middle.)
Make sure you save the downloaded file using a file name you can find again easily - Samsung Microwave MS143SCE Manual, for example.
Note: You will need Adobe Acrobat Reader software, free.
Best wishes.
Feb 27, 2018 | Samsung Microwave Ovens
Can't heat food
So we can help you, please post a NEW question, and please include your brand name and the full model number from the tag in or on the unit, as well as the answers to these questions:
When you try to microwave are the inside light, internal cooling fan and turntable all working?
Is there any unusual noise or is it louder or quieter than normal?
A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are working.
Oct 11, 2009 | Goldstar Microwave Ovens
Microwave samsung not working showing e-1everyting appears to be working except that it is not heating food or anything else. just stopped and now in the display it is showing "e 1"
We would need your full model number from the tag on the unit.
Since FixYa is not currently notifying us Experts when Clarification Requests are answered, you will need to post a NEW help request.
I
n your new post, please include your brand name and the full model number from the tag in or on the unit, your symptoms, as well as the error code you mention.
Oct 07, 2009 | Samsung Microwave Ovens
Ge profile spacemaker over range microwave not heating
It was probably the Magnatron tube that went out , they are normally replaced only under warr. due to the cost to repair , the part is roughly 200.00 and labor ranges from 100-200. I guess it all depends on what it is worth to you , you can pick a decent brand new one up for about 200. Hope that helped you out. Phil
Dec 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Outside caseing heating up while cooking`
Also, Please reply back with your brand and model number so we can help you.
Nov 20, 2008 | Sharp R-1480 Microwave Oven
Sanyo microwave
Could be the Magnatron, Diode, HV Cap or Transfomer, some also have a high voltage fuse that blow. Unless you really are confident playing with Very High Voltages, and have a meter capable of 5000v, I dont recommend you repair yourself as a microwave will happily electrocute you. Also if the discharge resistor has burnt out on the cap (assuming it was fitted on your model) the capacitor can store enough power to kill you even when the unit is unplugged so you must discharge the cap before playing with anything else to be safe.
Mar 14, 2008 | Sanyo EM-Z2100GS Microwave Oven
Microwave Ovens Logo
482 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
